Assembling and setting up the machine should take between 4h to 8h or two afternoons :)
If you preassemble everything, or if you disassemble your machine for a travel, it should take 1h to put it back together.
<videoflash>QuMhb-vMsfw</videoflash>
General tips
Read the whole manual once or twice before starting, to get an overview of the build
Know the parts
Firstly, have a look at all the part and learn what everything is.
top corner (at the rear left, you can embed a raspberryPi pcb webcam in it)
z-slider with space to embed the z-endstop
How to insert a T-nut
Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Base frame
x4 base-corner
x4 300mm profile
x4 m4x8
x4 m4 t-nut
x4 base corner assembly
x1 bottom-plate
x4 m4x8
x4 m4 t-nut
don't lock the nut firmly for the moment
press the sides and check that every corner is square, lock the 4 corners
Z-sliders
x3 z-slider
x1 z-slider for endstop
x4 300mm profile
x8 m4x8
x8 m4 t-nut
pay attention that each aluminium profile can be a little different, check that the printed part slide well on it, enventually file it
the slider holding the z-endstop will go at the rear left
put the t-nut in place first
then the aluminium profile, lock the nut
check that the z profiles are almost square to the base frame (it will be better once the top frame is in place)
x3 top corner
x1 top corner for z-endstop
x4 m4x8
x4 m4 t-nut
the top corner eventually holding the raspberryPi webcam will go at the rear left
x2 300mm profile
x2 m4x8
x2 m4 t-nut
Y-sliders
Y-slider left
Y-slider right
x2 nema14 stepper motor
x2 pulley
x8 m3x30 counter-sunk
x4 603zz bearing
The instruction show the left side, it will be the same (in mirror) for the right side.
add the pulley on the motof shaft (if you have this pulley you will need to invert it)
check the position of the pulley with the printed part then lock it with the grubscrew
x2 300mm profile
x2 360mm belt
x4 m4x8
x4 t-nut
the belt need to be well tightened before locking the second t-nut
x4 m4x8
x4 t-nut
Z-drive
x1 closed-belt
x4 m5 threaded rod 300mm
x8 m5 nut
x4 mr105zz bearing
x4 pulley
x8 m5 nylon nut
here is an overview, we will assemble one rod at a time while the cube is laying on the side, then turn it and make another rod
lock the m5 nut together at the end of the rod (using two flat spanner #8 or two pliers)
don't forget to add the belt before the pulley
adjust the nuts so that you have no play in Z (between the nuts and the printed part) while the rod still turn easily
move the z-slider toward the middle
now you can lock the pulley on the Z rod, there should be no play in Z, between the pulley and the printed parts, but it should also turn easily
repeat for each corner (turn the cube as it's easier to work on the laying side)
x1 nema 17
x6 623zz bearing
x2 m3x10
x2 m3x20
x1 m3x25
x8 washer
x4 large washer
x1 m3 nut
x1 m3 nut housing
add the pulley on the motor shaft
the pulley should be flush with the panel, lock the pulley
the motor's connector is facing upward (in direction of the rear side of the machine)
start with the two m3x10 and washers
then with the two m3x20 holding the bearings between washers
insert the m3 nut in the printed housing (use a bolt to pull it through if needed)
put the four Z-slider at the same height (e.g.: using the square)
now you can tension the belt (caution to keep the z-rod in place, they may turn while you pull on the belt)
check that everything moves well and that the four Z-sliders move in a synchronised way, eventually using the belt or by turning one of the Z-rod
it is not always needed, but if you think a rod could fall off from a z-slider (maybe you need to tighten a nut one face more) you may add a zip-tie to prevent it (or this printed part)
Bed
x1 m4 t-nut
x1 m4x10
x1 Z-plate
x4 m3x16
x4 m3 nut
check z-sliding by moving the belt
x1 microswitch
x2 ferule
heatshrink tubing
x1 2pin wire with connector
shorten the 1m wire to 25-30cm (and save the 70cm for the blower)
don't forget to add a 10mm of heatshrink tubing
pull gently to see if the crimping is ok
push the heatshrink tubing on the ferule
pass the wires first then push the endstop in place
x1 bed plate
x1 film heater
x3 m3 nut housing
x3 m3x35 countersunk head
x6 m3 nut
x3 spring
peel of the paper and stick the film heater on the plate
add the 3 countersunk m3x30
and lock them with m3 nut
- zip-tie wires
- cup-noodle
Rear Panel
x1 back panel
x1 plug
x1 switch
x2 m3x8
x2 m3 nut
place the switch on the back panel: position OFF downward
clip the switch on teh back panel
fix the plug with M3x8...
x3 6,35 ferule (+ insulation)
x4 4,8 ferule (+ insulation)
crimp a 6,35mm ferule on one side of the wire and a 4.8mm ferule on the other side (don't forget to add the insulations BEFORE you crimp the ferules!)
connect the switch (4,8mm ferule) and the plug (6,35mm ferule) with the red wire
connect the switch (4,8mm ferule) and the plug (6,35mm ferule) with the black wire
crimp a 6,35 ferule on the green wire
do it again with a 60mm red wire and a 4,8mm ferule
do it again with a 60mm black wire and a 4,8mm ferule
connect the switch and the plug with the 3 more wires
x1 power supply 150W
x2 m3x8
identify on the picture the 2 fixing points
place the power supply above the switch + plug
screw the lower part of the power supply on the back panel with a M3x8
rotate lightly the power supply through the left to make the wiring easier: L>red; N>black; Ground>green
replace the power supply verticaly and screw the upper part of the power supply on the back panel with a M3x8
x1 minitronics 1.1
x4 strut
x8 m3x8
screw the 4 struts on the 4 corners of the electronic board with 4 M3x8
place the electronic board on the back panel (USB port downward)
screw the electronic board on the back panel with 4 M3x8
connect the cables on the electronic board
connect the cables on the power supply
x1 extruder 17
x5 M4x8
x5 M4 T-nut
- wires AC in, DC out
- extruder
- board
- E wire, Z wire, DC in
- add back panel
- plug z-endstop, bed ntc, bed heat
X-axis
x1 nema14 stepper motor
x1 pulley
x4 m3x30 counter-sunk
x2 603zz bearing
- y-endstop
- x-endstop
- blower
- check movement
- prep Y-endstop
- prep X-endstop
- motor+pulley+bearings
- belt
- blower
Hotend
- hotend with hotend-holder
- tubing
- if good, wire NTC+Heat+Fan
- if self build, heat to tighten
- put in x-slider
- check movement, file if necessary
Wiring
- bed ok
- back panel ok
- x-axis ok
- hotend
- y-motors+led
Calibration
- config file to use (board)
- making the bed parallel
- config file to use (software)
- then
- elec cover + fan (File:Fan404010.png + m3x16 + m3nut)
- side panels
- door
- celebrate
