PonokoExtruderAssemblyBOM
From RepRapWiki
1 0.1uF capacitor 1 200-300mm of nichrome wire with a resistance of about 8 ohms 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 2 680Z "sk8er b0y" bearing 5 M3 20mm screw 2 M3 30mm screw 4 M3 40mm screw 3 M3 50mm screw 11 M3 nut 23 M3 washer 2 M5 25mm screw 5 M5 30mm screw 4 M5 nut 1 M5 nyloc nut 3 M5 washer 1 M6 32mm o/d washer 2 M6 dome nut 2 M6 half- or press-nut 2 M6 washer 4 M8 nut 1 M8 studding 110mm 4 M8 washer 1 PTFE tape 2 hole socket strip 4 large M3 washer 1 m5 washer 4 small, stout springs 1 thick, solid, insulated copper wire
-- Main.RussNelson - 08 Dec 2008
