DarwinPartDevelopment
Darwin Part Development
This interim page is designed to host the developments required to achieve Darwin's replication. Darwin was originally designed with a support material write head in mind. However, it is possible to achieve replication without a support head if some minor design changes are made.
Part | Replicated? | Who | Mod description | Modded STL (attached to page) |
Bearing-insert-180-X | Y | Vik | ||
Bearing-insert-180-Z | ||||
Bearing-insert-360-jam | Y | Vik | ||
Bearing-insert-360-run | Y | Vik | ||
Bed-clamp | Y | Vik | ||
Bed-constraint-bracket | Y | Vik | ||
Bed-corner | Y | Vik | Internal flat step bevelled, holes on flange teardropped. | [[File:DarwinPartDevelopment-Bed-corner-1.1.stl |thumb]] |
Circlip-M8 | ||||
Corner-bracket | Y | Vik | Squared off corners for strength & to remove bevel. | [[File:DarwinPartDevelopment-corner-bracket-degroof-vik.stl |thumb]] |
Corner-bracket-vertical-bolt-plug | ||||
Diagonal-tie-bracket | Y | Vik | Curved edge replaced with 45 degree step | [[File:DarwinPartDevelopment-Diagonal-tie-bracket-1.1.stl |thumb]] |
Extruder-quickfit-dock | ||||
Extruder-quickfit-latch | ||||
Fan-base | ||||
Fan-leg | ||||
Optoswitch-bracket | Y | eD | M3 chamfer removed. Clamp hole teared. | [[File:DarwinPartDevelopment-Optoswitch-bracket-1.1.stl |thumb]] |
PCB-clamp | Y | Vik | ||
X-belt-clamp | Y | Vik | ||
X-carriage | ||||
X-constraint-bracket | Y | Vik | ||
X-idler-bracket | Y | Vik | Axle hole now teardropped, slightly enlarged slots for nuts under Y belt clamp. | [[File:DarwinPartDevelopment-X-idler-bracket-1.1.stl |thumb]] |
X-motor-bracket | ||||
X-opto-flag | Y | Vik | Bolt hole now teared. | [[File:DarwinPartDevelopment-X-opto-flag-1.1.stl |thumb]] |
X-PCB-bracket | ||||
X-square-jig | ||||
XY-pulley-idler | Y | Vik | Sloping base flattened, edges of rim bevelled to 45 degrees | [[File:DarwinPartDevelopment-XY-pulley-idler-1.1.stl |thumb]] |
Y-bearing-housing | Y | Vik | Squared off rounded to to increase strength & added strut at base | [[File:DarwinPartDevelopment-Y-Housing-Square-Top.stl |thumb]] |
Y-belt-clamp | Y | eD | Chamfers removed | [[File:DarwinPartDevelopment-Y-belt-clamp-1.1.stl |thumb]] |
Y-motor-bracket | ||||
Y-motor-coupling | ||||
Y-opto-flag | Y | Vik | Mounting hole teared. | [[File:DarwinPartDevelopment-Y-opto-flag 1.1.stl |thumb]] |
Z-flag-adjuster-housing | ||||
Z-flag-clamp | ||||
Z-flag-slider | ||||
Z-motor-bracket | ||||
Z-motor-coupling | ||||
Z-opto-flag | ||||
Z-studding-tie | Y | Vik | ||
Z-toothed-pulley-rim | Y | Vik | Rim thickened for strength. In thick layers, only one or two were deposited on the original. | [[File:DarwinPartDevelopment-Z-toothed-pulley-rim-1.1.stl |thumb]] |
39 Parts, 20 printed. We're over half way!
-- Main.EdSells - 16 Nov 2007
