DarwinPartDevelopment
Darwin Part Development
This interim page is designed to host the developments required to achieve Darwin's replication. It tracks only the cartesian robot, not the extruder which has already been replicated. Darwin was originally designed with a support material write head in mind. However, it is possible to achieve replication without a support head if some minor design changes are made.
Part | Replicated? | Who | Mod description | Modded STL (attached to page) |
Bearing-insert-180-X | Y | Vik | ||
Bearing-insert-180-Z | Y | Vik | ||
Bearing-insert-360-jam | Y | Vik | ||
Bearing-insert-360-run | Y | Vik | ||
Bed-clamp | Y | Vik | ||
Bed-constraint-bracket | Y | Vik | ||
Bed-corner | Y | Vik | Internal flat step bevelled, holes on flange teardropped. | [[File:DarwinPartDevelopment-Bed-corner-1.1.stl |thumb]] |
Circlip-M8 | ||||
Corner-bracket | Y | Vik | Squared off corners for strength & to remove bevel. | [[File:DarwinPartDevelopment-corner-bracket-degroof-vik.stl |thumb]] |
Corner-bracket-vertical-bolt-plug | Y | Vik | ||
Diagonal-tie-bracket | Y | Vik | Curved edge replaced with 45 degree step | [[File:DarwinPartDevelopment-Diagonal-tie-bracket-1.1.stl |thumb]] |
Diagonal-tie-bracket | Y | Chris | Smaller version without the set screw | [[File:DarwinPartDevelopment-diagonal-tie-bracket-chris.stl |thumb]] |
Extruder-quickfit-dock | ||||
Extruder-quickfit-latch | ||||
Extruder-clamp | Y | Vik | Simplified version that bolts on. | [[File:DarwinPartDevelopment-Extruder clamp.stl |thumb]] |
Fan-base | Y | Chris | ||
Fan-leg | ||||
Motor-washer | Y | Chris | A motor shaped washer to replace the recess removed from the motor brackets | [[File:DarwinPartDevelopment-motor-washer.stl |thumb]] |
Optoswitch-bracket | Y | eD | M3 chamfer removed. Clamp hole teared. | [[File:DarwinPartDevelopment-Optoswitch-bracket-1.1.stl |thumb]] |
PCB-clamp | Y | Vik | ||
X-belt-clamp | Y | Vik | ||
X-carriage | Y | Vik | Hole for free-running belt teared. | [[X-carriage-degroof.stl |thumb]] |
X-constraint-bracket | Y | Vik | ||
X-idler-bracket | Y | Vik | Axle hole now teardropped, slightly enlarged slots for nuts under Y belt clamp. | [[File:DarwinPartDevelopment-X-idler-bracket-1.1.stl |thumb]] |
X-motor-bracket | Y | Vik | Lugs for X axis bars angled, & teared, base modified to take smaller steppers. Y bearings thickened. | [[File:DarwinPartDevelopment-X-motor-bracket-flattened.stl |thumb]] |
X-opto-flag | Y | Vik | Bolt hole now teared. | [[File:DarwinPartDevelopment-X-opto-flag-1.1.stl |thumb]] |
X-PCB-bracket | Y | Vik | ||
X-square-jig | ||||
XY-pulley-idler | Y | Vik | Sloping base flattened, edges of rim bevelled to 45 degrees | [[File:DarwinPartDevelopment-XY-pulley-idler-1.1.stl |thumb]] |
Y-bearing-housing | Y | Vik | Squared off rounded to to increase strength & added strut at base | [[File:DarwinPartDevelopment-Y-Housing-Square-Top.stl |thumb]] |
Y-belt-clamp | Y | eD | Chamfers removed | [[File:DarwinPartDevelopment-Y-belt-clamp-1.1.stl |thumb]] |
Y-motor-bracket | Y | Vik | Cavity for stepper removed, slots added for smaller steppers. | [[File:DarwinPartDevelopment-Y-motor-bracket-vik.stl |thumb]] |
Y-motor-coupling | Y | Vik | Grub screw holes teared. | [[File:DarwinPartDevelopment-Y-Motor-Coupling-vik degroof.stl |thumb]] |
Y-opto-flag | Y | Vik | Mounting hole teared. | [[File:DarwinPartDevelopment-Y-opto-flag 1.1.stl |thumb]] |
Z-belt-tensioner-idler | Y | Vik | ||
Z-belt-tensioner-idler-case | Y | Vik | ||
Z-belt-tensioner-anchor-bracket | Y | Vik | ||
Z-flag-adjuster-housing | ||||
Z-flag-clamp | ||||
Z-flag-slider | ||||
Z-motor-bracket | Y | Vik | Cavity for motor removed, bolt cavity top made conical, corner bracket contact squared off | [[File:DarwinPartDevelopment-Z-motor-bracket-vik.stl |thumb]] |
Z-motor-coupling | Y | Vik | ||
Z-opto-flag | Y | Vik | ||
Z-studding-tie | Y | Vik | ||
Z-toothed-pulley-rim | Y | Vik | Rim thickened for strength. In thick layers, only one or two were deposited on the original. | [[File:DarwinPartDevelopment-Z-toothed-pulley-rim-1.1.stl |thumb]] |
All necessary parts now printed, and new generation parts (i.e. Z belt tensioner) added. Child machine now working fine.
-- Main.EdSells - 16 Nov 2007
