File:Routerized cupcake gcode.zip
Revision as of 15:28, 20 July 2011 by Lanthan (talk | contribs) (Routerized cupcake (gcode files for a 4060 router cutting 6.7 mm plywood))
Routerized_cupcake_gcode.zip(file size: 54 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current15:28, 20 July 2011 (54 KB)Lanthan (talk | contribs)Routerized cupcake (gcode files for a 4060 router cutting 6.7 mm plywood)
  • You cannot overwrite this file.
The following page links to this file:
