File:Caveat inertial mass.jpg
Revision as of 06:26, 3 August 2011 by Lanthan (talk | contribs) (These gears were both printed from exactly the same gcode, "all other things equal", at 25 mm/s. The one on the left shows obvious lost steps on the y axis. The only difference was the addition of an 10x110mm aluminium plate (pictured above) to have a ful)
Original file(1,280 × 960 pixels, file size: 394 KB, MIME type: image/jpeg)
These gears were both printed from exactly the same gcode, "all other things equal", at 25 mm/s. The one on the left shows obvious lost steps on the y axis. The only difference was the addition of an 10x110mm aluminium plate (pictured above) to have a full build platform. The additional swinging mass proved too much for the wimpy y-axis stepper.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current06:26, 3 August 2011Thumbnail for version as of 06:26, 3 August 20111,280 × 960 (394 KB)Lanthan (talk | contribs)These gears were both printed from exactly the same gcode, "all other things equal", at 25 mm/s. The one on the left shows obvious lost steps on the y axis. The only difference was the addition of an 10x110mm aluminium plate (pictured above) to have a ful
  • You cannot overwrite this file.
The following page links to this file:
Metadata
