HuxleyYAxis
Revision as of 02:38, 16 January 2011 by Kymberlyaandrus (talk | contribs) (Install the Axis)
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Whene assembling the Y Axis, it is OK to actually tighten the bolts/nuts since it is all aligned by the frog plate and later installation into the frame.
Y 180
Photo of the parts used in Y 180 side
On the left is a picture of the parts used to make the Y Axis 180 side. See the image below on assembling the Y Axis to view the assembled Y 180 parts.
Insert the Nut(s) into the pockets of each piece
Y 360
Photo of the parts used in the Y Axis 360 side
Photo of an assembled Y 360
Connecting to Frog Plate
Photo of the parts used to Assemble the Y axis
Photo of an assembled Y Axis
Install the Axis
Photo of the parts used to install the build platform
Photo of an Installed Axis
Instalation of the build platform itself will come later... after the motors, belts and endstops.
You are now ready to install the Axis, you'll want to insert the 2 smooth rods you'll use into the front smooth bar clamps, then slide them through the bearing assemblies on the Y axis and the rear smooth bar clamps. You may need to move the Smooth bar clamps in order to get the rods though. The smooth bars should sit nicely in both the front and back smooth bar clamps. Go back to the frame adjustment information and follow the instructions there to tighten the smooth bar clamps into place. Threadlock is probably a good idea on the nuts holding the smooth bar clamps in place... once they are all adjusted.
Alignment of these bars is included with the Frame squaring and adjustment information here.
