Generation 3 Electronics/Tech Zone Remix/Installation
Overview
This page will attempt to provide information on how to connect all the electroncis together, and make sure they are performing as they should.
General information
Making the Cables (I know, they are a pain...)
Hooking up the Main board
Hooking up a Stepper Controller
On the top left, is a photo of the stepper controller, with all the wires hooke up to it.
The ten pin connector connects to the correct location on the mainboard (X, Y, or Z) as you make that cable, make sure that both ends have the color coded portion the same direction, if you put your cable together with the red stripe at the opposite end of the connector from what I have, then your cable will appear to be reversed from mine. This is OK as long as both ends are done the same.
The three pin connector is connected to the opto endstop, in this photo, it is connected to the min the other three pins are for a max endstop if you want to hook one up the red end of this cable is connected to the 5v+ on the actual endstop, that pin should be mated to the pin furthest from the led, the led is the little white thing on the bottom left of the opto endstop in the photo (as in the third picture on the right)
The top photo on the right shows the power connection. The yellow wire in this photo is the 12v+ and the black wire is the 12v- the terminal blocks should be labled.
The second photo down on both the left and right shows the connection of the motor wires. The left photo shows the blue, red, green, and black and the right photo shows another colored set. If your motor is going the opposite direction from what you expect, then swap them by 180 degrees, for example switch blue and black with each other and switch red and green with each other.
Connecting the Extruder Controller
There are several wires that hook into the extruder controller. The photos and descriptions below have most of the wires not featured in the photo removed, for clarity. You will need to hook all the wires up, before it will work completely.
Connecting Power, motors, and Other Loads the the Extruder Controller
The screw terminal blocks, should be labeled, and fairly self explanatory, but I know that Photos are far more effective than words (or in this case labels).
The top picture on the left is a photo of all the wires going into the screw terminals (all other wires have been removed for clarity). On the right, the power wires are connected, as are the two wires leads for the heater on the extruder tip. The power wires are polarized and the 12v + should be connected to the second position (yellow in this photo) and the 12v- (or ground) should be connected to the first position (black in this photo).The heater leads are red and orange in this photo, but it does not matter the color, or order of these wires. They are connected to the C position on the terminal blocks.
A and B positions on these terminal blocks can be programmed for other loads, such as a cooling fan, or a heated bed.
The second photo on the left is of the motor wires. I have used the most common color of wires, but your may be different. If the motor direction is reversed from what you expect, then simply flip all the wires 180 degrees, by swapping blue with black, and red with green.
The second photo on the right is just like the photo on the left, but with a different colored set of wires
Connecting the Main board to the Extruder Controller
The main board is connected to the Extruder board with two separate wires. The first wire (shown as the bottom wire in the photo) is the RS485 communications wire, the main board communicates over this wire to the extruder, to give it commands, and to receive information back (like the temperature of the Hot End). The second wire is only needed if you are using a stepper motor with your extruder. It uses the I2C communications port off of the main board and the D9/D10 pins on the extruder Controller. This cable carries the step and direction information for the extruder's stepper motor.A little background: These two boards are connected together with 2 wires, in most of the modern implementations of the RepRap, but the original design only used the RS485, and expected you to use a variable speed DC motor. When the extruder evolved to use stepper motors, someone figured out how to make all of that work (with timings, PWM and other technical stuff I am not going into on this page), but it requires the second connection to pass the working information to the extruder, this is required, because the RS485 communications protocols are not "Fast" enough to deal with the information needed for the stepper motor
The photo on the right is just a close up of the same wires.
Also of interest in this photo, he made a belt tensioner for the X axis, you can see it near the bottom right of the photo.
A few different ways to connect Temperature sensors
There are several ways to detect the temperature of the hot end of the extruder, below we have shown a couple of them. Use the one that fits your configuration
Connecting in the TechZone Thermocouple A/D converter
This converter is in a pre-release format, and is a variation of the adapter found on the Thermocouple_Sensor_1_0 page, but we have changed the firmware so that you do not need to remove the capacitor as shown in the instructions under that link. (Read that page for background, history, inspiration, whatever, but follow these directions if you received your A/D converter from TechZoneCommunications)
For information on the Firmware, and to download the firmware file, see TechZone_Thermocouple_Firmware page.(coming soon)
The four pin connector is connected to the four pins on the mainboard as shown in the photo on the left and the single wire is connected into one of the ten pins in the old quadrature connector as shown on the right.
Before turning on the heater, you need to make sure the thermocouple is connected with the correct polarity. To do this, load the RepRap host software and go to the extruder tab. It should be providing you with a temperature reading. If you put your finger on the tip of the extruder for a minute, you should see that temperature go up. If it goes down, then you have the polarity of the thermocouple reversed and you need to swap the wires.
The Photo on the right of this text, shows the connection of the heater lead wires to the Extruder Controller. it is the second set of wires from the right side of the 8 terminal block. This picture shows them as red and orange wires. They are not polarized (you can switch them places and it won't matter). I recommend not hooking these two wires up until you are ready to heat up your extruder tip. That should happen after you test all other aspects of your extruder and know that it works.
Here are some more photos to help with the details (a picture is better than any words I can create)
Using a standard thermistor
The leads from your thermistor can be connected to the two pins, as shown in the photo. Polarity does not matter on this connection.
Connecting a Stepper Controller to Drive the Extruder Stepper Motor
Having hooked a stepper controller up to the extruder motor, and run it that way, I will never go back! It runs much more quietly, and seems to behave much better. I think that the reason for this is that the Extruder Controller is not designed to run a stepper motor, but has been "hacked" to run the stepper motor. Whereas, the Stepper controller is designed to run the stepper motor from the get-go. I found a description about how to do this somewhere (and I thought it was on the Wiki), but could not find it again to share with several of the TechZone customers who were interested in trying this... so I have created this section.
The process of connecting the Stepper controller to the Extruder stepper motor is fairly easy. Instead of hooking the SCA/SCL pins from the mainboard to the D9/D10 pins on the extruder board, you hook them to the step and direction pins on the Stepper Controller, as shown on the photos on the left and right (on the left, it is the cable that comes up too close and goes out of focus). You also need to get 5v to the enable pin on the stepper controller. I do this with a jumper wire from the max 5v output to the enable pin on the controller, it is the yellow wire in the photos.Polarity on the 2 pin wire is important, but if you hook it up backwards, it just won't turn the motor as it should and you can reverse the wire.
Connecting the power and the motor wires to the stepper controller is the same as it is on all of the Axis stepper controllers.
You can take a stepper motor from one of your axis, temporarily, and connect it in this way, to see how different your extruder performs. I think you will be pleasantly surprised.
Sorry for the less than clear photos, I will take some new pictures when I get my good camera back.
