Cartesio Base
Description | Printed CNC machine
License | GPL v2
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | see files
External Link |
This page is under development
This is the start/base of it all.
Here you can go back to the main Cartesio page.
once finished it should look like this :
Images
Files
Parts List
Qnty | device | RS stockNr | |
2 | profile 20x40x570mm | prebuild | |
6 | profile 20x40x260mm | prebuild | |
2 | profile 20x20x440mm | prebuild | |
2 | profile 20x20x340mm | prebuild | |
1 | profile 20x20x260mm | prebuild | |
4 | profile 20x20x200mm | prebuild | |
3 | profile 20x20x90mm | prebuild | |
4 | level foot | 257-8656 | |
41 | M6 screw | 281-293 |
Assembly Instructions
Joining 2 profiles togheter
Here is why we choose the Bosch/Rexroth profiles in the first place :
Rather than buying expensive profile holders, we can insert a button head M6 bolt inside the profile.
First screw the M6 bolt in the top of one profile, so the head sticks out about 3mm.
Then slide the head of the screw inside the other profile, to the point where it is alligned with the hole in that other profile.
Now stick your imbus key inside of the hole and secure the M6 bolt
Assembling the bottom layer
2 | profile 20x40x260mm | prebuild | |
10 | M6 screw | 281-293 |
Screw the M6 bolts to all of the 260mm profiles.
Slide all of the 260mm profiles into the 570mm profiles, but do not tighten the bolts.
Put this assembly on a flat surface, so all profiles are aligned in a vertical way.
Now take a profile that is not used and hold it to the 20x20x260mm and the 20x40x570mm profiles so these are aligned in a horizontal way.
Now you can secure the M6 bolts of the 20x20x260mm profile.
Measure that the distance of the 20x40x260 profile that is at the end of the 570mm profile is the same on both sides, and secure the M6 bolts.
Then secure the middle 20x40x260 profile.
Now you can put in the rubber feet, and level the whole bottom of the base.
Adding vertical profiles
4 | profile 20x40x260mm | prebuild | |
8 | M6 screw | 281-293 |
Assembling the spindels
Putting the spindles in
