NEMA 17 Stepper motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Dimensions
Common Stepper Motor Models
the most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
References
− There are many online Shop selling different types of motors + − Below is a non-exhaustive list of possible motors and suppliers. +
− You are welcome to add information on a stepper motor/vendor you encounter, but please add only steppers not other motors which were tested to actually work on some or all printer. + the most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
− + however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
Model | Holding Torque | Rated voltage | Shaft | Step angle | Motor length |
42HT47 | 44 N·cm | 2.8 V | Ø 5 mm Dual | 1.8° | 47 mm |
42SHD0404-22 | 52 N·cm | 3.84 V | Ø 5 mm Single | 1.8° | 48 mm |
42BYGH4803(SKU 1124030) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm |
42BYGH4803-DC (SKU 1124090) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm |
1040222 | 88 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 48 mm |
LDO-42STH47-1684A | 50 N·cm | 2.8 V | Ø 5 mm single or dula | 1.8° | 47 mm |
4118S-62-07 | 31 N·cm | Ø 5 mm | 1.8° | 34 mm |
--- ignore everything below, this page is a work in progress to build a table without all the external linking ---
| Longs Motor || 17HS4417
| 40.0 N·cm || 2.6 V || Ø 5 mm single || 1.8° || 40 mm ||
| 2PrintBeta (DE)
Charlie's 3D Technologies (BE)
| Mercury Motor || SM-42BYG011-25
| 23.0 N·cm || 12 V || Ø 5 mm single || 1.8° || 34 mm || Rated voltage higher than ideal for running on 12 V current chopping drivers.
| Abra (US & CA)
Akizuki Denshi Tsusho (JP)
Australian Robotics (AU)
Cool Components (UK)
MindKits (NZ)
Robot Gear (AU)
SparkFun (US)
| RobotDigg || 17HS1011-20B
| 28.0 N·cm || 4.8 V || Ø 5 mm single || 1.8° || 34 mm || Also with flat on the shaft available.
| RobotDigg (CN)
| RobotDigg || 17HS3001-20B
| 40.0 N·cm || 2.0 V || Ø 5 mm single || 1.8° || 40 mm || Also with flat on the shaft available.
| RobotDigg (CN)
| RobotDigg || 17HS5005-S24
| 44.0 N·cm || 3 V || Ø 5 mm double || 1.8° || 48 mm || Double Shaft
| RobotDigg (CN)
| RobotDigg || 17HS6002-27B
| 65.0 N·cm || 4.05 V || Ø 5 mm single flat|| 1.8° || 60 mm || Also with flat on the shaft available.
| RobotDigg (CN)
| Unknown || 17HD2038E
| 45.0 N·cm || || Ø 5 mm single || 1.8° || ||
| EckerTech (CA)
| Unknown || 17HS19-1684S
| 55 N·cm || 2.8 V || Ø 5 mm single || 1.8° || 47 mm || Custom model.
| Reprap Austria (AT)
| Servo Corporation || KH42JM2B087C
| 33 N·cm || 6.7 V || Ø 5 mm single || 1.8° || 42 mm || Custom built.
| DIYTechShop (US)
| SOYO || SY42STH47-1206A
| 31.1 N·cm || 4.0 V || Ø 5 mm single || 1.8° || 40 mm ||
| Pololu (US)
Watterott (DE)
Zapp (UK)
| SOYO || SY42STH47-1504A
| 55.0 N·cm || 2.8 V || Ø 5 mm || 1.8° || 47 mm || Flat on the shaft.
| LulzBot (US)
| SOYO || SY42STH47-1684A
| 43.1 N·cm || 2.8 V || Ø 5 mm single || 1.8° || 48 mm
| Some vendors have longer than standard cables. Per phase: 1.68 A, 2.8 mH.
| 3Distributed (UK)
fabberworld.com (CH)
LDO Motors (CN)
Paoparts (FR)
TU Delft Group (NL)
Zapp (UK)
| SOYO || SY42STH47-1684B
| 43.1 N·cm || 2.8 V || Ø 5 mm double || 1.8° || 48 mm || Same as SY42STH47-1684A, but double shaft.
| LDO Motors (CN)
Mendel-Parts (NL)
Zapp (UK)
| Thingibox || TB35HT36-1004A
| 35.3 N·cm || 2.8 V || Ø 5 mm single|| 1.8° || 36 mm ||
| Thingibox (ES)
| Thingibox || TB35HT36-1004B
| 35.3 N·cm || 2.8 V || Ø 5 mm double|| 1.8° || 36 mm ||
| Thingibox (ES)
| Trinamic || QSH4218-51-049
| 49 N·cm || || Ø 5 mm || 1.8° || 47 mm || Tested on MakerBot Cupcake CNC
| Reichelt (DE)
| Wantai || 42BYGH W811
| 47.0 N·cm || 3.1 V || Ø 5 mm || 1.8° || 48 mm || Variant with flat on the shaft available.
| Cubic-Print (DE)
electronic-things (DE)
Phidgets (US)
RepRap teile (DE)
ReprapWorld (NL)
Createc 3D (ES)
| Wantai || Custom for QU-BD
| 49.0 N·cm || 3.6 V || Ø 5 mm single || 1.8° || 48 mm ||
| QU-BD (US)
| Unknown || Unknown
| 32.4 N·cm || 2.8 V || Ø 5 mm single || 0.9° || 43 mm ||
| MatterHackers (US)
| Makemendel ||
| 4.4 Kg·cm || 2.8 V || Ø 5 mm single || 1.8° || 47 mm ||
| Makemendel (IN)
+ − These were listed as "not tested" earlier, so your mileage may vary: + −
Manufacturer | Model | Holding torque | Rated voltage | Shaft | Step angle | Motor length | Additional notes | Vendor (shipping location)
Lin Engineering | 417-11-48-02
7.0 N·cm | Ø 5 mm | 1.8° | 28 mm | May be too weak.
Alltronics (US)
Lin Engineering | 4018X-07-04
11.0 N·cm | Ø 5 mm | 1.8° | 26 mm | May be too weak.
Lin Engineering | 4118L-25P-07R0
48.5 N·cm | Ø 5 mm | 1.8° | 48 mm |
Alltronics (US)
Nidec Servo | KH4248-B95101
48 N·cm | Ø 5 mm single | 1.8° | 48 mm |
Mechapro (DE)
Oriental Motors | PK244-01AA
33.0 N·cm | 5.6 V | Ø 5 mm single | 1.8° | 39 mm | Bipolar/Unipolar. Holding torque/volts listed for Bipolor mode
eBay? (Worldwide)
Oriental Motors | PX243M-03AA
20.0 N·cm | single | 0.9° | 42 mm |
Interinar Electronics LLC (US)
Oriental Motors | PX243M-01AA
15.0 N·cm | Ø 5 mm single | 0.9° | 33 mm | Uses Imperial #4-40 TPI mounting holes instead of M3 metric.
Oriental Motors | PKE245DA-L
55.0 N·cm | Ø 5 mm single | 1.8° | 47 mm |
Oriental motor (JP/US)
Rugao Xinhe | 17H185H-04A
43.8 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 42 mm |
AusXmods (AU)
Rugao Xinhe | 17H185H-04B
43.8 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 42 mm |
AusXmods (AU)
SANYO DENKI (Japan) | KH42KM2R001
45 N·cm | Ø 5 mm |
Wantai Motor | 42BYGHM809
48 N·cm | 3 V | Ø 5 mm | 0.9° | 48 mm |
SparkFun (US)
Custom | 42BYGH404
31 N·cm | Ø 5 mm single | 1.8° | 49 mm |
Part number decoding
+ − You can decode the part number written on Shinano Kenshi motors with the SKC Stepping Motor Part Number decoder at Shinano Kenshi: "Stepping Motor Operation & Theory". + −
+ − You can decode Lin Engineering part numbers written on it with the "Lin part number system" decoder on p.1 and p.2 of the Lin Engineering Catalog. Page 9 of the Lin Engineering catalog explains the part numbering system.
