Mini J Head Nozzle
Revision as of 20:13, 6 June 2011 by Reifsnyderb (talk | contribs) (Parts List)
Mini J-Head Nozzle
Release status: Concept
Mini J-Head Nozzle, Thermal Barrier, and Mounting Plate based on the J Head Nozzle.
GPL
Introduction
NOTE: This page is under construction. More pictures, descriptions, etc., will become available when they are ready. The current pictures do not show a finished nozzle tip as it will be identical to previous designs. When these pictures were taken, it was a proof-of-concept for the thread sizes, internal dimensions, fitting of the parts, etc.
This nozzle has been designed as a drop-in replacement for the RepRap Universal Mini Extruder hot end.
Advantages
  • Internally, the filament path is identical to that of an already proven design.
  • If necessary, the PTFE liner can be replaced by using an off-the-shelf piece of PTFE tubing.
  • A resistor is used as a heater. There is no need to wrap nichrome wire.
  • Heat transmission is improved as there is no thermal junction where a separate heater screws onto the nozzle.
  • Since there are no press-fit parts, it is easier to disassemble.
Disadvantages
  • The brass nozzle requires considerable machining.
Parts List
Quantity Part Description
1 Brass Mini J-Head Nozzle Machined Brass Nozzle/Heater Combination
1 Thermal Barrier Machined PEEK Insulator
1 PTFE Liner 4mm OD, 2mm ID PTFE Tubing
1 Mounting Plate Insulator Internally Threaded PEEK Insulator
1 Mounting Plate
1 Heater Resistor Axial, 5.6 ohm, 1%, 5W (UB5C-5.6-ND)
1 Thermistor 100K (B57560G104F)
Machined Parts
Mini J-Head Nozzle
Material: Brass Bar Stock, 5/8" Square Or 5/8" x 1/2" Rectangular, ? Long
Note: The machining process can vary depending upon available machinery and tooling. The minimum machining requirements are a metal lathe with a 4-jaw independent chuck.
Thermal Barrier
Material: PEEK, 8mm Round
PTFE Liner
Material: PTFE tubing, 4mm OD, 2mm ID
  1. Cut an approximately 30 degree (or greater) taper on what will be the hot-end of the PTFE liner.
Mounting Plate Plate
Assembly
Notes
General
Testing
Future Modifications
Pictures
