Mendel Drawings
Revision as of 03:57, 24 April 2011 by Sebastien Bailard (talk | contribs) (Usage)
Usage
Rather than machining a Mendel, you may want to make a WolfStrap. Or a 1X2 or 1X2 Tallcat
Sells, Prusa
I think these are for Sells Mendel.  You're probably looking for the drawings for a Prusa Mendel. Which
is predominantly done in OpenSCAD, which may not generate mechanical drawings.
--Sebastien Bailard 07:57, 24 April 2011 (UTC)
Files
Imperial Measurements
File:Mendel Drawings.zip
All in a single PDF: File:Mendel Drawings - Single PDF.pdf
Note: Mendel_Drawings.zip contains a number of pdfs. These pdfs are engineering drawings of mendel parts, drafted in auto cad.
Units are in Imperial - Inches.
Import Drawings
The files in Mendel_Drawings.zip are a bunch of pdfs. It may be good to convert the pdfs to .png type image files (using image magick or pdftk?) and embed them in a series of pages. E.g. x_axis_belt_clamp.pdf is a pdf in the zip, we need x_axis_belt_clamp.png, and then either have Mendel/Drawings be one long image dump or have it be a list of pages like: Mendel/x_axis_belt_clamp --WikiSysop 07:31, 21 June 2010 (UTC)
Working Notes
To understand Mendel design, started to convert SolidEdge "part" files in "dxf" and "dwg" files.
Don't know if it's the proper place and i'm a total beginner about 3D and 2D design.
Please check what i'm doing and give me some advice. Check my english too...
Usability
How do we integrate a bunch of images with our formal set of files, which is buried here: https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/mendel/mechanics/solid-models/ And is there a good way for users to upload their changes to that system?
