Haeckel
Revision as of 10:34, 21 January 2014 by Mattgolt (talk | contribs)
Haeckel Documentation
Haeckel
Haeckel is a variation of MendelMax.
Introduction
The RepRap Haeckel is an open source 3D printer that uses fused deposition modeling (FDM).
Ernst Heinrich Philipp August Haeckel (* 16. February 1834, † 9. August 1919) was a German biologist who promoted and popularized Charles Darwin's work in Germany.
The Reprap Haeckel is based on a generic Mendel. Its goal is to be a self contained unit, that can easily be upgrade to have a Heated Build Chamber. The idea is to have a very rigid frame and x assembly that can withstand light milling, such as PCB Milling or wood engraving. The Haeckel has two integrated spool holder, each holds up to 4 filament spools (9cm wide each).
Specifications
  • Printed Parts:
  • Non-Printed Parts:
  • Material Cost: 500€~
  • Cost: not for sale, yet
  • Printing Size: 200mm x 200mm x 350mm (can be extended)
  • Precision: ??? (position), ??? (printing)
  • Speed: ??? (position), ??? (printing)
  • Footprint: 470mm x 470mm x 570mm
Frame Parts
Quantity Length Part Type Used Where Comment Looks like
2 550mm 20x20mm aluminum extrusion back struts. The spool holders get attached to these, depending on your filament spool diameter, you might want to use longer back struts.
2 420mm 20x20mm aluminum extrusion front struts
12 430mm 20x20mm aluminum extrusion rest of the frame
2 270mm 20x20mm aluminum extrusion spool holders. can be extended or shortened
2 90mm 20x20mm aluminum extrusion Needed for x end and x idler. Soon to be available fully printed. Minimum length is 90mm. Can be up to 410mm (not recommended).
unfinished x assembly
Smooth rods
Part Used Where Quantity Length. Comment Looks like
X-smooth rods 2 370mm Can without problems be longer than recommended minimum lengths. Length shouldnt exceed 390mm.
Y smooth rods
Y-smooth rods 2 430mm These lengths can not be longer. 5mm shorter will still be okay, but 1mm longer can not be mounted
Y smooth rods
Z-smooth rods 4 370mm Can without problems be longer than recommended minimum lengths.Length shouldnt exceed 390mm
Z smooth rods
Printed parts
Quantity Part Name Used Where Comment Looks like File Download
2
90_innerCorner.stl
4
CornerPiece_small.stl
These needed to be cut to size on the original build as they were falsely planned. There is an updated .stl for the small version now. You need to have small corners on the lower corners, or the lower extrusions won't have the correct distance of 50mm. Foto CornerPiece small.jpg
2
CornerPiece.stl
1
Y_motor_mount.stl
4
Extrusion_three_way_connector.stl
Front Frame Assembly
This chapter shows how to assemble the front rectangle of the Haeckel's frame. You'll need:
  • 2x 420mm Extrusions
  • 3x 430mm Extrusions
  • 1x y_motor_mount.stl
  • 2x y_rod_clamp.stl
  • 2x three_way_connector
  • 2x corner_small.stl
  • 2x corner.stl
1. Overview
2. Begin by sliding a three way connector on a 420mm extrusion
3. Slide the connector down and tighten it
4. Take a small corner and attach it
5. Take a second small corner and attach it to the other side. Repeat Steps 2 - 5. You should now have two of these front struts.
6. Attach one 430mm Extrusion to one of the three way connectors. Attach Y-Motor mount and two bar clamps as pictured.
7. Attach the other strut to the horizontal bar. Make sure the Motormount and bar clamps are correctly attached. You will not be able to insert nuts into the t-slot afterwards
8. Take two 430mm extrusions and attach them to the top and bottom corners. The motor mount gets attatched to the bottom extrusion
9. Make sure the frame is rectangular. The measurements can differ by the type of extrusion you are using. This measurement is 470mm and needs to be exact on all points
3. The distance between the lower extrusions needs to be 50mm (center to center). For 20mm wide extrusions its 70mm (outside to outside)
3. The front side of the Haeckel is now done and square
Printer at work
<videoflash>ZgHDDmB_RSs</videoflash>
