Input & output files using POISSON suite
Revision as of 14:26, 9 April 2011 by Rapatan (talk | contribs) (Created page with ' Program name input files output files Automesh, XXXX.AM, XXXX.T36 OUTAUT.TXT, XXXX.T35, (TAPE36, TAPE37) …')
Table I-1. Files used in Poisson Superfish. Program Input files Output files Automesh, XXXX.AM, or XXXX.IN XXXX.T36 OUTAUT.TXT, XXXX.T35, (TAPE36, TAPE37) Autofish XXXX.AF, XXXX.T36, XXXX.SEG OUTAUT.TXT, OUTFIS.TXT, XXXX.T35, XXXX.SFO, XXXX.PMI, (TAPE36, TAPE37, TAPE40) Fish XXXX.T35 OUTFIS.TXT, FishScan.TBL , XXXX.T35, (TAPE40) CFish XXXX.T35 OUTFIS.TXT, FishScan.TBL , XXXX.T35, (TAPE40) Poisson XXXX.T35 OUTPOI.TXT, OUTPOI.TBL, XXXX.T35, XXXX.PO7, EFLD.QKP, BFLD.QKP Pandira XXXX.T35, OUTPAN.TXT, OUTPAN.TBL, XXXX.T35, XXXX.PA7, EFLD.QKP, BFLD.QKP, (TAPE40) SFO XXXX.SEG XXXX.T35 Transit.TBL, TBETA.TBL, XXXX.T35, XXXX.SFO, XXXX.PMI, TBETAnn.TBL SF7 XXXX.IN7, XXXX.T35 OUTSF7.TXT, XXXX.nn.TBL, XXXXnn.EGN, XXXXnn.T7 Force XXXX.FCE, XXXX.T35 OUTFOR.TXT WSFplot XXXX.T35, (WSFplot.PRF), CurveFile OUTWSF.TXT, WSFplot.PRF, numerous hardcopy graphics file types SegField Filename.SGF, Filename.SFO as named in SGF file Tablplot file named in the input SGF file SFOtable Filename.SFT, series of files Filename.SFO as named in SFT file Tablplot file named in the input SFT file SF8 Filename.IN8, two T35 solution files as named in IN8 file OUTSF8.TXT List35 XXXX.T35 XXXX.TXT Quikplot Filename.QKP numerous hardcopy graphics file types Tablplot Filename.TBL numerous hardcopy graphics file types ABCfish Filename00.ABC, where ABC stands for CCL, DTL, etc. Filename01.ABC, Filename00.LOG, plus files XXXX.AM, XXXX.T35, XXXX.SFO for each problem solved. May also include XXXX.PMI files.
