P3Steel Bill of materials
Proteins
Almost all the structure is made of steel so you will only need the following printed parts:
Part | Quantity |
Endstop Holder | 3 |
X-Axis Motor end | 1 |
X-Axis idler end | 1 |
X carriage | 1 |
Y belt holder | 1 |
Extruder (*1) | 1 |
(*1): Made of several plastic parts that depend on the chosen extruder model.
See the P3Steel Proteins page for more details.
Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make. See the P3Steel Vitamins page for details.
Electronics
Part | Quantity | Unit price | Total cost |
Arduino Mega 2560 board (or compatible) | 1 | -- | -- |
RAMPS 1.4 board | 1 | -- | -- |
Stepper motor drivers. | 4 | -- | -- |
Endstops. | 3 | -- | -- |
LCD Controller | 1(Recommended) | -- | -- |
Power supply | 1 | -- | -- |
See the P3Steel Electronics and wiring page for details.
Mechanical Parts
LM8UU Linear bearings | 11 | -- | -- |
608zz Axial bearings | 2 | -- | -- |
Other axial bearings (pending) | -- | -- | -- |
GT2 Pulleys | 2 | -- | -- |
GT2 Belt, 6mm | 2m | -- | -- |
Flexible coupling 5mm to 5mm | 2 | -- | -- |
NEMA 17 Stepper motors | 5 | -- | -- |
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
- 2x Threaded rod M5x295 mm
Smooth rods
6 Stainless steel 8mm smooth rods (optionally chromed) are needed of the following sizes:
- 2x Ø8x375 mm for the X-Axis.
- 2x Ø8x341 mm for the Y-Axis (350mm for version 2.01 of the frame).
- 2x Ø8x320 mm for the Z-Axis.
Screws, nuts and washers
The entire steel structure is assembled with approximately 40 x 12mm M3 hex screws and the corresponding M3 nyloc nuts.
A few more M3 hex screws are required for the steppers, 2 x M5 nuts are required for the Z-axis threaded rods and some more screws, nuts and washers of various sizes are required depending on the choice of extruder, X motor mount, X and Y idlers and endstops.
See the P3Steel Vitamins page for a more detailed list of screws, nuts and washers needed to assemble a P3Steel.
