NEMA 17 Stepper motor
Revision as of 21:12, 7 December 2014 by Thejollygrimreaper (talk | contribs) (Common Stepper Motor Models)
Vitamin
A NEMA 17 sized stepper motor.
Wikipedia Stepper motor
another NEMA-17 size motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Dimensions
the most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
References
You are welcome to add information on a stepper motor you encounter, but please add only steppers not other motors which were tested to actually work on some or all printer.
− + however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
Model Holding Torque Rated voltage Shaft Step angle Motor length
42HT47 44 N·cm 2.8 V Ø 5 mm Dual 1.8° 47 mm
42SHD0404-22 52 N·cm 3.84 V Ø 5 mm Single 1.8° 48 mm
42BYGH4803(SKU 1124030) 54.0 N·cm 4.2 V Ø 5 mm single 1.8° 48 mm
42BYGH4803-DC (SKU 1124090) 54.0 N·cm 4.2 V Ø 5 mm single 1.8° 48 mm
1040222 88 N·cm 2.6 V Ø 5 mm single 1.8° 48 mm
LDO-42STH47-1684A 50 N·cm 2.8 V Ø 5 mm single or dula 1.8° 47 mm
4118S-62-07 31 N·cm   Ø 5 mm 1.8° 34 mm
--- ignore everything below, this page is a work in progress to build a table without all the external linking ---
| Longs Motor || 17HS4417 + − | 40.0 N·cm || 2.6 V || Ø 5 mm single || 1.8° || 40 mm ||   + − | 2PrintBeta (DE)
+ − Charlie's 3D Technologies (BE) + − |- + − | Mercury Motor || SM-42BYG011-25 + − | 23.0 N·cm || 12 V || Ø 5 mm single || 1.8° || 34 mm || Rated voltage higher than ideal for running on 12 V current chopping drivers. + − | Abra (US & CA)
+ − Akizuki Denshi Tsusho (JP)
+ − Australian Robotics (AU)
+ − Cool Components (UK)
+ − MindKits (NZ)
+ − Robot Gear (AU)
+ − SparkFun (US) + − |- + − | RobotDigg || 17HS1011-20B + − | 28.0 N·cm || 4.8 V || Ø 5 mm single || 1.8° || 34 mm || Also with flat on the shaft available. + − | RobotDigg (CN) + − |- + − | RobotDigg || 17HS3001-20B + − | 40.0 N·cm || 2.0 V || Ø 5 mm single || 1.8° || 40 mm || Also with flat on the shaft available. + − | RobotDigg (CN) + − |- + − |- + − | RobotDigg || 17HS5005-S24 + − | 44.0 N·cm || 3 V || Ø 5 mm double || 1.8° || 48 mm || Double Shaft + − | RobotDigg (CN) + − |- + − | RobotDigg || 17HS6002-27B + − | 65.0 N·cm || 4.05 V || Ø 5 mm single flat|| 1.8° || 60 mm || Also with flat on the shaft available. + − | RobotDigg (CN) + − |- + − | Unknown || 17HD2038E + − | 45.0 N·cm ||   || Ø 5 mm single || 1.8° ||   ||   + − | EckerTech (CA) + − |- + − | Unknown || 17HS19-1684S + − | 55 N·cm || 2.8 V || Ø 5 mm single || 1.8° || 47 mm || Custom model. + − | Reprap Austria (AT) + − |- + − | Servo Corporation || KH42JM2B087C + − | 33 N·cm || 6.7 V || Ø 5 mm single || 1.8° || 42 mm || Custom built. + − | DIYTechShop (US) + − |- + − | SOYO || SY42STH47-1206A + − | 31.1 N·cm || 4.0 V || Ø 5 mm single || 1.8° || 40 mm ||   + − | Pololu (US) + − Watterott (DE)
+ − Zapp (UK) + − |- + − | SOYO || SY42STH47-1504A + − | 55.0 N·cm || 2.8 V || Ø 5 mm || 1.8° || 47 mm || Flat on the shaft. + − | LulzBot (US) + − |- + − | SOYO || SY42STH47-1684A + − | 43.1 N·cm || 2.8 V || Ø 5 mm single || 1.8° || 48 mm + − | Some vendors have longer than standard cables. Per phase: 1.68 A, 2.8 mH. + − | 3Distributed (UK)
+ − fabberworld.com (CH)
+ − LDO Motors (CN)
+ − Paoparts (FR)
+ − TU Delft Group (NL)
+ − Zapp (UK) + − |- + − | SOYO || SY42STH47-1684B + − | 43.1 N·cm || 2.8 V || Ø 5 mm double || 1.8° || 48 mm || Same as SY42STH47-1684A, but double shaft. + − | LDO Motors (CN)
+ − Mendel-Parts (NL)
+ − Zapp (UK) + − |- + − | Thingibox || TB35HT36-1004A + − | 35.3 N·cm || 2.8 V || Ø 5 mm single|| 1.8° || 36 mm || + − | Thingibox (ES) + − |- + − | Thingibox || TB35HT36-1004B + − | 35.3 N·cm || 2.8 V || Ø 5 mm double|| 1.8° || 36 mm || + − | Thingibox (ES) + − |- + − | Trinamic || QSH4218-51-049 + − | 49 N·cm ||   || Ø 5 mm || 1.8° || 47 mm || Tested on MakerBot Cupcake CNC + − | Reichelt (DE) + − |- + − | Wantai || 42BYGH W811 + − | 47.0 N·cm || 3.1 V || Ø 5 mm || 1.8° || 48 mm || Variant with flat on the shaft available. + − | Cubic-Print (DE)
+ − electronic-things (DE)
+ − Phidgets (US)
+ − RepRap teile (DE)
+ − ReprapWorld (NL)
+ − Createc 3D (ES) + − |- + − | Wantai || Custom for QU-BD + − | 49.0 N·cm || 3.6 V || Ø 5 mm single || 1.8° || 48 mm ||   + − | QU-BD (US) + − |- + − | Unknown || Unknown + − | 32.4 N·cm || 2.8 V || Ø 5 mm single || 0.9° || 43 mm ||   + − | MatterHackers (US) + − |- + − | Makemendel || + − | 4.4 Kg·cm || 2.8 V || Ø 5 mm single || 1.8° || 47 mm || + − | Makemendel (IN) + − |} + − + −
+ − These were listed as "not tested" earlier, so your mileage may vary: + −
Manufacturer Model Holding torque Rated voltage Shaft Step angle Motor length Additional notes Vendor (shipping location)
Lin Engineering 417-11-48-02
7.0 N·cm   Ø 5 mm 1.8° 28 mm May be too weak.
Alltronics (US)
Lin Engineering 4018X-07-04
11.0 N·cm   Ø 5 mm 1.8° 26 mm May be too weak.
Lin Engineering 4118L-25P-07R0
48.5 N·cm   Ø 5 mm 1.8° 48 mm
Alltronics (US)
Nidec Servo KH4248-B95101
48 N·cm   Ø 5 mm single 1.8° 48 mm
Mechapro (DE)
Oriental Motors PK244-01AA
33.0 N·cm 5.6 V Ø 5 mm single 1.8° 39 mm Bipolar/Unipolar. Holding torque/volts listed for Bipolor mode
eBay? (Worldwide)
Oriental Motors PX243M-03AA
20.0 N·cm   single 0.9° 42 mm
Interinar Electronics LLC (US)
Oriental Motors PX243M-01AA
15.0 N·cm   Ø 5 mm single 0.9° 33 mm Uses Imperial #4-40 TPI mounting holes instead of M3 metric.
Oriental Motors PKE245DA-L
55.0 N·cm   Ø 5 mm single 1.8° 47 mm
Oriental motor (JP/US)
Rugao Xinhe 17H185H-04A
43.8 N·cm 2.8 V Ø 5 mm single 1.8° 42 mm
AusXmods (AU)
Rugao Xinhe 17H185H-04B
43.8 N·cm 2.8 V Ø 5 mm double 1.8° 42 mm
AusXmods (AU)
SANYO DENKI (Japan) KH42KM2R001
45 N·cm   Ø 5 mm
Wantai Motor 42BYGHM809
48 N·cm 3 V Ø 5 mm 0.9° 48 mm
SparkFun (US)
Custom 42BYGH404
31 N·cm   Ø 5 mm single 1.8° 49 mm
Part number decoding
+ − You can decode the part number written on Shinano Kenshi motors with the SKC Stepping Motor Part Number decoder at Shinano Kenshi: "Stepping Motor Operation & Theory". + −
+ − You can decode Lin Engineering part numbers written on it with the "Lin part number system" decoder on p.1 and p.2 of the Lin Engineering Catalog. Page 9 of the Lin Engineering catalog explains the part numbering system.
