HuxleyZAxis
Revision as of 21:42, 15 January 2011 by Kymberlyaandrus (talk | contribs) (Adding the Z Smooth bars)
Image of a Huxley Z Axis, assembled from a TechZoneCommunications Huxley Kit
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
The Z Axis should be put in after the frame and Y axis have been squared, and trued. Information about how to do that can be found here. You should have tightened all nuts and used threadlock on them if you are going to (I recommend that you use threadlock). If you perform the following steps before squaring and trueing up the frame and Y axis, it will be in the way and will make that process more difficult.
Drive Rods
Photo of the parts used in Y 180 side
An assembled Huxley Z Drive Rod
On the left is a picture of the parts used to assemble and prepare the drive rods for the Z axis. On the right is an assembled and prepared Z Drive rod
    • (2) 6mm threaded rod (the las 2 in the set) they are about 215mm or 8-1/2" long
    • (2) Printed Drive Cogs (shown with nut already installed)
    • (2) 626zz bearings
    • (10) 6mm nuts
The following are shown in the picture but are not used until the next step (but I mised them in that picture...)
    • (6) 3mm X 20mm bolts
    • (6) 3mm Nylocs
    • (12) 3mm washers --ok... the picture only shows 6...
Heat a 6mm nut with a torch or something
Begin by putting a 6mm nut into the end of each of the printed cogs. I use a torch to heat the nut slightly (don't overheat it) just like we did for the Z Nut Retainers on the X Axis. I thread the nut onto the end of the threaded rod to heat it (don't burn you fingers!).
Assemble the bearings and nuts onto each rod
Next, assemble the Drive rod with a 6mm nut, the bearing, then three more 6mm nuts, followed by the cog. Place them all on the end of the rod until the rod is flush with the nut in the drive cog as shown on the right.
Remove the cog from the end of the rod
For now, we remove the drive cog from the drive rod. At this time I rcommend that you put a small amount of threadlock on the top nut and on the bottom nuts. Be careful not to get threadlock into the bearing, since threadlock can ruin the bearing.
Install the X Axis onto the Z drive rods
Photo of the parts used to Install the X Axis
Photo of an installed X Axis
You will need the Huxley, the assembled X Axis, the two threaded drive rods from above and the printed drive cogs, along with the 3mm bolts, nuts and washers listed in the step above.
Turn the machine upside down to install the X Axis
We start by turning the Huxley upside down (or almost upside down) as shown in the picture on the right.
Then Place the X Axis into the space where it will be, put the top of the X Axis towards the top of the Huxley. The smooth side of the X Axis Carriage is the top of the X Axis. You want to put the motor end on the correct side of the machine. I build mine with a backwards X Axis, so that the motors of my Huxley are all clsoe together. I do NOT recommend this for your first machine, since it then requires that you mirror all you parts in order to get them to print corectly. -- I am building a website based toolchain, which will have this ability for you in the near future, but until then it is a fairly advanced thing to mirror the parts for printing; It is just easier to use if you put your X axis motor above your Z Axis driven unit, rahter than above your Z Axis Combo unit.
Add the drive rods
Put the Drive Rods through the Z driven unit, and the Z Combo unit and thread them into the nuts in the Z Nut Retainers on the X Axis, I threat them until they are about two inches I also try to get them nearly even (it makes squaring easier if I get them close now). The picture on the right shows the Drive rod in place on the Combo unit and the drive rod for the driven unit is being put into place.
Add the drive rods
Align the bearings into the spaces in the Z Combo unit and the Z driven unit. Then use 3 of the 3mm X 20mm bolts on each side with nuts and washers, go ahead and make these fairly snug.
Add the drive Cogs
Finally put the drive cogs back onto the end of the rods. Add a drop of threadlock if you wish (I recommend it).
When you are done with this step, your huxley should look something like the top right picture of this section.
Photo of the parts used for the Z Smooth Bar
Photo of the Z Smooth Bar Assembled
To install the Z smooth bars you will need your Huxley (duh), and the following parts:
    • (2) Z Axis Smooth bars (last two in the kit) aproximately 225mm long (8-3/4")
    • (4) Z Smooth bar clamps --printed parts
    • (10) 6mm nuts
    • (10) 6mm washers
    • (4) 3mm X 20mm bolts
    • (4) 3mm nyloc nuts
    • (8) 3mm washers
Aligning the Z Axis
Aligning the Z Axis
