Motor FAQ
Introduction
This page tries to answer most of the frequently asked questions related to the choice and operation of stepper motors used by the Reprap. There is a good article on wikipedia explaining the technology behind stepper motors. The physical size of stepper motors are usually described via a US based standard called Nema, the reprap site has an article explaining the standard.
The pages related to building a Mendel has a list of suppliers of stepping motors.
The power of a motor is usually proportional to the physical size of the motor, The Darwin version of Reprap primarily used NEMA 24 motors, whereas the Mendel version is designed to use either NEMA 14 or NEMA 17 motors. The more commonly used size is NEMA 17 as it is easier to find NEMA 17 motors with sufficient torque compared to NEMA 14.
Torque
The Mendel officially requires 0.137Nm torque (1400 g-cm or 1.215 lb-in) for the X, Y and Z axis. Recent designs for extruders almost exclusively require stepper motors as well, but no requirements for torque has been given in those designs.
Stepper motor's do not offer as much torque or holding force as comparable DC Servo motors or DC Gear motors. Their advantage over these motors is one of positional control. Whereas: DC motors require a closed loop feedback mechanism, as well as support circuitry to drive them, a stepper motor has positional control by it's nature of rotation via fractional increments.
Power and current
All stepper motors will have a certain specifications for voltage and current, typically 2.8V and 1.68A, as long as the stepper driver/controller does current control you can use any supply voltage greater than the motor's rated voltage. In fact, a large difference is advantageous to the top speed of the motor. If the motor dirver/controller does not do current control, you must use a supply voltage fairly close to the motor voltage (no more than 2x the voltage specified by the manufacturer) or the motor will overheat and burn out its winding insulation or demagnetize its rotor.
The 2.3 version of the Reprap axis controllers do have current control.
Stepper drivers vs Stepper Controllers
To run a stepper motor, two things are normally required: a controller to create step and direction signals(at +-5V normally) and driver circuit which can generate the necessary current/amperage to drive the motor. In some cases: a very small stepper may be driven directly from the controller, or the controller and driver circuits may be combined on to one board.
PWM and Stepper Drivers
From Wikipedia:[[1]]: Pulse-width modulation (PWM) is a very efficient way of providing intermediate amounts of electrical power between fully on and fully off. A simple power switch with a typical power source provides full power only, when switched on. PWM is a comparatively recent technique, made practical by modern electronic power switches.
Stepper Drivers normally work by chopping up a supply voltage using an embedded PWM chip. These chips do require minor support circuitry which is the primary thing you pay for when you buy a stepper driver. The PWM chips themselves usually have a unit price below $10USD depending mostly on their rated current.
Chip | Verified | Max Amperage | Comments |
[L293D | Yes | .6amp(s) | Multiples can be stacked on top of each other to divide up amperage. |
[A3967] | No | .75amp(s) | Slightly underpowered, at only 750mA/Phase |
[A4983] | Yes | 2amp(s) | Can get very warm, active cooling is needed |
[Allegro 3977] | No | 2.5amp(s) | Can drive 1 stepper, discount when buying several. |
[TB6560] | No | 2.5-3amp(s) |
Stepper drivers
Sourcing stepper motor drivers can be a bit difficult, the 2.3 stepper drivers for the Reprap is very hard to purchase pre-assembled, sourcing the individual parts and assembling the controllers can be done with just a little bit of skill, for those without skills or materials to assemble the boards, generic stepper drivers purchased from the web. In Europe it will usually be more cost-effective to purchase pre-assembled boards compared to purchasing the individual parts and perform a DIY assembly.
Manufacturer | Verified | Location | Max Amperage | Comments | |
[Sparkfun] | No | US | .75amp(s) | Slightly underpowered, at only 750mA/Phase | |
[Polulo] | Yes | US | 2amp(s) | Can get very warm, active cooling is needed | |
[DIY CNC] | No | GB | 2.5amp(s) | Can drive 1 stepper, discount when buying several. | |
[TB6560AHQ based] | No | GB | 2.5-3amp(s) | can drive 4 or 5 steppers depending on model | |
[Gecko Drive | Yes | US | 3.5amp(s)] | Can drive 4 steppers |
Micro stepping
Microstepping between the pole-positions is made with lower torque than with full-stepping, but has much lower tendency for mechanical oszillation around the step-positions and you can drive with much higer frequencies.
If your motors are near to mechanical limitations and you have high friction or dynamics, you won't receive much more accuracy. When your motors are 'overpowered' and/or you don't have much friction, then you can transfer the higher positioning accuracy to moving accuracy too.
