Abbas
Revision as of 07:29, 16 January 2015 by Hacibot (talk | contribs) (Files and Parts)
ABBAS is the open source 3D printer that is based on Prusa i3 . It has simplified aluminum profile frame. Taht is easy to buy and assmebly than laser cut metal frame . it has 26x26 table area if you need a big printing surface you can build it.
ABBAS 3D Printer
Release status: Working
How to build an ABBAS 3D Printer
This page represents an example development page and showcases many features that can be used in creating new development pages.
Abbas 3D printer is build with openbuild extrusion. Based dimensions are 260x260x200 , but you can scale them as you want .
Goals
Build a fully scalable 3D printer
Big printing area
Low cost as possible
And of course Opensource
Features
Printer Size  : 500mm x 450mm x 500mm
Printing area  : 260mm x 260mm x 200mm
Print Material  : PLA (1.75mm Default) , Flex
Extruder  : Haddeci V1 Direct-Drive
Nozzle  : 0.5mm default/0.4mm/0.3mm/0.2mm
Pictures
Forum thread?
1- 39cm x 2 pcs 20x20 aluminium profile 2- 35cm x 2 pcs 20x20 aluminium profile 3- 32cm x 3 pcs 20x20 aluminium profile 4- 42cm x 4 pcs Ø8 Smooth rod 5- 37cm x 2 pcs Ø8 Smooth rod 6- 33cm x 2 pcs M5 Threaded rod 7- 5x5 Flexible Couplings 8- GT2/T2,5 Washerley x 2pcs 9- GT2/T2,5 Belt x 2 mt 10- 5x Nema 17 motor
1- 32 pcs M4x10 screw 2- 32 pcs M4 T Nuts 3- 32 pcs M4 Washer 4- 6 pcs M6x40 Hex-head screw 5- 6 pcs M6 washer 6- 5 pcs M3x25 flat-head screw 7- 1 pcs M3x20 flat-head screw 8- 3 pcs M3 x10 flat-head screw 9- 2 pcs M3x 35 screw 10- 6 pcs M3x12 screw 11- 8 pcs M3x10 screw 12- 8 pcs M3x25 screw 13- 4 pcs M3x40 flat-head screw 14- 42 pcs M3 washer 15- 40 pcs M3 nylstop nut 16- 4 pcs M3x40 flat-head screw 17- 4 pcs M4 nut 18- 2 pcs M4 x40 screw
Downloads
5 mm Aluminium  plate
You need  2 Maximus E3D retainer , 1 printed in PLA and 1 in aluminium , thickness of each part must be 3mm
First Print
Raspberry Pi addon.
First print for the Maximus XL 3D printer
<videoflash type="youtube">vu_Uf3a5s4g</videoflash>
