Pololu Electronics
Revision as of 08:22, 11 September 2010 by Adrianbowyer (talk | contribs) (Introduction)
Pololu Electronics
Release status: Working
Alternative Mendel electronics based on the Arduino Mega and the Pololu A4983
GPL v2
Electronics
Eagle
Introduction
This is a popular and actively developing set of electronics for Mendel that has been designed to be printed by Mendel itself.
It is based on the Arduino Mega and the Pololu A4983 stepper driver.
As Nophead has pointed out, that Pololu driver is a nice design, but with one big shortcoming: it will run hot, and is difficult to cool because it's so small. So what I've done is to design the electronics in such a way that they both perform their function and act as a physical duct for the flow from a fan to direct their own cooling. A happy side-effect of this is that the resulting PCBs are very simple, and can be made single-sided without any thin tracks. Thais is why RepRap itself can make them. We must walk before we can run...
Indeed, so simple is the design that it is quite straightforward to make it on a couple of pieces of stripboard. That is how I prototyped it.
All the Eagle design files for this are in the repository here, along with mechanical alterations and additions to the Mendel design to accommodate them.
The latest copy of the standard RepRap firmware in the subversion repository supports this design. Set MOTHERBOARD to 3 in your configuration.h file and compile for the Arduino Mega. Note: also check that the pins.h file corresponds with how you have made this; I am changing the pin assignments around a bit as I re-design the PCBs (see below).
Pololu do a DC motor controller with an identical geometry, so it should be possible to make a similar device with - say - two stepper drivers and two DC motor drivers that would control further extruders.
Schematics
Power Side -- This is the side that has higher voltage to power the motors. Signal Side -- This is the side that has lower voltage to handle data communication and stepper signal communication.
Here are the schematics, one for each side. The Pololu boards have 16 connections that come out of the edges on a 2.54mm pitch. Those are the columns of 8-way connectors shown on the schematics. I deliberately did not create a single Eagle library device for the Pololu boards, as half their connections go to one PCB, and the other half to the other. The whole thing makes a box structure that both simplifies connections and also ducts the cooling air, as mentioned above.
The Arduino Mega connections are the ones labelled A0, D52 etc.
Leave the 78L05 5v regulator off if you connect Vdd to the 5v output of the Mega.
Making the PCBs in RepRap
I've done a couple of PCB designs. They are in the repository in electronics/Pololu-electronics. They are single sided, have no tracks thinner than 1.27mm (0.05"), and have no tracks running between pins, so they are reasonably easy to draw on copper-clad board with an etch-resist pen in a RepRap.
The connections to the Mega are by a single 8x2 connector, which is straightforward to wire up with IDCs and sixteen-way ribbon cable, plus four leads from the power-side board to A0, D2, A1 and D3 for the extruder heating and bed heating respectively.
The stepper drivers are canted at a slight angle to make it easier to get a screwdriver in to adjust their current-setting pots. The voltage regulator and the MOSFETs can either be mounted on the component side of the power board, or on the other side in the air stream.
Making the electronics using stripboard
Here are all the components except the connecting wires. I built it on two pieces of stripboard 13 strips wide by 41 holes long. Start by soldering 90o pin headers into the Pololu boards so the connections stick out sideways.
Here are the reverse sides of the boards, showing the track breaks. It is really important to double check everything at this stage because, after you do the final assembly, it will be very difficult to make corrections.
Solder all the Pololu boards onto one piece of stripboard first. Make this the power side (with VMOT, VDD and two GNDs). Run a bead of solder along the tracks for VMOT and the two GNDs to give plenty of current carrying capacity. Do the same on the four connections to each motor.
Now for the tricky bit...
No. Not yet. I just had a better idea. Instead of soldering in the Pololu boards, put SIL socket strip in to accommodate them like this:
Then the whole device would just push-fit together. Best check the current capacity of the connections of the strip you choose. Or you could solder the power side and use the stripboard on the signal side; that way you'd still get a push-fit device, but with the solder to take the motor currents.
Back to doing it the tricky way...
...you have to reach in with the soldering iron to do the second stripboard. You may find it easier to put the solder in from the other side to the one shown in this photograph.
Here is the finished device. Note the red and black wires - they carry Vdd and ground from the power-side stripboard to the signal-side one.
It is intended to mount the whole thing on a fan in such a way as the entire fan flow is ducted between the four Pololu boards to cool them.
Here it is under test:
Video
Finally, here's a brief video...
<videoflash type="vimeo">13772589|640|480</videoflash>
As you can see, I've mounted the device on an old power-supply fan. With that the chips run only seven or eight degrees Celsius above ambient, which is cucumber cool. A neater and more compact arrangement would be to put the assembly on a couple of small processor fans, which are about the same size as the gap between the stripboard pieces; or maybe one could do without the fan altogether and just rely on convective cooling. I tried turning the fan off and, in an environment at around 24 oC, the boards ran at just over 40 oC.
The mechanical designs for all these parts are in the same directory as the electronics design in the distribution: mendel/electronics/Pololu-electronics.
Other Pololu Designs
Triffid Hunter
[Original Blog Post Here]
by Triffid Hunter
Rapatan
Complete electronics consisting of 2 stackable boards, RapatanShield_base_board_V1.0 on top of Arduino_Mega_Board. (see link for further details)
Base board provides  ; 4 steppers control , 3 opto end stops, 2 heaters (Heater bed 10A, & Extruder Heater 3A) and 2 Thermistors for temperature control. The board is now fully tested and working but I am awaiting firmware update so heater bed control is fully automatic.
[1] Rapatan_Shield_base_board_V1.0
[2] Arduino Mega
Johnnyr
Another shield design for the Arduino Mega, plugging the Pololu stepper driver boards into the shield, is being documented at Arduino_Mega_Pololu_Shield . This variant is designed so that the shield PCB itself can be created (masked) on a RepRap.
This is an angle view of the shield.
mike mackenzie
this is my addition for this project, this is a continuation of my first one, i has 4 pololu stepper drivers on it, 6 opto end stops connectors, and a power input for the stepper drivers i will post a picture has soon has i can figure it out but for now here is a link to my thingiverse [3]
ljyang
I have have been working on a replacement for the monolithic design I started on a while back and will be using the following carriers for the pololu drivers along with a different shield for my mega. My repstrap mechanics are almost all done now too, but I'm redesigning it for belts instead of leadscrews as well. I'm planning on making my shield compatible with the MBI stuff, so I'm following their pinout and such for the shield. The driver board below should work for mendel, current MBI and new MBI electronics. I tried to make it flexible so you could choose the connectors you wanted to use for interconnects. Ljyang-pololu-carrier.png
Dave M.
This is a board I'm planning on making to give MakerBot users an upgrade path to the Pololu driver that fits into the existing mounting holes. I have min/max endstop support, along with jumper-selectable step sizes. All connections can be configured with 0.1" connectors like the MTA100, or you can use terminal blocks to do your wiring. Comment on my blog if you have questions / comments / suggestions!
Tony Buser
A simple Pololu Extruder Stripboard to interface with the current electronics but bypass the noisy inefficient extruder controller for driving just the extruder stepper.
Ian Eagland
I have built a pair of single sided boards machined on my repstrap. They follow Adrian's double board idea and circuit. I have made one of the boards a Mega shield. By using extra long header pins it was fairly easy to solder the pins on the copper side. I moved the Mosfets and power supply to the shield. I also used sockets so the Pololu boards plug in. I was also able to angle the Pololu boards so the trim pot can be accessed in situ. The upper board only has the Pololu stepper motor connections. I also put the fan connection on this board but it could have been on the shield. By using 90 degree connectors for the motors all soldering is straight forward. The only remaining job is to add the fan mounts. There is one tracking error I had to patch and I had trouble machining one board as the cutter broke and when I replaced it I set the cut too deep. It took just over 2 hours to machine the boards but I had to use a slow feed as the spindle only runs at 2000rpm. When Adrian changes the pins I will produce another set with a more sensible layout based on all that I experienced so far.
Even more simplified version by Peer
In this thread http://forums.reprap.org/read.php?35,56137,56252 (german) I show the building of my even more simplified electronics.
See this image from the thread: http://forums.reprap.org/file.php?35,file=2788,filename=IMG_0196_web.jpg
The idea is to cut through anything which is not essential for a Mendel with stepper extruder. This removes a lot of PCBs, Connectors, extra electronics and gets really cheap. So basically its 4 Pololu stepper drivers to drive XYZ and an Extruder, and simply a AVR ATmega644p controller running on 20 MHz (sitting under the LCD) which replaces even the Arduino Mega board. Add some Rs, Ts, Cs and connectors for 2 * temperature measurement, heating control and opto end stops, and it is as simple as it can get.
As a bonus, I also added a simple off-the-shelf LCD and probably will add some keys, so a menu system can be implemented. But this is not essential, because everything can also be controlled from the host.
Communication is over a RS232 serial line with the MAX232 chip. If you do not have a serial port on your PC, you can use a USB-Serial adapter. If you use the USB-serial adapter with the FTDI, you can omit the MAX232 chip and use the setup like in the official Gen3 electronics.
This needs reassignment of the controller pins, so some adaptation in the firmware and the Arduino IDE will be necessary. So this board will run the FiveD firmware.
This other photo http://forums.reprap.org/file.php?35,file=2795,filename=IMG_0199_web.jpg shows the PCB without the LCD, so you see the controller (under it are still some parts). To the left I put a super-simple add-on which will carry the Rs, Ts and Cs to as per above text, and more connectors for said peripheral devices. The shown stepper already ran happily many hours today. To the there is a little board which simply makes 5V out of 12V with a 7805, but this is just a thingy for convenient testing which will not be necessary when using the PC PSU with it's own 12V and 5V supply in the end.
Status: Work in progress. Everything worked out very well so far.
