AtomX
Atom X
Atom X
CC-BY-SA
About AtomX
This page where created so I can start uploading files and let beta testers do test prints of the parts.
This project where created during a weekend for fun and ended up to be a pretty cool micro bot.
Iam currently refining the parts and adjusting them and will be released 2016-03-27.
It can print all its parts on it self.
Use very little parts.
Cheap to build.
Printing Dimensions
X=110mm
Y=110-130mm (depends on if you use 170 or 200 mm long rods)
Z=150mm
(Updated 2016-03-25)
BOM
Click me
Early beta stl files so download and print at your own risk!
http://reprap.org/mediawiki/images/0/03/Reprap_atomx_beta20160325.zip
Update 2016-03-28
Started uploading revision parts on things I have bin reported and requests.
The x carriage have bin changed so you now nead 47-50mm long m3 screws to attach the motor.
The original where done so you neaded to use a dremel to cut small bits of to fit the motor,it where done like that to make it easier to print.
Rev2 parts do not nead this anymore!!!
if you already printed the old x carriage and don't want to cut with a dremel so is there a spacer here.
http://reprap.org/wiki/File:Reprap_atomx_x_motor_spacer.zip
Also made a small revision on the Bowden mount as some builders thought they neaded to sand and grind to much to fit there Bowden.
I lowered the thicknes in this area with 0.25 mm so should work better.
These parts will be up together with old ones so you can choose wich one you want.
Keep suggestions coming but please post them on the thing page so its easier for me to track ;)
http://reprap.org/wiki/File:Rev2_reprap_atomx_x_fixed_parts.zip
Rods
2 = 170mm Long 6mm rods ( X )
2 = 200mm Long 6mm rods ( Y )
2 = 360mm Long 8mm rods ( Z )
2 = 220mm Long M6 threaded rods ( Structure support )
Leadscrew
1 = 300mm Long 8mm with Brass nut. ( Optional with a extra brass nut to place on the top side to minimize backlash )
Pitch of the leadscrew is up to you as there is many to choose from and easy to change in firmware.
Bearings
8 = Lmu6
4 = Lmu8
4 = 625zz ( Skateboard bearings )
Bearings
2 = GT2 20 tooth pulleys ( Its up to you wath you use I had these at home.)
Belt
1 meter long GT2 ( Is more then enough and you get some left )
Nuts and bolts
4 = M6 nylon lock nuts. 4 = M6 nuts 2 = 47-50mm Long m3 screws ( X motor )
Hotend
Any Jhead or e3d clone should work.
Extruder
Any Bowden type like airtrippers or wades.
World premiere
( Videos have ads to fund my builds )
<videoflash type="youtube">iiAD7D7nIw4</videoflash><videoflash type="youtube">bEwji7QfVgc</videoflash>
