Revision as of 01:28, 1 May 2012 by Darkpaw (talk | contribs) (Position data from the "camrap" software. The camera wasn't moved during this run, so this data is a result of: camera noise, lighting changes, vibration and other errors. The values are in 4mm = 1 unit.)
Original file(1,066 × 407 pixels, file size: 50 KB, MIME type: image/png)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current01:28, 1 May 2012Thumbnail for version as of 01:28, 1 May 20121,066 × 407 (50 KB)Darkpaw (talk | contribs)Position data from the "camrap" software. The camera wasn't moved during this run, so this data is a result of: camera noise, lighting changes, vibration and other errors. The values are in 4mm = 1 unit.
  • You cannot overwrite this file.
The following page links to this file:
Metadata
