Revision as of 01:43, 11 April 2010 by MattMoses (talk | contribs) (Third attempt. This one worked well enough to test. Solidified wax forms a film on the inside of the case. This design uses a nested drain and vent. The cutting tip exits to the left in the picture. The vent exits to the right. An eight-ohm heater i)
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 1,024 × 768 pixels.
Original file (1,024 × 768 pixels, file size: 113 KB, MIME type: image/jpeg)
Third attempt. This one worked well enough to test. Solidified wax forms a film on the inside of the case. This design uses a nested drain and vent. The cutting tip exits to the left in the picture. The vent exits to the right. An eight-ohm heater is wound around the drain tube inside the case. Drain tube is 5/32 inch (about 4mm) outside diameter.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:43, 11 April 2010 | 1,024 × 768 (113 KB) | MattMoses (talk | contribs) | Third attempt. This one worked well enough to test. Solidified wax forms a film on the inside of the case. This design uses a nested drain and vent. The cutting tip exits to the left in the picture. The vent exits to the right. An eight-ohm heater i |
- You cannot overwrite this file.
File usage
The following page links to this file:
