Haeckel
Revision as of 15:57, 28 November 2013 by Mattgolt (talk | contribs)
Haeckel Documentation
Haeckel
Haeckel is a variation of MendelMax.
Introduction
Ernst Heinrich Philipp August Haeckel (* 16. February 1834, † 9. August 1919) was a German biologist who promoted and popularized Charles Darwin's work in Germany.
The Reprap Haeckel is based on a generic Mendel. Its goal is to be a self contained unit, that can easily be upgrade to have a Heated Build Chamber. The idea is to have a very rigid cubic frame that can withstand light milling, such as PCB Milling or wood engraving. The Haeckel has two integrated spool holder, each holds up to 4 filament spools (9cm wide each).
Specifications
  • Printed Parts:
  • Non-Printed Parts:
  • Material Cost: 500€~
  • Cost: not for sale, yet
  • Printing Size: 200mm x 200mm x 350mm (can be extended)
  • Precision: ??? (position), ??? (printing)
  • Speed: ??? (position), ??? (printing)
  • Footprint: 470mm x 470mm x 570mm
Frame Parts
Quantity Length Part Type Used Where Comment Looks like
2 55mm 20x20mm aluminum extrusion back struts
2 420mm 20x20mm aluminum extrusion front struts
12 430mm 20x20mm aluminum extrusion
rest of the frame
Smooth rods
Part Used Where Quantity Length. Comment Looks like
X-smooth rods 2 370mm Can without problems be longer than recommended minimum lengths. Length shouldnt exceed 390mm.
Y smooth rods
Y-smooth rods
Smooth rods
2 430mm These lengths can not be longer. 5mm shorter will still be okay, but 1mm can not be mounted
Y smooth rods
Z-smooth rods 2 370mm Can without problems be longer than recommended minimum lengths.Length shouldnt exceed 390mm
Z smooth rods
Printed parts
Quantity Part Name Used Where Comment Looks like File Download
2
90_innerCorner_stl
2
90_innerCorner_stl
2
90_innerCorner_stl
2
90_innerCorner_stl
File:Foto Y motor mount.jpg
2
90_innerCorner_stl
