HuxleyXAxis
Revision as of 04:43, 30 December 2010 by Kymberlyaandrus (talk | contribs) (X Carriage)
Image of a Huxley X Axis, assembled from a TechZoneCommunications Huxley Kit
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Whene assembling the X Axis, assemble the parts just finger tight, and into aproximate areas. When it is all together, we will fix things by measurements, and tighten them up.
X Carriage
Photo of the parts used in X Carriage
Photo of an assembled X Carriage
On the left is a picture of the parts used to make the X axis carriage (some people call it a shuttle) It is shown assembled on the right:
    • (1) X Carriage - from the printed parts set
    • (1) 180 side of the X Carriage - from the printed parts set
    • (1) 360 side of the X Carriage/Bushing Clamp - from the printed parts set
    • (1) Graphite filled Bronze bushing
    • (6) 3mmX30mm bolts
    • (4) 3mmX20mm bolts
    • (16) 3mm washers
    • (10) 3mm nyloc nuts
    • (4) 623zz bearings
Here is how I stacked the bearings for the 180 degree side of the carriage.
We start this by installing the four bearings that hold the carriage onto the 180 degree restraint bar. The bolts go through the plastic part first (with a washer under the bolt head) then through another washer - or two - followed by a bearing and then the nyloc nut. you don't need another washer between the nut and the bearing. A close-up photo of the bearing stack can be seen on the right.
Photo of the 180 and 360 degree side of the X Carriage
Here you can see the bearings installed on the printed parts, and the bushing sitting in the groove where it will spend the rest of its existence. I simply place the bearing near the center, I don't get out a measuring device and make sure it is exactly in the middle, just eyeball it to close.
Do Not over-tighten the clamp on the busing
With the bushing in place, I fasten the bushing clamp or X Carriage 360 side onto the carriage, I usually put a smooth bar through the bushing before I put ANY torque onto the bolts which hold it together. Be careful to NOT overtighten this, or it will deform the bushing and it will never slide well.
The Image here shows the 180 Degree bearing piece already installed to the Carriage, use (2) 30mm bolts with nuts and washer to do this, the head of the bolt goes to the bottom and the nut goes on top of the carriage (top of the carriage is the smooth side). These two bolts should allow you to adjust the tension with which the bearings ride on the smooth bar, but it is easiest to make this adjustment after the axis is all assembles, so leave them fairly loose for now.
Use a drill to spin the bar in the bushing to seat the bushing and allow it to move freely
While We are here, it is a convenient time to "Seat" the bushing. The bushing provided by TechZone in the kit is a graphite bronze bushing. Due to manufacturing imperfections and variations, you probably need to "Seat" the bushing. I do this by putting the smooth bar into a drill chuck and spinning it while moving the carriage up and down the bar, I do this until the carriage slides easily and freely.
There is an added bennefit of doing this in this way, as the bronze wears slightly, it lays graphite down on the stainless steel rod. You will want to make sure to use the same rod in your final assembly (I usually just set it aside the way it is and don't take the rod out of the bushing again.
I also recommend that you add a drop or two of your favorite machine oil, like sewing machine oil, or bicycle chain oil to the shaft, after you have seated the bushing.
Z180 Degree and X Axis Idler
Photo of the parts used in the Z 180 portion of the X Axis and the X Axis Idler
Photo of an assembled Z 180and X Axis Idler
Z Nut Retainers
Z Nut Retainers and bolts
Photo of a prepared Z Nut Retainer
The following parts are used to assemble and prepare the Z Nut Retainers Assembled version is shown on the right. (4) Z Nut Retainers (8) 3mm X 20mm bolts (16) 3mm washers (8) 3mm nyloc nuts (2) 6mm nuts
Heat a 6mm nut with a torch or something
The first thing we need to do is to make sure that the 6mm nut will fit into the space provided for it. It is usually tight and need to be carved out larger, you can do this with a knife, but I have found that it is easier to heat a nut up and then press it into the space as shown on the right. I use a standard plumbing torch to heat the nut on the end of a piece of the threaded Rod. Don't get the nut too hot, it only need to be about 130 degrees celcius to do this well.
You could also use a soldering iron, hot plate, or oven to heat the nut. Or, as stated earlier, you can use a knife to carve the space to fit.
Press the Hot Nut into the space on the Nut Retainer to make a better fit
I press the nut it while it is warm - as shown on the right, once it is in about half way (a little less really) I take it back out and perform the same operation on the other three Printed Nut Retainers.
Once they are all prepared you use the eight 20mm bolts and put two of them together with one of the nuts in between. Don't tighten it down yet, we want to be able to slip the smooth bar into the spaces there, without very much effort.
Z360 Degree portion
Photo of the parts used in the Z 360 portion of the X Carriage
Photo of an assembled Z 360
Photo of a Z 360 piece with the center bearing
Photo of a Z 360 piece with bearings
Notice that the head of the bolt fits into a small recess when attaching the Z Nut Retainer to the 360 piece
X Axis Motor Mount
Photo of the parts used for the X Axis Ideler
Photo of an assembled X Axis Motor Mount
Here is how I stacked the bearings and washers
Put them together
Photo of the parts used finish the Assembly of the X Axis
Photo of an assembled Frame
Squaring, and truing the size/shape
