Abbas
Revision as of 19:46, 7 February 2015 by Hacibot (talk | contribs) (Base Assembly)
ABBAS is the open source 3D printer that is based on Prusa i3 . It has simplified aluminum profile frame. Taht is easy to buy and assmebly than laser cut metal frame . it has 26x26 table area if you need a big printing surface you can build it.
ABBAS 3D Printer
Release status: Working
ABBAS 3D Printer
Abbas 3D printer is build with openbuild extrusion. Based dimensions are 260x260x200 , but you can scale them as you want .
Goals
Build a fully scalable 3D printer
Big printing area
Low cost as possible
And of course Opensource
Features
Printer Size  : 500mm x 450mm x 500mm
Printing area  : 260mm x 260mm x 200mm
Print Material  : PLA (1.75mm Default) , Flex
Extruder  : Haddeci V1 Direct-Drive
Nozzle  : 0.5mm default/0.4mm/0.3mm/0.2mm
Pictures
Bill Of Materials
1- 39cm x 2 pcs 20x20 aluminium profile
2- 35cm x 2 pcs 20x20 aluminium profile
3- 32cm x 3 pcs 20x20 aluminium profile
4- 42cm x 4 pcs Ø8 Smooth rod
5- 37cm x 2 pcs Ø8 Smooth rod
6- 33cm x 2 pcs M5 Threaded rod
7- 5x5 Flexible Couplings
8- GT2/T2,5 Washerley x 2pcs
9- GT2/T2,5 Belt x 2 mt
10- 5x Nema 17 motor
1- 32 pcs M4x10 screw
2- 32 pcs M4 T Nuts
3- 32 pcs M4 Washer
4- 6 pcs M6x40 Hex-head screw
5- 6 pcs M6 washer
6- 5 pcs M3x25 flat-head screw
7- 1 pcs M3x20 flat-head screw
8- 3 pcs M3 x10 flat-head screw
9- 2 pcs M3x 35 screw
10- 6 pcs M3x12 screw
11- 8 pcs M3x10 screw
12- 8 pcs M3x25 screw
13- 4 pcs M3x40 flat-head screw
14- 42 pcs M3 washer
15- 40 pcs M3 nylstop nut
16- 4 pcs M3x40 flat-head screw
17- 4 pcs M4 nut
18- 2 pcs M4 x40 screw
Downloads
You can download all Abbas plastic parts below adress.
http://www.thingiverse.com/thing:625085 [1]
Abbas Spool Holder ( Suitable for 20x20 aluminum profile)
http://www.thingiverse.com/thing:597170 [2]
Base Assembly
Bottom rectangle is 32x39 cm Upper U is 32x36cm
File:Http://3.bp.blogspot.com/-GQ6 ioNZKiM/VHhmmXRxbtI/AAAAAAAAAtQ/TJyDHYG1MDM/s1600/1.jpg File:Http://4.bp.blogspot.com/- zREz51c1K8/VHhmma5WFHI/AAAAAAAAAtU/nCBj3TpWH7o/s1600/2.jpg
