P3Steel Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Lasercut parts
The P3Steel frame is essentially built from 3mm lasercut steel. CAD Drawings are available from GitHub and author's page on Thingiverse.
P3Steel V1.2 | P3Steel V2.0 |
Has 3 Bearings on Y Carriage and 4 point heated bed leveling system. | Has 4 Bearings on Y Carriage and 3 or 4 point heated bed leveling system. |
P3Steel V2.01:
CAD file for version 2.01: File:PRUSA i3 steel 3mm lasercut 2.01d irobri.dwg
P3Steel V2.5:
CAD file for version 2.5: File:PRUSA i3 steel 3mm lasercut 2.5DXL e irobri.dwg.zip
Mechanical Parts
Bearings
Image | Part | Quantity | Unit price | Total cost | Commentaries |
LM8UU linear bearings | 11 | -- | -- | 4 for the Y carriage, 4 for the Z carriage and 3 for the X carriage. | |
608zz axial ball bearings | 2+3 | -- | -- | One for each X and Y-axis idlers.
Three for a Wade's extruder (but depends on the extruder model). | |
Other axial bearings (depends on the extruder model) | -- | -- | -- | -- |
Motors & couplings
GT2 Pulleys | 2 | -- | -- | -- | |
GT2 Belt (2 x 1m) | -- | -- | -- | -- | |
Flexible coupling 5mm to 5mm | 2 | -- | -- | Couple the Z-Axis motors to the threaded rods. | |
NEMA 17 Stepper motors | 5 | -- | -- | 1 for the X-axis, 1 for the Y-axis, 2 for the Z-axis and 1 for the extruder. |
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
- 2x Threaded rod M5x295 mm (305mm for version 2.5)
Smooth rods
6 Smooth rods are needed of the following sizes:
- 2x Ø8x375 mm for X-Axis (385mm for version 2.5)
- 2x Ø8x341 mm for Y-Axis (350mm for versions 2.01 and 2.5)
- 2x Ø8x320 mm for Z-Axis (330mm for version 2.5)
Screws
Approximately (with a reasonable safety margin):
80 x M3 nyloc nuts. 4 x m5 small nuts. (for z axis rods to drive x-carriage)
60 x M3 12mm hex screws. 20 x M3 20mm hex screws. 20 x M3 8mm hex screws.
20 x M3 washers.
2 x M8 30mm hex screws. 2 x M8 nyloc nuts. 10 x M8 washers.
The above does not include the screws, washers and nuts needed by the extruder / hotend subassembly. Stainless steel (vs. mild steel or carbon steel) M3 screws and nuts are much preferable, specially for the frame assembly.
Electronics
Arduino Mega 2560 board (or compatible) | 1 | -- | -- | The printer's "brain". | |
RAMPS 1.4 board | 1 | -- | -- | Interface betwen the arduino board and the hardware. | |
Stepper motor drivers. | 4 | -- | -- | Drive the motors | |
Mechanical endstops. | 3 | -- | -- | Endstops are required to calibrate the home position for each of the X, Y and Z-axis. Mechanical, optical or magnetic sensors can be used. | |
12864 Graphics LCD Controller or 2004 LCD Smart Controller | 1(Optional) | -- | -- | An LCD controller allows printing without having a computer connected to the Arduino, by reading G-code from an SD card. | |
ATX PSU or LED strip 12V power supply. | 1 | -- | -- | See Choosing a Power Supply for your RepRap. We want 12V@16A minimum. |
Extruder / Hotend
This is a tough choice for people building their first RepRap printer, as it can become a major stumbling point during the first attempts to print a 3D object.
If you are not yet an experienced RepRap builder/user, it is strongly suggested that you purchase a hotend with potentially local support i.e. from the same local shop where you usually buy filament from. Once you have decided on a specific hotend, you can decide on an extruder design compatible with it and with the P3Steel.
As of early 2015, there are two popular choices for hotends: - E3D all-metal hotends. - J-head type hotends.
As for the extruder type, these basically fall into two categories: - Direct drive extruders. - Wade's geared extruders.
The P3Steel version 2.5 supports single or dual Bowden extruders.
Heated Bed
There are a few options out there for heated beds, the simplest and most popular seems to be the mk3 as seen [here]. Refer to instructions for your particular bed for leveling and usage procedures (some recommend panes of glass be used to print on, although it is not necessary with the mk3).
