DarwinPartDevelopment
Revision as of 19:23, 16 February 2008 by VikOlliver (talk | contribs) (version migrated from twiki)
Darwin Part Development
This interim page is designed to host the developments required to achieve Darwin's replication. Darwin was originally designed with a support material write head in mind. However, it is possible to achieve replication without a support head if some minor design changes are made.
Part Replicated? Who Mod description Modded STL (attached to page)
Bearing-insert-180-X Y Vik
Bearing-insert-180-Z Y Vik
Bearing-insert-360-jam Y Vik
Bearing-insert-360-run Y Vik
Bed-clamp Y Vik
Bed-constraint-bracket Y Vik
Bed-corner Y Vik Internal flat step bevelled, holes on flange teardropped. [[File:DarwinPartDevelopment-Bed-corner-1.1.stl |thumb]]
Circlip-M8
Corner-bracket Y Vik Squared off corners for strength & to remove bevel. [[File:DarwinPartDevelopment-corner-bracket-degroof-vik.stl |thumb]]
Corner-bracket-vertical-bolt-plug
Diagonal-tie-bracket Y Vik Curved edge replaced with 45 degree step [[File:DarwinPartDevelopment-Diagonal-tie-bracket-1.1.stl |thumb]]
Extruder-quickfit-dock
Extruder-quickfit-latch
Fan-base
Fan-leg
Optoswitch-bracket Y eD M3 chamfer removed. Clamp hole teared. [[File:DarwinPartDevelopment-Optoswitch-bracket-1.1.stl |thumb]]
PCB-clamp Y Vik
X-belt-clamp Y Vik
X-carriage Y Vik Hole for free-running belt teared. X-carriage-degroof.stl
X-constraint-bracket Y Vik
X-idler-bracket Y Vik Axle hole now teardropped, slightly enlarged slots for nuts under Y belt clamp. [[File:DarwinPartDevelopment-X-idler-bracket-1.1.stl |thumb]]
X-motor-bracket Y Vik Lugs for X axis bars angled, & teared, base modified to take smaller steppers. Y bearings thickened. [[File:DarwinPartDevelopment-X-motor-bracket-flattened.stl |thumb]]
X-opto-flag Y Vik Bolt hole now teared. [[File:DarwinPartDevelopment-X-opto-flag-1.1.stl |thumb]]
X-PCB-bracket
X-square-jig
XY-pulley-idler Y Vik Sloping base flattened, edges of rim bevelled to 45 degrees [[File:DarwinPartDevelopment-XY-pulley-idler-1.1.stl |thumb]]
Y-bearing-housing Y Vik Squared off rounded to to increase strength & added strut at base [[File:DarwinPartDevelopment-Y-Housing-Square-Top.stl |thumb]]
Y-belt-clamp Y eD Chamfers removed [[File:DarwinPartDevelopment-Y-belt-clamp-1.1.stl |thumb]]
Y-motor-bracket
Y-motor-coupling
Y-opto-flag Y Vik Mounting hole teared. [[File:DarwinPartDevelopment-Y-opto-flag 1.1.stl |thumb]]
Z-flag-adjuster-housing
Z-flag-clamp
Z-flag-slider
Z-motor-bracket
Z-motor-coupling
Z-opto-flag
Z-studding-tie Y Vik
Z-toothed-pulley-rim Y Vik Rim thickened for strength. In thick layers, only one or two were deposited on the original. [[File:DarwinPartDevelopment-Z-toothed-pulley-rim-1.1.stl |thumb]]
39 Parts, 31 printed. We're Nearly there!
-- Main.EdSells - 16 Nov 2007
