Downloads
Downloads
Note that this is software under development; there are no official releases yet.
Source code is available from the RepRap CVS repository. Alternatively you can download a tarball (30MB) with all the software in from here.
A Windows binary version is also available.
Windows Version
This version is only periodically updated. Always use the source for the latest working copy.
A link to download this is available at the bottom of this page.
Prerequisites
To install and run this you first need:
- If you don't already have it, a copy of the Java Runtime such as JRE1.4.2 (or J2SE1.4.2), JRE1.5 (or J2SE5.0). This is available from http://java.sun.com/javase/downloads/index.html
- A copy of Java3D for windows. This must be installed after the JRE. It can be downloaded from https://java3d.dev.java.net/binary-builds.html. It will be called java3d-1_4_0_01-windows-i586.exe.
Running it
- Unzip the file to a folder somewhere
- Double click reprap.bat to launch the application. Alternatively, double click reprap-directx.bat to launch the application with DirectX support.
- Set your serial port via the File / Preferences menu option.
