Assembling and setting up the machine should take between 4h to 8h or two afternoons :)
If you preassemble everything, or if you disassemble your machine for a travel, it should take 1h to put it back together.
<videoflash>QuMhb-vMsfw</videoflash>
General tips
Read the whole manual once or twice before starting, to get an overview of the build
Know the parts
Firstly, have a look at all the part and learn what everything is.
top corner (at the rear left, you can embed a raspberryPi pcb webcam in it)
z-slider with space to embed the z-endstop
How to insert a T-nut
Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Base frame
x4 base-corner
x4 300mm profile
x4 m4x8
x4 m4 t-nut
x4 base corner assembly
x1 bottom-plate
x4 m4x8
x4 m4 t-nut
don't lock the nut firmly for the moment
press the sides and check that every corner is square, lock the 4 corners
Z-sliders
x3 z-slider
x1 z-slider for endstop
x4 300mm profile
x8 m4x8
x8 m4 t-nut
pay attention that each aluminium profile can be a little different, check that the printed part slide well on it, enventually file it
the slider holding the z-endstop will go at the rear left
put the t-nut in place first
then the aluminium profile, lock the nut
check that the z profiles are almost square to the base frame (it will be better once the top frame is in place)
x3 top corner
x1 top corner for z-endstop
x4 m4x8
x4 m4 t-nut
the top corner eventually holding the raspberryPi webcam will go at the rear left
x2 300mm profile
x2 m4x8
x2 m4 t-nut
Y-sliders
Y-slider left
Y-slider right
x2 nema14 stepper motor
x2 pulley
x8 m3x30 counter-sunk
x4 603zz bearing
The instruction show the left side, it will be the same (in mirror) for the right side.
add the pulley on the motof shaft (if you have this pulley you will need to invert it)
check the position of the pulley with the printed part then lock it with the grubscrew
x2 300mm profile
x2 360mm belt
x4 m4x8
x4 t-nut
the belt need to be well tightened before locking the second t-nut
x4 m4x8
x4 t-nut
Z-drive
x1 closed-belt
x4 m5 threaded rod 300mm
x8 m5 nut
x4 mr105zz bearing
x4 pulley
x8 m5 nylon nut
here is an overview, we will assemble one rod at a time while the cube is laying on the side, then turn it and make another rod
lock the m5 nut together at the end of the rod (using two flat spanner #8 or two pliers)
don't forget to add the belt before the pulley
adjust the nuts so that you have no play in Z (between the nuts and the printed part) while the rod still turn easily
move the z-slider toward the middle
now you can lock the pulley on the Z rod, there should be no play in Z, between the pulley and the printed parts, but it should also turn easily
repeat for each corner (turn the cube as it's easier to work on the laying side)
x1 nema 17
x6 623zz bearing
x2 m3x10
x2 m3x20
x1 m3x25
x8 washer
x4 large washer
x1 m3 nut
x1 m3 nut housing
add the pulley on the motor shaft
the pulley should be flush with the panel, lock the pulley
the motor's connector is facing upward (in direction of the rear side of the machine)
start with the two m3x10 and washers
then with the two m3x20 holding the bearings between washers
insert the m3 nut in the printed housing (use a bolt to pull it through if needed)
put the four Z-slider at the same height (e.g.: using the square)
now you can tension the belt (caution to keep the z-rod in place, they may turn while you pull on the belt)
check that everything moves well and that the four Z-sliders move in a synchronised way, eventually using the belt or by turning one of the Z-rod
it is not always needed, but if you think a rod could fall off from a z-slider (maybe you need to tighten a nut one face more) you may add a zip-tie to prevent it (or this printed part)
Bed
x1 m4 t-nut
x1 m4x10
x1 Z-plate
x4 m3x16
x4 m3 nut
check z-sliding by moving the belt
x1 microswitch
x2 ferule
heatshrink tubing
x1 2pin wire with connector
shorten the 1m wire to 30cm (and save 70cm for the blower)
don't forget to add a 10mm of heatshrink tubing
pull gently to see if the crimping is ok
push the heatshrink tubing on the ferule
pass the wires first in the z-slider printed piece then push the endstop in place
x1 bed plate
x1 film heater
x3 m3 nut housing
x3 m3x35 countersunk head
x6 m3 nut
x3 spring
peel of the paper and stick the film heater on the plate
add the 3 countersunk m3x30
and lock them with m3 nut
place the aluminium bed over the wood bed and fix it with the 3 nut housings...
... or 3 bolts (like on the picture) as you prefere; the bottom part of the screws should be aligned with the bottom part of the bolts (the bed level will be adjusted at the end)
Rear Panel
x1 back panel
x1 plug
x1 switch
x2 m3x8
x2 m3 nut
place the switch on the back panel: position OFF downward
clip the switch on teh back panel
fix the plug with M3x8...
x3 6,35 ferule (+ insulation)
x4 4,8 ferule (+ insulation)
crimp a 6,35mm ferule on one side of the wire and a 4.8mm ferule on the other side (don't forget to add the insulations BEFORE you crimp the ferules!)
connect the switch (4,8mm ferule) and the plug (6,35mm ferule) with the red wire
connect the switch (4,8mm ferule) and the plug (6,35mm ferule) with the black wire
crimp a 6,35 ferule on the green wire
do it again with a 60mm red wire and a 4,8mm ferule
do it again with a 60mm black wire and a 4,8mm ferule
connect the switch and the plug with the 3 more wires
x1 power supply 150W
x2 m3x8
identify on the picture the 2 fixing points
place the power supply above the switch + plug
screw the lower part of the power supply on the back panel with a M3x8
rotate lightly the power supply through the left to make the wiring easier: L>red; N>black; Ground>green
replace the power supply verticaly and screw the upper part of the power supply on the back panel with a M3x8
x1 minitronics 1.1
x4 strut
x8 m3x8
screw the 4 struts on the 4 corners of the electronic board with 4 M3x8
place the electronic board on the back panel (USB port downward)
screw the electronic board on the back panel with 4 M3x8
connect the cables on the electronic board
connect the cables on the power supply
x1 NEMA 17 stepper motor
x1 knurled insert
fix the drive gear on the motor shaft
x1 extruder 17
x1 pneumatic fitting
x2 M3x10
remove the support material of the extruder idler
screw the pneumatic fitting in the extruder idler with the 2.5 hexagonal key
place the extruder idler on the back panel with the M3x10 (pneumatic fitting oriented upward - unlike shown on the picture...)
screw the M3x10 in the nema 17 stepper motor through the back panel (cable oriented downward)
x1 M3x16
x1 603zz bearing
x1 M3x25
remove the support material of the extruder strip
fix the bearing on the extruder strip with a M3x16
assemble the extruder idler and strip with a M3x25 and screw them in the motor through the back panel
x2 M3x35
x2 spring
x2 M3 nut
x2 M3 washer
screw the springs on M3x35 to keep the extruder idler and strip tight
x5 M4x8
x5 M4 T-nut
add the screws and nuts on the back panel and fix it on the back of the Mondrian structure
X-axis
X-endstop
x1 microswitch
x2 ferule
heatshrink tubing
x1 2 pin wire with connector
shorten the 1m wire to 80cm
Y-endstop
repeat the X-axis operations to make the Y-endstop
X-slider
x1 x-slider
x2 endstop
pass the wires first in the x-slider printed piece then push the X-endstop in place
pass the wires first in the x-slider printed piece then push the Y-endstop in place
x1 x-slider
x1 nema14 stepper motor
x1 pulley
x1 belt
x4 m3x30 countersunk
x2 603zz bearing
add the pulley on the motor shaft and lock it with the grubscrews
check if the teeth of the pulley are aligned with the groove of the aluminium profile extrusion
if the alignment is ok then fix the motor on the x-slider (wires must be oriented frontward) by screwing two m3x30 countersunk through the plastic
add the belt over the pulley
bring both sides of the belt together
place a 603zz bearing over the groove of the aluminium profile extrusion and screw a m3x30 countersunk through the x-slider and the bearing into the stepper motor
do it again with the last m3x30 countersunk and bearing
cross-section of the X-slider
x2 m4x8
x2 T-nut
place a x-belt-endin the aluminium extrusion groove
place the belt over the printed piece and lock it with a m4x8 and a T-nut (2mm before the extremity of the profile extrusion)
repeat on the other side of the profile extrusion...
... and stretch the belt before locking it with the m4x8 (use pliers to help you); check if the x-slider slides well on the profile extrusion - if no: untighten a bit the belt or unscrew lightly the 4 m3x30 countersunk
Blower
x2 ferule
heatshrink tubing
extend the blower wires with the 70cm wires saved from the Z-endstop: crimp the ferules on the wires, add the heatshrink tubing and heat it over the ferules
place the blower in front of the blower spout (an arrow indicates you the orientation)
push the blower in the printed piece
x2 m4x8 round-head
x1 m4x8
x3 T-nut
place the X-axis between both Y-sliders
lock it with m4x8 round-head and T-nuts
fix a m4x8 and a T-nut in the aluminium groove so that the X-endstop touches it before it touches the Y-motor 2
Hotend
x1 heater block
x1 nozzle
x1 barrel
x1 thermistor
screw the nozzle into the heater block until the nozzle meplat get aligned with the flat part of the heater block
screw the barrel into the heater block until it touches the nozzle
wrap the thermistor with a pice of Kapton...
... and place it into the heater block
x1 hotend heatsink (+ tube holder)
x1 PTFE tube
pass the PTFE tube in the tube holder and pass it through the heatsink hotend
screw the tube holder in the heatsink hotend
x1 hotend holder
x4 m3x8
orient the hotend heatsink so that the side with 5 holes is placed on the table (invisible)
screw the m3x8 into the hotend heatsink (on the side with 4 holes) through the hotend holder
push the PTFE tube in the barrel as much as possible
screw the barrel in the hotend heatsink...
... until the thread is aligned with the bottom part of the hotend heatsink and the edges of both metal parts are parallel (the longer part of the heater block is oriented towards the front of the hotend)
x1 x-slider
check the alignment of the heater block with the spout of the x-slider
the bottom part of the heater block must be aligned with the upper part of the spout holes
if the alignment is ok then fix the barrel in the hotend heatsink with a grubscrew
tighten the tube holder on the PTFE tube with a spanner: tight enough so that the tube is hold...
... but not too much so that the filament can still pass through it
x1 fan
x1 fan railings
x4 m3x16
x4 m3 washer
pass the 4 screws through the fan railings and the fan (wires oriented downward)
... and screw the elements in the hotend heatsink
x1 cartridge heater
keep 10cm of the cartridge heater wires (and save 70cm for the cable harness)
insert the cartrige heater in the heater block so that the wires run along the fan wires
fix the cartridge heater in the heater block with a grubscrew
x2 1mm ferrule
x2 heatshrink sleeve
strip one extremity of a black wire
crimp firmly the wire on the thermistor extremity with a ferule
add the heatshrink sleeve over the metal part and heat it with a lighter
cut the black wire the same length as the cartridge heater wires
once again: strip one extremity of a black wire
add the heatshrink sleeve over the metal part...
... and heat it with a lighter
bring the black wire together with the others...
... and cut it the same length as the others
x1 male casing
x6 female ferrule
strip the 6 extremities of the wires
crimp one female ferrule on each extremity...
... and insert them in the male casing just like on the picture - 1: fan (red wire on top)
2: thermistor (wires' position doesn't matter)
3: cartridge heater (wires' position doesn't matter)
your hotend is almost ready! you still need to heat the hotend and tighten the nozzle in the heater block as much as possible but you first have to do the wiring...
Cable harness
x2 2 pin-wire with connector
x2 cartridge wire (70cm)
x1 female casing
x6 male ferrule
x2 end piece
shorten both 2 pin-wires with connector to 70cm
take the 70cm cartridge wires that you've saved previously
crimp firmly the male ferrules on the 6 wires
place the cartridge wires on the left of the female casing...
... and push the male ferrules until they get locked in the casing
place both 2 pin-wires with connector so that the red wire is upward
place both end-pieces at the extremities of the cartridge wires...
your cable harness is ready to be connected
Wiring
wire the 5 motors with their corresponding cables
X-motor (long); Y-motor 1 (long); Y-motor 2 (long); Z-motor (short); E-motor (short)
bring the wires from Y-motor 2 out of the connector related with the electronic board and invert them
bring the wires back in the connector
pass the wires of the X-axis through the RepRap symbol cut on the back panel
connect the different electronic elements on the minictronics like shown on the picture (pay attention to the wires color)
tidy the wires by passing them through the 4 cable holders
zip-tie the bed wires on the wood panel
stick Kapton strips on the bed (use your fingers or a plastic card to avoid air bubbles)
make sure that the strips do not place on top of each other
- bed ok
- back panel ok
- x-axis ok
- hotend
- y-motors+led
Calibration
- config file to use (board)
your 3D-printer is connected and moves well
with the Pronterface console place the hotend over one bed spring and bring the bed to 0 (home Z)
the nozzle must touch the bed without puting pressure on it
if the nozzle is too high turn the wing nut clockwise
it will decompress the spring and make the bed goes up on this point
if the nozzle is too low (and put pressure on the bed) turn the wing nut counterclockwise: it will compress the spring and make the bed goes down on this point
repeat these operations over the second bed spring: bring the bed to 0...
... and adjust the srping until the nozzle touches lightly the bed
repeat these operations over the third spring
and chek if the bed level is still ok on the other points of the bed
- config file to use (software)
- then
- elec cover + fan (File:Fan404010.png + m3x16 + m3nut)
- side panels
- door
- celebrate
