Cartesio Base
Cartesio Base
Description | Printed CNC machine
License | GPL v2
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | see files
External Link |
This page is under development
This is the start/base of it all.
Here you can go back to the main Cartesio page.
once finished it should look like this :
Images
Files
Parts List
Qnty | device | RS stockNr | |
2 | profile 20x40x570mm | prebuild | |
6 | profile 20x40x260mm | prebuild | |
2 | profile 20x20x440mm | prebuild | |
2 | profile 20x20x340mm | prebuild | |
1 | profile 20x20x260mm | prebuild | |
4 | profile 20x20x200mm | prebuild | |
3 | profile 20x20x90mm | prebuild | |
4 | level foot | 257-8656 | |
41 | M6 screw | 281-293 |
Assembly Instructions
Joining 2 profiles togheter
Here is why we choose the Bosch/Rexroth profiles in the first place :
Rather than buying expensive profile holders, we can insert a button head M6 bolt inside the profile.
First screw the M6 bolt in the top of one profile, so the head sticks out about 3mm.
Then slide the head of the screw inside the other profile, to the point where it is alligned with the hole in that other profile.
Now stick your imbus key inside of the hole and secure the M6 bolt
Assembling the bottom layer
Adding vertical profiles
Assembling the spindels
Putting the spindles in
