PrusaFirmwareBraino
- 1 PRUSA FIRMWARE
- 2 Prerequisites
- 3 Host PC Toolchain
- 4 Sanguinololu Electronics
- 5 Download Sprinter source code
- 6 modify source code files
- 7 final issues before sucess
- 8 Compile and uploader Sprinter
- 9 install pronterface
- 10 install slicer
- 11 copy sanguino definitions into Arduino install directories - installed from Software center
- 12 Add user to DIALOUT group
- 13 Weird errors
- 14 invalid device signature -means- No Bootloader
PRUSA FIRMWARE
When I built my Prusa in 2011, I used Sanguino electronics with ATMEGA644P, and Sprinter firmware. PC ran Windows operations system.
Now (2015), I need to modify the firmware as part of printer calibration http://reprap.org/wiki/PrusaCalibrationNotesBraino. The old PC has been replaced with a upgraded workstation running Linux (Mint 17, similar to Ubuntu). The entire tool chain has seen changes or upgrades. The information retained from the original firmware is the Configuration.h from Sprinter. This should be all that is necessary.
The goal is Sprinter firmware on Sanginololu electronics prior to calibration http://reprap.org/wiki/PrusaCalibrationNotesBraino
This is the summary of investigation spanning one month's time. I hope your firmware build is significantly shorter.
Prerequisites
In order to create new firmware, we need:
- host PC (toolchain)
- Reprep (electronic configuration + mechanical configuration)
- Firmware application (source code configured for the individual reprap machine)
- firmware programmer (to get the new firmware into the reprap controler)
The reprap is a working metric (Mendel) Prusa (2011). The electronics are known-working Sanguinololu v1.3a.
The host PC needs the full toolchain discovered and installed. On Linux this should be much easier than on Windows, as windows was a not pleasant.
Host PC Toolchain
My host PC has linux Mint 17 64 bit. Actually, I did this a bunch of times and I believe the correct instrustions are the same and successful on Mint 16 and 17 both 32 bit and 64 bit. We Need:
- Host PC OS
- Arduino IDE (compiler)
- Sanguino hardware support files (so the Arduino IDE compiler knows our hardware)
- Sprinter firmware source code
We want to use the Arduino IDE to compile the Sprinter firmware for our hardware.
OS Clean install
I start with a clean OS install. I run virtual box virtual machines. If anything goes horribly wrong it is quicker to launch a new virtual machine rather than re-do the main PC.
When everything finally works, I either keep the virtual machine, or configure a dedicated physical machine. In this case I have a bunch of old junker PC that are still fine for running a 3D printer, and this frees up my main rig for its intended purpose.
Download Arduino IDE
- Download the latest Arduino from the Arduino downloads page http://arduino.cc/en/main/software. I used 1.0.6 for linux 32 bit for this pass of the instructions, but it also worked with 64 bit last pass.
- Extract the downloaded archive.
- Find the Arduino script in the arduino directory.
- Launch the Arduino IDE by running the shell script (just click on it).
At first launch, the Arduino IDE creates a "sketchbook" directory. This is a C code "projects" directory. I guess they could not simply name it "projects", as that would be too obvious.
Also, at first launch, the Arduino IDE will add the current user to the DIALOUT group. This is required, as it allows us to access the USB virtual serial port /dev/ttyUSB0. The USB virtual serial port /dev/ttyUSB0 is the connection from the Arduino IDE to the Sanguino electronics. This will also be the connection to the PRonterface application on the PC, but we'll get to that in a minute.
The silkscreen on the board displays Sanguino(lolu) v1.3a. Originally, I felt I wanted Sanguino electronics as the closest thing to a "standard", and purchased this. In fact, I found the anti-static bag it came in, it was from Solidoodle. The board arrived with a bootloader pre-burned, so I have no previous experience or need of any bootloader programmer.
I started at the Sanguinololu page, http://reprap.org/wiki/Sanguinololu. That page is only googe for HARDWARE, and does not seem to be of much use after the board is constructed. The page lists FUSES (which should not be an issue on a running board) and confirms Sprinter (my previous choice for firmware) is valid for these electronics.
NOTE: originally, the information was associated with the name "Sanguino". However, if we google sanguino, Google sends us to a binoculars place. Notice the hit is Google Code Sanguino. This will be used later.
Download Sanguino support
I started at the Sanguinololu page, http://reprap.org/wiki/Sanguinololu. That page is only good for HARDWARE.
For the sanguino hardware description files the Arduinio IDE's compile needs to build the sprinter firmware application, we want the google code page.
http://code.google.com/p/sanguino/downloads/detail?name=Sanguino-0101r1.zip
Sanguino-0101r1.zip is the most recent source code to date. This is what I found successful.
- Download the Sanguino-0101r1.zip archive
- extract the archive
- copy or move the sangino directory that is extracted to the /hardware directory in the Arduino folder. It should end up looking like:
~/arduino/hardware ~/arduino/hardware/arduino ~/arduino/hardware/sanguino ~/arduino/hardware/tools
NOTE: If the Arduino IDE was downloaded from the Arduino site, the Arduino IDE code should all be in the current user home directory somewhere (probably under Downloads by default) and we have permission to move and copy files here. IF the software was installed from thesoftware center, it will be under /user/share/arduino and will be owned by root. See http://reprap.org/wiki/PrusaFirmwareBraino#copy_sanguino_definitions_into_Arduino_install_directories_-_installed_from_Software_center_2 for instructions on changing permission to allow move and copy
From https://github.com/kliment/Sprinter
Run this command in a terminal window:
git clone https://github.com/kliment/Sprinter.git
The command will create a Sprinter directory in you home directory which contains all the Sprinter firmware code.
Move the Sprinter directory to the sketchbook fold that the Arduino IDE created earlier.
Now when you launch the Arduino IDE, the file menu displays Sprinter under the sketchbook directory.
sprinter instructions are broken for sanguino / sanguinololu
Ignore all the instructions in the SPRINTER readme file. Those are out of date, and will send you in circles for days.
For the most part, the changes needed to configure the sprinter source code are made in configuration.h
In my case, I also modify one items in Sprinter.pde (Sprinter.ino) and need to reverse pins in pins.h
modify Sprinter.PDE (Sprinter.ino)
I like to have the printer TELL me if the firmware is correct, and if it has changed. To do this, I add a date/time stamp. To achive this, in Sprinter.pde:
- locate the VERSION_TEXT definition around line 252
#define _VERSION_TEXT "1.3.22T / 20.08.2012"
- comment this line out, but copy the defintion to the beginning of the file
// #define _VERSION_TEXT "1.3.22T / 20.08.2012"
- using the uncommenet definition at the beginning of the file, add a date stamp
#define _VERSION_TEXT "1.3.22T / 20.08.2012 Braino20150203-1622 esteps708"
Now I will change the date/time each time I make a change to the file, and add single word note like esteps708 to flag what I changed in the file. The printer will display this when connected to pronterface. This is handy to confirm that the new firmwware did in fact upload, and where I left off after my last upload.
modifiy Configuration.h
Modify the following in configuration.h
- open the Arduino IDE
- in the file menu select sketchbook > Sprinter
- The sprinter project opens
- click the tab for configuration.h
These are the edits I perform:
No SD on this machine:
// Comment out (using // at the start of the line) to disable SD support: // #define SDSUPPORT
Select Sanguino:
// Sanguinololu 1.2 and above = 62 // #define MOTHERBOARD 33 #define MOTHERBOARD 62
OK, this is what I needed to change. Last time I had X and Y step per unit as 57.11, & extruder steps per unit was 700 (calculating by hand). Now the online calculator http://prusaprinters.org/calculator/ says I need 57.265569 and 625.70629055 (and I checked it, and the calculatin looks correct). This is the bit that should fix my print issues. How did I get 57.11 instead of 57.265569? I didn't know what I was doing and/or I changed something with the mods I made. It may have something to do with the "effective diameter of the Hobbed bolt". This means the the 8mm boltdiamter get reduced when we cut the hobs into it. Also when we tighten the idle bearing again the hob, the effective diameter (and/or the effective diameter of the filament) changes. So we have to run some tests from Triffid Hunter's calibration, and adjust there numbers. But more on that later, for now find the file and edit it.
//// Calibration variables // X, Y, Z, E steps per unit - Metric Prusa Mendel with Wade extruder: // #define _AXIS_STEP_PER_UNIT {80, 80, 3200/1.25,700} #define _AXIS_STEP_PER_UNIT {57.265569, 57.265569, 3200/1.25, 708}
The final number (708 at this writing) is what is tweaked to tune the extruder steps per unit.
Proper bed travel for this machine:
//----------------------------------------------------------------------- //Max Length for Prusa Mendel, check the ways of your axis and set this Values //----------------------------------------------------------------------- const int X_MAX_LENGTH = 190 ; // 200; Only needs to be 190 for very tall (94 mm) objects; 205 for calibrating bed. const int Y_MAX_LENGTH = 180; //200; const int Z_MAX_LENGTH = 94; // 100
additional modification for my printer - fix reversed X Axis
I think the parts I purchased were reversed in the X-Axis. Everything works great, except in Pronterface, clicking +X sends the extruder to the left. It a little annoying but I could live with it. After finally going back and sorting the firmware out, I figure I may as well fix this now.
This fix has two parts: half is in configuration.h half, is in Pins.h
From http://www.thefrankes.com/wp/?p=2651
in ~/Sprinter/configuration.h:
change const bool INVERT_X_DIR = false; to
// const bool INVERT_X_DIR = false; const bool INVERT_X_DIR = true;
change #define X_HOME_DIR -1 to
// #define X_HOME_DIR -1 #define X_HOME_DIR 1
NOTICE: there must be exactly one space between DIR and 1 or it won't work
change "const bool min_software_endstops = false; //If true, axis won't move to coordinates less than zero." and "const bool max_software_endstops = true; //If true, axis won't move to coordinates greater than the defined lengths below." to
//const bool min_software_endstops = false; //If true, axis won't move to coordinates less than zero. //const bool max_software_endstops = true; //If true, axis won't move to coordinates greater than the defined lengths below. const bool min_software_endstops = true; //If true, axis won't move to coordinates less than zero. const bool max_software_endstops = false; //If true, axis won't move to coordinates greater than the defined lengths below.
This is so the X can move to do the home operation.
in ~/Sprinter/pins.h
- find line 667 #if MOTHERBOARD == 62 (this is the Sanguino section)
- find
"#define X_MIN_PIN 18" "#define X_MAX_PIN -2"
change this to
// #define X_MIN_PIN 18 //#define X_MAX_PIN -2 #define X_MIN_PIN -2 #define X_MAX_PIN 18
Be aware the the X Axis won't want to move until the HOME button have been clicked
Once the PC, toolchain, support, and source code were in place, there still were issues before success. Check there is you have problems.
Bootloader was overwritten
It turns out the sanguino(lolu) board did not have a bootloader, even though there was Sprinter firmware on the board. The Arduino IDE appeared to be communicating, and the board board appeared to be responding, but did not accept the new firmware. Perhaps there is some test to determine if a bootloader is present? I have not seen any in the instructions.
This message means there is no bootloader:
avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check.
See http://reprap.org/wiki/PrusaFirmwareBraino#invalid_device_signature_-means-_No_Bootloader
FUSES: X move in one direction, endstops not working
The FUSES are wrong in the Sanguino support. In ~/hardware/sanguino/board.txt we see:
atmega644.bootloader.low_fuses=0xFF atmega644.bootloader.high_fuses=0x9A atmega644.bootloader.extended_fuses=0xFF
However, http://reprap.org/wiki/Sanguinololu#Fuse_Settings tells us:
Fuse Settings
The fuses for the atmel chip must be changed from the default factory settings to disable JTAG.
Symptoms of incorrect fuse settings:
X axis only moves in one direction. Endstops do not work.
644P Fuse Settings
The settings come from the bootloaders boards.txt file.
Example using avrdude and usbtiny.
avrdude -B 8 -patmega644P -c usbtiny -U lfuse:w:0xFF:m -U hfuse:w:0xDC:m -U efuse:w:0xFD:m
Change ~/hardware/sanguino/board.txt to
//atmega644.bootloader.low_fuses=0xFF //atmega644.bootloader.high_fuses=0x9A //atmega644.bootloader.extended_fuses=0xFF
atmega644.bootloader.low_fuses=0xFF atmega644.bootloader.high_fuses=0xDC atmega644.bootloader.extended_fuses=0xFD
In the Arduino IDE select
- tools > board > Sanguino with 644P
- tools > programmer > parallel programmer (I made a parallel programmer from here: http://arduino.cc/en/Hacking/ParallelProgrammer?from=Main.ParallelProgrammer )
- hit the RESET button on the sanguino board
- wait several seconds so the board can wake up
- Burn bootloader
- hit the reset button AFTER the bootloader uplad is complete.
ALSO: I don't know if this is crazy or what, but I thought I did this several times. It did not take affect until I hit the reset before burning the bootload (to ensure the board wasn't areleady doing something) and AFTER buring the bootloader (to ensure the changes are committed). Maybe the resets have nothing to do with it, perhaps the parallel programmer is weak it it took many attempts before the fuses actuallty changed. In any case, this is what my notes say worked.
Now that everything is set up, compile the Sprinter source code we modified and upload it to the printer's Sanguino board.
In the Arduino IDE, use the Verify button to compile the source code. If there are no errors, we can continue with upload.
Ensure the Arduino IDE is connected to /dev/tty/USB0
Click the upload button.
install pronterface
In order to test the firmware, we need the control application Pronterface running on the PC. After testing Pronterface is the tool by which we control the printer for day to day operation.
install slicer
The final step of testing involves actual printing. Once we are able to print we can start on calibration
- Find the arduino install directory, check the permission with
cd /usr/share/arduino/; ls -alF
- Set permission so we can write to the hardware subdirectory, check they changes with:
sudo chmod -R 777 hardware ls -alF
- Extract the Sanguino [-0101r1] archive (wherever it was downloaded, this is what we will move shortly).
- Copy the Sanguino directory to the Arduino install directory /hardware subdirectory (using the file browser). It should end up looking like:
/usr/share/arduino/hardware /usr/share/arduino/hardware/arduino /usr/share/arduino/hardware/Sanguino /usr/share/arduino/hardware/tools
- start the arduino IDE, there should be a shortcut in the menu popup
- the first launch will ask to add your user to the dialout group, say yes.
- check that the sketchbook directory was created in your home directory
- shutdown and restart the PC (or virtual machine) so the dialout group change takes affect
At first launch, the Arduino IDE will add the current user to the DIALOUT group. This is required, as it allows us to access the USB virtual serial port /dev/ttyUSB0. The USB virtual serial port /dev/ttyUSB0 is the connection from the Arduino IDE to the Sanguino electronics. This will also be the connection to the PRonterface application on the PC, but we'll get to that in a minute.
If for somereason this did not happen automattically, here are the commands to set up the dialout group. In a terminal window, type the following:
sudo adduser $USER dialout
Shutdown and restart the PC or virtual machine for the dialout group change to take affect.
Weird errors
I recieved lots of weird error messages the on several attempts at installing the Arduino IDE, the Sanguino support, and compiling the Sprinter source code. These were caused by several mistakes on my part:
- I believed the board had a bootloader, since I had previously had configured and loaded Sprinter firmware.
- I believed the fuses were set correctly since the printer have been operating properly for years.
- I assumed the fuse setting in the sanguino download were correct.
Compiling the sprinter firmware gave the error message:
/usr/share/arduino/hardware/sanguino/cores/arduino/HardwareSerial.cpp:132:15: error: attempt to use poisoned "SIG_USART1_RECV" #elif defined(SIG_USART1_RECV) ^
I cannot determine what caused this or what changed to make this go away. Perhaps it was the missing bootloader or the incorrect fuses. I thought it was due to the OS, the Arduino IDE version, or the Sanguino hardware support version. However, the source code now compiles successfully on Mint 16 32 bit and Mint 17 64 bit. The one thing I DO know is that the "fix" we find via a google search does NOT solve the problem, it only changes it into something else. That is:
...edit the Arduino.h in /usr/share/arduino/hardware/sanguino/cores/arduino adding... #define __AVR_LIBC_DEPRECATED_ENABLE__ 1 ...as third line.
... may make the message go away, but something else goes wrong. and on and on. If things are set up properly, the message is not displayed in the first place.
Bear this in mind when performing troubleshooting.
For kicks, here is the full compile and verbose upload report that I looked at for a couple days. I assumed this says the the device is working and communicationg properly, the only issue is the signature is not set, and that signals the upload operation to quit. Perhap it would succeded with the -F option? [update: No and No, No, No; and No. The message means there is no bootloader, the device is funstional but the upload is not working becuase there is no bootloader, the bad signature is a manifestation of the bootloader not replying with the correct signature, the upload attempt has already completed and not responded with the correct answer. The -F option does something other than what were would want here.]
Binary sketch size: 37,620 bytes (of a 63,488 byte maximum) /usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega644p -cstk500v1 -P/dev/ttyUSB0 -b38400 -D -Uflash:w:/tmp/build7737045225584187139.tmp/Sprinter.cpp.hex:i
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 15:55:32 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf" User configuration file is "/home/sanguino/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0 Using Programmer : stk500v1 Overriding Baud Rate : 38400 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] AVR Part : ATmega644P Chip Erase delay : 55000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 10 128 0 no 2048 8 0 9000 9000 0xff 0xff Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- flash 33 6 256 0 yes 65536 256 256 4500 4500 0xff 0xff Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500 Description : Atmel STK500 Version 1.x firmware avrdude: Send: A [41] . [80] [20] avrdude: Recv: . [14] avrdude: Recv: . [02] avrdude: Recv: . [10] avrdude: Send: A [41] . [81] [20] avrdude: Recv: . [14] avrdude: Recv: . [01] avrdude: Recv: . [10] avrdude: Send: A [41] . [82] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: Recv: . [10] avrdude: Send: A [41] . [98] [20] avrdude: Recv: . [14] avrdude: Recv: . [03] avrdude: Recv: . [10] Hardware Version: 2 Firmware Version: 1.16 avrdude: Send: A [41] . [84] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: A [41] . [85] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: A [41] . [86] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: A [41] . [87] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: A [41] . [89] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] Vtarget : 0.0 V Varef : 0.0 V Oscillator : Off SCK period : 0.1 us
avrdude: Send: A [41] . [81] [20] avrdude: Recv: . [14] avrdude: Recv: . [01] avrdude: Recv: . [10] avrdude: Send: A [41] . [82] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: Recv: . [10] avrdude: Send: B [42] . [82] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [01] . [00] . [08] . [00] . [00] . [01] . [00] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: Send: P [50] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] ################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] ################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] avrdude: Send: V [56] 0 [30] . [00] . [01] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] ################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00] [20] avrdude: Recv: . [14] avrdude: Recv: . [00] avrdude: Recv: . [10] ################################## | 100% 0.01s
avrdude: Send: Q [51] [20] avrdude: Recv: . [14] avrdude: Recv: . [10]
avrdude done. Thank you.
Again, the above message (from Verbose setting) indicates that while the chip wants 38400 baud, and would talk if it were able, it has no bootloader, and a bootloader must be uploaded to the chip before we can move forward.
