Extruder
X Axis
Y Axis
Z Axis
Frame
Left Side
BOM
Name
Qty/assembly
Type
M8 Nut |
14 |
Fastener
M8 Washer |
14 |
Fastener
330mm M8 Threaded Rod |
3 |
Hardware
corner vertex |
3 |
Laser Cut Part
Z Leadscrew base |
1 |
Laser Cut Part
Z Motor Bracket |
1 |
Laser Cut Part
You will also need a measurement jig to get the distance between the corner vertices the same. I created a jig using one of the other bits if M8 rod, 4 nuts and 2 washers. I assembled the jig so that the outside of the two washers was 290mm apart. Then used it when tightening the nuts on the vertex pieces to ensure the spacing was right.
Right Side
BOM
Name
Qty/assembly
Type
M8 Nut |
14 |
Fastener
M8 Washer |
14 |
Fastener
3 |
Hardware
corner vertex |
3 |
Laser Cut Part
Z Leadscrew base |
1 |
Laser Cut Part
Z Tensioner Bracket |
1 |
Laser Cut Part
