GSI Cut
Revision as of 20:11, 20 February 2013 by Marinosaurus (talk | contribs)
FoldaRap Documentation
cut id
Release status: develloping
a tranfolding reprap
LaserCut
throw a school projet we want to devellope an transportable laser cut. We batse our work the foldarap because we work in the same labo as Emmanuel
Specifications
  • Printed Parts: 20-21
  • Non-Printed Parts: Laser tube, Power laser, optical part, laser water cooling, air boost,
  • Cost: 400 €
  • Cutting Size: 200mm x 200mm
  • Resolution : a voir ?? mm and ?? mm
  • Speed: ?? mm/s
Special Features
  • Mobile!
  • Based on standard/cheap 20x20mm aluminium extrusion (with 6mm slot)
  • Easy to build, with few tools (the printed parts are based on a 20mm grid (for overall aesthetic and mostly to ease the design), are generally 3-4mm thick, and fit the beams in a way you have nothing to measure during the assembly
  • Whith a real CO2 laser tube
  • Little (the entire machine is going to be about 30*30*30)
  • Big RED Power Security (my favorite detail ^^)
  • Cut surface about 200 x 200 mm
  • Easy to place on the material (it the machine witch go on the material, not the material witch go inside the small machine)
R&D
[Forum]
Inspiration
Some details that I found interesting or related or want to integrate to this idea of a foldable machine...
External links, media/press, etc.
We like feedback from the community:
  1. [1] mention to be doing this project.
History
  • 2013/02: beggening
