EZStruder
Revision as of 19:21, 7 May 2013 by Partdaddy (talk | contribs)
EZStruder
Release status: Experimental
EZStruder Cold End
See BOM for links to files
EZStruder by SeeMeCNC.com
Details
The EZStruder is a compact and versatile Cold End drive by SeeMeCNC. A design by PartDaddy & John Oly of SeeMeCNC. The EZStruder Cold End is manufactured by classic thermoplastic injection molding and CNC machining processes. The Cold End design is based on many RepRap style drives, such as "Minimalistic Mk8 replacement" by whosawhatis, 10-JAN-2012, Thingiverse. The spring and filament are caged between the drive lever and motor mounting plate, where as many previous designs pass the filament through the lever. Development advice and credits to Shane Graber and Brian VanDiepenbos.
The EZStruder will work with any RepRap groove-mount style Hot End and Prusa Hot Ends. And it is compatible with either 1.75 or 3mm filament. And conveniently used for 1.75mm bowden setups with an INCLUDED bowden adapter.
BOM and Files
File:EZStruder STLs.zip File:EZStruder SAT.zip
