PiBot TB6600 Stepper Driver
Description | Part of PiBot Electronics,Stepper Driver
License | |
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | see files
External Link |
- PiBot TB6600 Stepper Driver
The PiBot TB6600 Stepper Driver is a [TOSHIBA TB6600HQ] based driver.
- Features of stepper Driver
- PWM chopper-type single-chip bipolar sinusoidal micro-step stepping motor driver.
- BiCD 0.13 (50 V) process, Lower Ron: 0.4 Ω(typ.).
- Output withstand voltage: VCC = 50 V.
- Output current: IOUT = 5.0 A (absolute maximum ratings, peak, within 100ms);IOUT = 4.5 A (operating range, maximal. value);MoreStepper motor can choose. Solder 6*1W external resister sensor.
- Thermal shut down (TSD) protection.
- Under voltage lock out (UVLO) protection.
- Over-current detection (ISD) protection.
- Double input port: Anti-reverse structure IDC haeder( 8pin symmetrical input) & HT-396-4pin input (suit for DIY).
- Stepless adjustable reference voltage.
- Compatible the CNC Stepper Motor.
- Offer an solution to change your CNC to 3D Printer.
- Board size: 51.1*58.5mm ; fix hole: 43.9*45.7mm -Carry 60*60*10mm aluminum Heat sink which build-in fix hole and connection hole.
- Auto half current, energy conservation.
- photoelectric-isolation used in the input port,compatible more drive Level.
- Programmable micro step - 1/1, 1/2A, 1/2B, 1/4, 1/8, 1/16.
- Price for complete PiBot TB600 Stepper Driver $24,- (soldered, incl. 100mm cable and connector)
- For purchasing or more information, please contact PiBot, or one of the resellers.
- All parts are licensed under CC BY-NC-SA 3.0
Settings of Driver
PiBot TB6600 Stepper Driver all input pins build-in connect to GND with a 100KΩ resistance.
M1(input) | M2(input) | M3(input) | Mode (Excitation) | Illustrate |
L | L | L | standby mode (operation of the internal circuit is almost turned off) | H-High voltage, L-Low voltage |
L | L | H | 1/1(2-phase excitation, full-step) | |
L | H | L | 1/2A type (1-2phase excitation A type) (0%-71%-100%) | |
L | H | H | 1/2B type (1-2phase excitation B type) (0%-100%) | |
H | L | L | 1/4 (W1-2phase excitation) | |
H | L | H | 1/8 (2W1-2phase excitation) | |
H | H | L | 1/16 (4W1-2phase excitation) | |
H | H | H | standby mode (operation of the internal circuit is almost turned off) |
Auto\Latch(input) | Effect | Illustrate |
L | TSD and ISD functions return by either of turning on power supply again or
programming the ENABLE as H → L → H || default set to High | |
H | TSD and ISD functions return automatically |
TQ(input) | Vref Voltage Ratio | Effect | Illustrate |
L | 30% of the input Vref | decrease 70% Motor current | default set to High |
H | 100% of the input Vref | full current,more power |
100% Current Settings (Current value)
100% current value is determined by Vref inputted from external part and the external resistance for detecting output current. Vref is doubled 1/3 inside IC. Per the [TB6600 datasheet], the calculation for current is:
Io(100%) = (1/3 × Vref) ÷ RNF
The average current is lower than the calculated value because this IC has the method of peak current detection.
RNF should be 0.68||0.68||0.68=0.2267Ω
Sometimes this value can be set by experiment, that Stepper motor not heating, small noise and the chip do not get too hot.
How to Build
- Related Files
- Solder Images
- Prepare all of the components to build a PiBot TB6600 Stepper Driver;
- You'll need a soldering toolkit and SMT soldering toolkit to finish this board.
- Use SMT soldering toolkit
- Apply solder paste to every exposed SMD pad.
- Place each SMD component on its appropriate pad.
- Place populated board on a cold hotplate,turn hotplate on,board solders itself!
- Solder in remaining through hole components.
- If you without a soldering toolkit, you can also use an tweezers and an soldering iron finish them by manual.
- Use soldering toolkit
- Insert through hole components.
- solder all these pins to the pad.
- Solder the TB6600 in bottom
- Be careful, please ensure no short cut and insufficient solder.
- Test
- Before plug in the power source, you first need to check the polarity of electrolytic capacitor, chip and diode.
- Use an digital multimeter to test the resistance value of the power. Usually, it has a increase resister. Ensure no short cut and insufficient solder.
- Now, you can plug in the power source, the power LED (red) lighten. Usually,the Run LED(green or red) lighten(it not related).
- Connect the control pins and output pins(A1-Red A2-Green B1-Yellow B2-Blue or A1-Black A2-Green B1-Red B2-Blue), input signal,
- stepper Motor and Driver Connection
A1(output) | A2(output) | B1(output) | B1(output) |
Red wire | Green wire | Yellow wire | Blue wire |
Black wire | Green wire | Red wire | Blue wire |
Pin Map
- Input, The IDC Header
Pin | Name | Function |
1 | Enable | Control signal input. set to high input, set to low disable input. |
2 | direction | Forward/reverse control. set to high CW, set to low CCW. |
3 | clk | A pulse on this line will make the stepper motor advance one step in the desired direction. |
4 | GND | Connect to the controller common ground. |
5 | GND | Connect to the controller common ground. |
6 | clk | A pulse on this line will make the stepper motor advance one step in the desired direction. |
7 | direction | Forward/reverse control. set to high CW, set to low CCW. |
8 | Enable | Control signal input. set to high input, set to low disable input. |
- Input, HT-3.96mm-4pin header
- Input, HT-3.96mm-2pin header
1 | Power + | Input the power source "+" polarity. Limit input:0-45V. |
2 | Power - | Input the power source "-" polarity. |
- Output, HT-3.96mm-4pin header
1 | A1 | Output of Driver connect to Stepper motor A1-A2 |
2 | A2 | Output of Driver connect to Stepper motor A1-A2 |
3 | B1 | Output of Driver connect to Stepper motor B1-B2 |
4 | B2 | Output of Driver connect to Stepper motor B1-B2 |
Driver Comparison
Manufacturer | Verified? | Location | Max current | Microstepping | Comments |
PiBot_TB6600_Stepper_Driver (using Toshiba 6600HQ) | Yes | CN | 0-4.5 A | 1/1,1/2A,1/2B, 1/4,1/8,1/16 |
Stepper Motor Driver 2.3 (using A3982) | Yes | US | 2 A | 1/2 | Listed for comparison. |
EasyDriver (using A3967) | Yes | US | 0.75 A | 1/8 | Slightly underpowered compared to other drivers, at only 750 mA/phase. bothacker uses EasyDriver[1], and reports that it has plenty sufficient power for Mendel. Recommended. |
Pololu stepper driver board | Yes | US | 2 A | 1/16 | Can get very warm; active fan cooling or passive small heatsink is needed above ~0.5 A. Recommended. |
... ay.com/autohec 4 Axis Stepper Motor Driver Controller (using A3977) | Yes | US | 2.5 A | 1/8 | 4 stepper drivers on a single board. |
DIY CNC | No | GB | 2.5 A | 1/8 | Can drive 1 stepper; discount when buying several. |
Arduino Motor Shield | No | US | 0.6 A | ? | Requires Arduino as controller. Can drive 2 servos, 4 DC, or 2 (bipolar or unipolar) steppers. Website notes that you can increase the max current by piggy-backing (soldering a chip onto a chip) another L293D chip on top of the first (and another one on top of that) |
... ay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=4+axis+TB6560&_sacat=See-All-Categories TB6560AHQ based | No | GB/PRC | 1.5 - 3 A | 1, 1/2, 1/8, 1/16 | Can drive 3 to 5 steppers depending on model; read more. |
Stepper Driver 2.3 Clone by kymberlyaandrus | Yes | US | 2 A | 1/2 | Same schematic but physically smaller than the original version. The trim pot doesn't have a start/end point so adjusting the current can be more difficult than other boards. The terminal blocks are nice because they don't require making special connectors. |
Gecko Drive | Yes | US | 3.5 A | 1/10 (only) | Can drive 4 steppers |
Nanotec SMC11 | Yes | GER | 1.4 A | 1/16 | with cooling until 2.5 A |
LiniStepper by Roman Black | no | US | 3 A | 1/18 and "stepless" | Open Source: Circuit Diagram, PCB (Board) Layout, and PIC Software all available. |
Tri Duino Stepper | ??? | ??? | ??? | ??? | Open Source |
A3979breakout | ??? | ??? | ??? | ??? | ??? |
grblshield | No | US | 2.5 | 1/8 | 3 axis controller plugs onto Arduino Uno or similar |
Developments
PiBot Box will put on sale recently. It is made of steel plate, can contain 1 to 6 driver.
