FoldaRap Buyers Guide
Revision as of 10:24, 7 December 2013 by Iggcel (talk | contribs) (物料清单 (BOM))
FoldaRap Documentation
This project was for myself, as I need/want a RepRap that's easy to carry around and for the challenge of making a folding 3d-printer. But I believe in open-source and sharing and all the revolution behind that. Thus I try to well document it, in case others want to make one; to acknowledge all the things we own to those who went before, and to encourage those who come after to do the same.
On a more long-term view, I don't plan to create a company out of it, I'd better hope to see it grow on itself in the wild, just by indicating how to source it. I have more fun in designing stuff than marketing it, nonetheless I may try to sell few beta-test kits (bulk ordering is good for prices), eventually via a crowdsourcing campaign or by request, maybe with the help of my hackerspace. Just for the experience of it and to say I can push a project to that point :D (edit : done !)
(almost all the projects I did during my design studies could have done something, but I never found the time for that and they ended sleeping in their drawing books which is sad; while now I have taken the habit to publish everything, even an old one sometimes).
"Ideas are like living things and breed happily in an open-source context" as I like to think ^^ (on the same spirit I like this comment from User:Adrianbowyer)
Bill Of Material (BOM)
物料清单 (BOM)
Total end cost for 1 machine : ~500-600€ when you include all taxes and shipping costs. I suggest you to make group orders with friends and always try to source locally.
一台机器的总成本:包含所有的税收与运费在500至600欧元。 我建议你与朋友团购或在本地采购。
Hardware
硬件
(PS:因各国对材料的型表表示不同,本人非专业,材料建议自己看英文理解) Foldarap hardware-kit.jpg
5  20x20mm beam 6mm slot 200mm - Motedis or see Aluminium_profile_Suppliers
5 根 20x20mm梁 6mm槽 200mm长 铝材
6  20x20mm beam 6mm slot 300mm
6 根 20x20mm梁 6mm槽 300mm长 铝材
50 M4 T-nut for 6mm slot - Motedis
50 对 用于6mm槽的M4四角螺母
(=31€)
50 M4x8 round head bolt - Fix'n Vis Round Head Bolt
2  M3x4 / Hotend-heatsink(2) Fix'n Vis Bolts
13 M3x8 bolt / Z-motors (4), Y-motor (3), X-end-idler (2), psu (2), male plug (2)
2  M3x10 bolt / Hotend-heatsink (2)
6  M3x12 bolt / X-idler (1), extruder-idler (3), Y-belt-clamp (2)
4  M3x16 bolt / X-motor (3), extruder-fan (1)
7  M3x20 bolt / X-carriage (3), hinges axis (2), Y-idler (1), extruder-idler (1)
3  M3x30 countersunk bolt / bed leveling (3)
2  M3x35 / extruder spring (2)
19 M3 nut / hinges (2), X-carriage (3), X-idler (2), extru-fan (1), Bed (3), Y-belt-clamp (2), extru-idler (2), plug (2), psu (2) - Fix'n Vis Nuts
3  M3 nylock nut / bed leveling (3) nylock nut
5  M5 nut / extruder-idler pneumatic fitting (1),z-rod (4) (for the Z nylon nuts can be slightly better)
11 M3 washer / X-motor (3), X-idler (2), extruder-idler (2), Y-idler (2), Y-belt-clamp (2) - Fix'n Vis washer
2  230mm threaded rod M5 - Fix'n Vis
(=9€)
2  extruder spring - RS751483 or see Springs
3  bed spring - RS 751455 or RS 751607
1m spiral wrapping band for tidying the wires - RS227874
7  faston ferule - Radiospare to crimp the cable for the plug and the switch
(=15€)
2  polymer coupling - See this thread (ebay / emakershop)
6  linear bearing, LM6UU or if you can Igus RJMP-01-06 - See Bearing
4  300mm smooth rod 6mm - (can be salvaged from usual scanners and printers) or see Smooth rod
4  603zz bearings / X-idler (1), Y-idler (2), extruder-idler (1)  - See Bearing
1  600mm T2.5 belt 5-6mm wide - RepRapWorld or see Belts_and_Pulleys
1  700mm T2.5 belt 5-6mm wide
2  T2.5 pulleys - Paoparts or see Belts_and_Pulleys
1  PTFE Tubing for bowden extruder (2mm inner diam. and 3mm outer), 300mm long - See Bowden
2  Pneumatic fittings for 3mm tubing, with M5 thread - See Bowden or emakershop / I'm using the MA12-03-M5 but others can work
1  direct drive gear - Maritime-models (see Drive-gear)
1  bed plate 4mm thick - Paoparts
1  roll of kapton - See Kapton Tape#Vendors
20-30 zip-ties
Electronic
5 nema14 stepper motors - [1]
1 usb to mini-usb cable - [2]
3 miniature microswitch endstop 20mm - [3]
1 standard male plug IEC C13 C14 - RS 5392045
1 standard female cable - EU/C13 - UK RS6266739 / US RS7316163
1 big blue switch - RS 5287858
1 RepRappro Hotend - emaker
1 40x40mm heatsink - RS 6744769 to make a more compact hotend
1-2 small fan (40 x 40 x 10 mm), for the hotend (can be bought with one) and the extruder motor - RepRapWorld or see Fan
1 100k thermistors - Mouser
1 m of 18AWG wire (350mm red, 300m black, 150mm green) for the switch/plug/psu - Read also WiresAndConnectors
1,5 m of 22AWG (red or black) for the hotend heater (not needed if you buy a cartridge heater, they usually come with 100cm wires)
10 m of 26AWG (3.6m red, 3.2m green, 2.0m blue) for the sensors and fans
1 Melzi board [4]
1 12V power supply : 5A or 10A (for heated bed)
or
1 Azteeg_X1 board - [5]
4 stepper drivers
1 12V power supply : 10A or 20A (RS 7066316 100*150*35mm)
Laser cut parts
See the github repo and eMakerShop, you can have them from Ponoko too
1 electronic under-plate 3-4mm thick
1 bed-plate 4-6mm thick (acrylic or aluminium)
1 Y-carriage
1 reprap.org plate 160x20mm, 2-4mm thick (+2 T-nut and M4x8) - optional but make a nice reference to the wiki :)
These parts can also be made by hand with simple tools.
Printed parts (total : 21)
See also the github repo
foot front left
foot front right
foot rear left
foot rear right
hinge-inner left
hinge-inner right
hinge-outer left
hinge-outer right
z-motor-bracket left
z-motor-bracket right
z-top left
z-top right
y-motor
y-idler
y-belt clamp
x-end-motor
x-end-idler
x-carriage
extruder-idler
board mount (x2)
Other
Heated-Bed
For the aluminium heated bed add :
1 aluminium bed plate (4mm thick)
60cm of 26 AWG wire (blue)
2 ferule 0,5mm²
1 peltier element 12708 (40x40mm is enough) - ebay
Padded suitcase
How to replicate a FoldaRap !
If you can print your own parts it will take ~400gr and 22h at ~30% infill
Material
I'd recommend PLA over ABS.
It's maybe only required for the parts that act as sliders on the aluminium extrusions (x-motor, x-idler), but there is still some big parts (the feet).
Recommended settings
Infill : 30-35% hexagonal or rectilinear or any dense pattern you like.
Foldarap precision-needed.jpgReprapworld-black-print2.jpgReprapworld-black-print.jpg
I recorded this little video where I'm playing with some parts freshly printed, to show what to expect about the tight tolerances.
<videoflash>rRXyc5I8yfo</videoflash>
The part that slide under it's own weight (16gr) have been slided back and forth a few time.
Fully assembled machines
Not yet.
Partial or complete kit
Webshops
Printed parts
Misc.
  • A draft BOM is on Kitbom
  • My spreadsheet is roughly the same as the following lists but a little outdated.
FoldaRapMendel Bom
1 underplate
5 300mm
7 400mm
50 M4x8
8 M4x12 (hinges)
2 M4x16 (hinges)
