P3Steel Bill of materials
Revision as of 17:40, 26 October 2014 by AndrewBCN (talk | contribs)
EnglishEspañol
Introduction | Bill of materials | Proteins | Vitamins | Painting the steel frame parts | Main steel frame assembly | Y-axis assembly | X-axis assembly | Connecting X-axis and Z-axis | Motor assembly | X and Y-axis motions | Heated bed assembly | Extruder assembly | Electronics and wiring | Extras
Proteins
Almost all the structure is made of steel so you will only need the following printed parts:
Part Quantity
Endstop Holder 3 to 6
X-Axis Motor end 1
X-Axis idler end 1
X carriage 1
Y belt holder 1
Extruder (*1) 1
(*1): Constructed of several plastic parts that depend of the chosen model
Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Mechanical Parts
Part Quantity Unit price Total cost
LM8UU Lineal bearings 11 -- --
608zz Axial bearings 2 -- --
Other axial bearings (pending) -- -- --
GT2 or T2.5 Pulleys 2 -- --
GT2 or T2.5 Belt -- -- --
Flexible coupling 5mm to 5mm 2 -- --
NEMA 17 Stepper motors 5 -- --
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
  • 2x Threaded rod M5x295 mm
Smooth rods
6 Smooth rods are needed of the following sizes:
  • 2x Ø8x375 mm for X-Axis
  • 2x Ø8x341 mm for Y-Axis
  • 2x Ø8x320 mm for Z-Axis
Electronics
Arduino Mega 2560 board (or compatible) 1 -- --
RAMPS 1.4 board 1 -- --
Stepper motor drivers. 4 -- --
Endstops. 3 -- --
Smart LCD 1(Optional) -- --
Power supply 1 -- --
Screws, nuts and washers
The entire steel structure is assembled with approximately 40 x 12mm M3 hex screws and the corresponding M3 nyloc nuts.
A few more M3 hex screws are required for the steppers, 2 x M5 nuts are required for the Z-axis threaded rods and some more screws, nuts and washers of various sizes are required depending on the choice of extruder, X motor mount, X and Y idlers and endstops.
