.ctor-bot
Release status: Working
Description | Simple, cheap and easy to build 3D printer.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
The goal was to build a printer with bigger print volume than Prusa Mendel.
Chassis based on M8 screw rods, strong pyramidal design and It has mount holes to the wooden plate to increase the stability of the printer.
It uses standard 220x220mm aluminium heated bed, E3D V6 hotend (clone) with Bowden type extruder. You can use any cheap one from China.
Build size is 220 x 220 x 200 mm (xyz).
Z axis has bearing stabilizers to reduce z-wobbling.
All parts are easy to find.
Screw rods M8:
4 x 452 mm - Z pyramid diagonals.
4 x 423 mm - Z verticals.
2 x 330 mm - Z-axis motor screw. I used standard M8 rods.
2 x 466 mm - For top X.
4 x 450 mm - For bottom X.
2 x 480 mm - For Y.
2 x 180 mm - For spool holder, optional.
Smooth rods, 8mm:
2 x 420 mm - Z.
2 x 420 mm - Y.
2 x 405 mm - X.
You also need 14pcs of 608 bearings:
8pcs for Z stabilizers.
2pcs for Z screw bottom support.
2pcs for Y belt pulley (idler)
2pcs for spool holder, optional
And a lot of M8 nuts and spacers also as M3 with different sizes.
.ctor-bot has a standard Graphical 128x64 display and Arduino Mega with RAMPS 1.4 extension board. Also, you need 3pcs standard RepRap mechanical endstops.
.STL
Image | File | Description |
ctor-bot foots.zip | All-in-One foots STL file. | |
ctor-bot top-brackets.zip | All-in-One Top Brackets STL file. | |
ctor-bot z-axis + hotend carret.zip | All-in-One Z-axis brackets and
e3d V6 single extruder hotend base STL files. | |
ctor-bot misc.zip | Display housing, Arduino case,
Y-axis idler pulley (for 608 bearing), Y-axis smooth rods clips. | |
ctor-bot bed-support.zip | All-in-One STL for heated bed support.
Not the best design. TODO. | |
ctor-bot spool-holder.zip | All-in-One spool holder STL. |
BOM
2 pcs 5mm to 8mm stepper motor coupler. I Used screw one.
11 pcs lm8uu linear bearing. It is possible to use printed with PLA. You can found good models on Thingerverse.
5 pcs nema 17 stepper motors. I used 3pcs 17hs4410 for X, Y and extruder and a couple of 17hs2408 motors for Z-axis.
12V 20A Power supply (If you choose 12V electronics).
RepRap 128x64 graphic LCD controller with SD Card support.
Arduino Mega + RAMPS 1.4.
40mm + 5015 Fan.
E3D V6 (there is an option with Volcano heated block, use longer fan throat).
Any extruder with Teflon tube.
3 pcs GT2 16 teeth pulley for motors.
1 GT2 pulley idler.
Approximate 2m of GT2 Belt.
14 pcs 608z ball bearings.
220x220mm Aluminium Heated bed.
