PrusaBuildNotesBraino
- 1 Prof Braino's Prusa Build Log
- 2 testing the system
- 3 Calibrating and Tweaking
- 4 Extrusion test
- 5 Print Calibration 1
- 6 More on PC Software
- 7 PC tool chain options
- 8 PRINT CALIBRATION
- 9 Creating STL MODELS
- 10 Misc Creating and dealing with STL
Summary: To catch my build notes for my Prusa Build Autumn 2011
Who the heck is this Prof Braino guy? http://reprap.org/wiki/User:Prof_braino
If your a n00b like me, some of this fancy computer stuff might be confusing. Here's some stuff I used to get my rig working or at least to the state that it is today.
NOTICE: This is a build in progress. Many parts are out of sequence, due to the distributed nature and in flux development of the reprap project,
High level project is to implement an alternative processor, specifically the Parallax Propeller per this discussion http://forums.parallax.com/showthread.php?129448-Prop-based-CNC-3D-printer
In order to establish a baseline as to what constitutes the current 3D-Printer (as of 20110701), I opted to build a unit for comparison. I settled on a modified Mendel Prusa http://reprap.org/wiki/Prusa. This includes a modified Wades extruder, and LM88uu linear bearings. The X-axis ends are different. Some parts are MDF instead of printed. So far, It has taken me 5 months to find all the parts and bring them together.
This is a log of the specifics I encountered. Hopefully, a person armed with the data in this log will be able to get up and running in a shorter time for a lower cost. The brick and mortar locations are in the Chicago Northwest Suburbs.
The total price was estimated to be $300-$400 USD. The actual prices are listed for each item. So far the total is: $638! Don't tell my wife!
The additional costs were due to the pre-built kits for hot end and motherboard.
I'm not do good with electronics (I'm more of a software guy), and saved my self at least a couple weeks with the solidoodle part.
The hot end was another spot of trouble. I did manage to find a very nice scape of PEEK, and couple sources for nichrome wire, but did not happen across Teflon rod yet. Since I bought the kit, there is no urgency to find Teflon rod, but its still on the list for future investigation.
Mechanical
Printed parts from Sacha at Pumping Station One http://pumpingstationone.org/tag/reprap/ This kit includes all the printed parts. The vertices are replaces by MDF pieces in this kit, that are very precise and are quicker to make. There might be one piece missing from Sacha's kit, the wooden plate for the modified Wades' extruder. Be sure to ask if you go this route.
$150
Rods from McMaster-Carr (they delivered to my door! Same day!)
- 1272T17 Smooth Rod 8mm 3@ 1 meter
- 98861A080 M8 1,25 pitch threaded rod 6 @ 1 meter
$78
Fasteners from Jordan Supply (there's more than listed on the web site) http://www.jordanindustrial.com/
$11
Leveling and Truing
The default instructions talk about using a nut on a thread as a plumb line. This did not work so well for me. Instead, I decided to get the whole thing level and just measure it.
I used a piece of large marble bathroom tile as a poor man's granite block. The marble has a shiny surface, it is easy to see that it is optically flat. Its marble so it won't bend much. This was made level with a spirit level and two Popsicle sticks. The machine was placed on top. At this point, it was easy to get the measurements correct, 234 mm for the triangles and 280 for the laterals. I spot checked the diagonal measurements for the base, they matched so I was able to proceed.
Later I changed from a marble bath tile to a piece of Corian cut out from a kitchen counter top from when the sink was installed. This is about 26x14 and is perfect size for the prusa.
For the Y axis, the top print platform was bolted to the lower print platform. When rotated 90 degrees from normal, this will rest on the Y axis bearing bars. Drawing them to the lower platform will ensure they are parallel. After the linear bearings are added to the lower platform, siding the platform the full range settles the smooth rods into place, and they can be tightened,
The X axis ends are modified, so this affects X and Z axes assembly. The modified ends to not use set screws, the smooth rods are held in place by friction. If the X rods are too long, they cannot be adjusted shorter, they needed to be removed and re-ground.
For the Z axis, the task was to find the midpoint of the bottom side of the triangle, and then add the offset for the Z axis smooth rod. This was close enough for a course approximation, the X axis is used for the final adjustment.
For the X axis, the smooth rods need the linear bearing before they are inserted into the X axis ends. The Z rod holders are loosened, and the X axis placed on the print platform. The Z rods a slid into the Z bearings. The Z motor mount position is adjusted according to the X ends.
It was easier than it sounds.
Hot End
MakerGear - the instructions are not organized clearly. I made some major mistakes despite reading them first several times, and following quite closely. [what exactly is not well organized? makergear|rick]
NOTE to SELF: send notes to rick at makergear
http://www.makergear.com/products/operators-pack "Operator pack" and "Hot End Pack" and (there was third term) all refer to the assembly that holds the heater coil and extruder tip. It cost $75
The Hot End pack requires Wooden Mounting Pieces - Wade for $6.00 USD.
The wooden mounting plates did not fit the modified Wades extruder directly. (the screw holes were off by about 2mm). I don't know if there is and alternate wooden plate with the correct dimensions, perhaps Sacha laser cut his own and forgot to include them in the kit of parts he sells?
$86 including shipping
<include the full list of comments?>
Electronics
I opted for a one piece mainboard
http://reprap.org/wiki/Sanguinololu
This one is preassembled
http://store.solidoodle.com/index.php?route=product/product&path=63&product_id=52
It includes a bootloader pre-burned during assembly and testing during production.
This needed a two pin shunt header soldered to the AUTO RST labeled on the skilk screen to enable Autoreset. Shunting the jumper allows the PC to restart the Arduino for programming, etc. Removing the shunt (default) allow the unit to operate stand alone; that is, it will not reboot when the unit is disconnected or reconnected to the PC print.
This module is intended to be swapped out and replaced with the propeller chip implementation at some point.
$116 including shipping
Stepper Motors and Drivers
Pololu 1200 were recommended by several sources. FIVE are needed, two for the Z-axis. Reordering one more motor costs nearly double the price of the motor due to shipping.
http://www.pololu.com/catalog/product/1200/faqs
The stepper drivers are refered to by the stepper driver IC. The unit we buy is the IC mounted on a carried board. The A4988 has over current protection. FOUR are needed. The one used for the Z-axis can drive the two Z-motors easily. New notes say to wire them in series instead of parallel contraindicating the instructions.
http://www.pololu.com/catalog/product/1182
$161 including shipping (would have been $11 less had it been a single order)
Belts and Pulleys
These we a bit of trouble to find. The instructions specify T5 belts and 11 tooth cog for 5mm shaft.
I ended up getting a 9 foot length of T5 belt and have enough left over to replace one axis.
The 11 tooth pulleys are for 1/4 inch and 3/16 inch belt. I had to drill them out to 5mm to fit on the Pololu motor shafts.
McMaster Carr - they delivered to my door AGAIN! Same day! http://www.mcmaster.com/#catalog/117/1046/=f3isi9
- 5710k12 (2)
- 7959k24 (9 feet)
$36
Power Supply, Connectors, harversted parts
Power Supply
I found a pre-ATX power supply in the junk box. This type uses a physical power switch instead of control by motherboard logic. Its a HIPRO Hp-200PPGN harvested from a Tiger Direct K-6/2. It was diagnosed as unstable, but claims 8 amps on the 12 volt rail.
Connectors
The sanguino board has 11 connectors for the motors, end stops, and thermistors.
The four 4 pins stepper motor connectors are the same size as 1.44 floppy drive connectors. I harvested these from dead power supplies and Y-cables. Cots $0
The three 3 pin endstop connectors are the same as size as PC fan connectors (with RPM monitoring). I harvested these from noise fans recovered from dead PCs. The yellow and black wires were swapped compared to the layout on the Sanguino. This was fixed with a toothpick and a magnifying glass.
The four 2 pin thermistor and heater connectors for the extruderr and heated bed are the same as PC fan connectors (without RPM monitoring). I don't have a heated bed at this time, so it was easy to find 2 dead fans.
Software
The firmware selected for the printer affects the software needed for the PC. After selecting and extracting the firmware archive, we discover what prerequisite software is needed on the PC. This is why the printe firmware is listed first, but appears in the middle of the PC software install list.
Firmware
SPRINTER archive https://github.com/kliment/Sprinter
PC
The PC software needs to be set up to run interface to the Arduino firmware.
I selected the first Recommended firmware from http://reprap.org/wiki/Sanguinololu#Software * SPRINTER *
The software needs to be set up on the PC before the firmware will respond.
The software might not need to be installed in this exact order, but do it this way to be safe.
Windows XP workstation:
Python
The Python programming environment is NOT included with Windows XP but fortunately we can download it for free and use it legally. Python is very small and reasonably quick and efficient. Python is the new BASIC, we don't need to use basic anymore. Use Python, its more modern that getting a trendy tattoo.
Anyway, the interface to the Arduino micro controller that run the Prusa is written in Python.
We install a bunch of Python packages to in preparation to running the printer.
[From Printrun README.md]
- Needs Python 2.7.2
http://www.python.org/download/releases/2.7.2/ I used http://www.python.org/ftp/python/2.7.2/python-2.7.2.msi
- needs pyserial - I missed this twice!
http://pypi.python.org/packages/any/p/pyserial/pyserial-2.5.win32.exe
- Needs Python wx
http://www.wxpython.org/download.php#stable I used http://downloads.sourceforge.net/wxpython/wxPython2.8-win32-unicode-2.8.12.1-py27.exe
- needs pyreadline - I missed this twice!
http://launchpad.net/pyreadline/1.7/1.7/+download/pyreadline-1.7.win32.exe
Download and extract the SPRINTER archive https://github.com/kliment/Sprinter
Follow the instructions in the SPRINTER README
PC software
- Arduino IDE http://www.arduino.cc/en/Main/Software
I used current newest version 0023
Plug in the Sanguino board, Windows XP will detect the USB device. If the New Hardware Found wizard doesn't find the driver, let it fail and update it using the device manager per these steps:
http://arduino.cc/en/Guide/Windows#toc4
The machine that already had FTDI USB to serial set up for the parallax propeller worked without additional drivers;
On another machine I had to navigate to the FTDI folder Note the virtual COM port ID for SPRINTER
- Sanguino configuration files, version 0018
http://sanguino.cc/softwareforwindows Copy the directories as directed
Launch the ARDUINO application Open SPRINTER.PDE EDIT the files as directed
NOW TO TEST if its talking......
Printer Firmware
The Ardunio code is "firmware" this runs the printer. This receives instrucions (from somewhere else we will cover next) and make the printer move.
The Arduino firmware in this example is SPRINTER.
In the ARDUINO application, with SPRINTER open:
Select Tools-> Board-> Sanguino Select Tools-> Serial Port -> COM3 (or whatever you noted above) Select Tools-> Serial Monitor
After about 10 seconds, the serial monitor should display a "start" message from SPRINTER.pde
If it doesn't, try hitting the reset button on the Sanguino. Also check that the baud setting matches the settings in the config files.
For my, it did not respond correctly unitl I set the serial monitor window2 baud rate to 115200
NOTE in the SPRINTER source code file it can be useful to edit the
void setup()
function to contain a unique message, so you know your change has been loaded. Find the line that says
Serial.println("start")
and change it to something you can recognize like
Serial.println("start Prof Braino is the coolest 20111122-1225")
If you include a date-time stamp as above each time you edit the file, you can always tell when a change has reached the device. If you include a descriptive comments like "end stops calibration" you can tell where you left off, or if the proper version of the firmware is loaded.
NOTE: There is a note someplace that might say not to change this message, I haven't figured out if this affect anything in an adverse way. The objective is to display which mod to the firmware is running, since this can change
In configuration.h update
//#define MOTHERBOARD 3
to
#define MOTHERBOARD 62
You can also change
char uuid[] = "00000000-0000-0000-0000-000000000000";
to sopmething you can recognize like
char uuid[] = "this is my board 00-0000-000000012345";
There are more changes to the spirnter.pde firmware listed below, they are being logged in the order I encountered them.
Ubuntu 11.04 Laptop:
<after I clear a space in the shop>
Both Window PC and Linux PC - Additional Python Scripts
IN ADDITION To SPRINTER, we need another set of Python scripts
Printer Application Software
The PC printer application software is the program that runs on the PC. This talks to the printer firmware, and allows the user (you) sitting at the PC to control the printer. Actually, you give commands to the printer appliction, the printer application gives command to the firmware, and the firmware gives commands to the electronics.
Printrun
Printer Application
Download and extract Printrun
https://github.com/kliment/Printrun
I moved the whole printrun subdirectory to my Python directory so it would be easy to find from within Python
Pronterface.py
PRONTERFACE.py is the python script that runs the user window for controlling the printer during setup and test.
This is where all you work happens during calibration and tweaking.
Use this to determine if the ranges and limits are set correctly.
After PRINTRUN is extracted from the archive, and the entire directory is moved to the python directory, I made a shortcut to prontrerface and put it in the task bar shortcuts area, next to the shortcut for sprinter.pde. Much easier to find.
testing the system
At this point, there should be a PC properly equipped with the correct set of software, and the software should be configured. The Sanguino board should have its power light on when plugged into the PC USB port, and the should be talking to the serial monitor program by displaying a START message (that the user has modified to display an individualized message).
Now to test using the interactive prython script pronterface.py from the kliment-Printrun package
Start Python
Start -> programs -> python 2.7 -> IDLE (the Python GUI
For some reason, at thispoint I get an error that an icon file was not found. This does not appear to affect anything, so if you see it, ignore it by closing the error message window.
From the Python Shell File -> Open (navigate to kliment-Printrun that you previously extracted) -> pronterface.py
From the pronterface.py window that opens: Run -> Run Module (F5)
If at this point you get a message "no module named serial" you missed the pyserial install from above. Recheck.
The Printer Interface window is displayed. If you get this far, you should be doing ok. If not, go through the steps again, it took me several tries.
printer Interface
Select your com port, usually com 3 or higher. If only physical com ports are displayed, check if the Sanguino go unplugged. The virtual com port goes away when the cable is disconnected.
Select your baud rate. 115200 works for mine.
Select the monitor printer checkbox.
Select connect.
The resonse window should display the Connecting.... message. After about 10 seconds, the Connected message should be displayed. The If the Sanguino is not connected, the message will sit there forever. Once connected, the window should begin displaying
T:0 B:0
periodically to indicate that the Sanguino is still ticking. This actually is reporting the thermistor readings for the extruder and heated bed. If the thermistors are not connected the reading is 0. If this becomes annoying, un-check the Monitor Printer box.
Steps per mm
The McMaster-Carr cogs and belts are XL, the step is 5.08. Using the formula from http://reprap.org/wiki/Prusa_Mendel_Assembly#Firmware_Calibration
[ 200 (steps) * 16 (microstep) ] / [ 5.08 (belt pitch) * 11 (pulley teeth) = 57.2655
This number worked.
So I changed
float axis_steps_per_unit[] = {80, 80, 3200/1.25,700};
to
float axis_steps_per_unit[] = {57.2655, 57.2655, 3200/1.25,700};
Maximum Travel
I found issues: The salvaged limit switches are a bit too big, some travel is consumed. The screws that hold the top print bed are high enough that they might interfere with the extruder end, so print area was trimmed to fit inside these.
- x = 200 => 190
- y = 200 => 180
- z = 100 => 95
Stepper current
Sacha told that he melted the solder off his stepper driver boards, from testing with the power turned up all the way. I turned them all the way down clockwise and them backed up a quarter turn. After some testing, I noticed them to be warm, so I adjusted them while in motion. The sound changes, you can hear them rumble if the power is too low, and they get loud if the power gets high enough. I tuned mine so that are quietest and still move. I may have to increase the power when I start extruding, but that is another day.
For the time being, the steppers and drivers are below 37 c during range of motion testing.
Extrusion test
I had heard that a DMM with a K-type temperature probe was required for setting up the heater coil, so I got one.
Turns out the MakerGear hot end is one of the options right in the software, and works as described. The thermistor reading and the probe reading were within a degree of each other. When I turned the heat on, the temperatures would vary by a couple degrees either way, but this can be due to the micro controller and thermal properties of the extruder head.
When the temperature reach 185 c, it was left to stabilize for a couple minutes. The temperature stayed between 177 c and 185 c. The 40 mm fan mounted on the X axis slide was sufficient to keep the rig from melting. The groove tube was about 50 c just above the heater coil and 30 c by the wooden plate, but I did not check this thoroughly.
I had two loop of PLA plastic for testing. To my delight, the machine was able to squirt out liquid plastic, which quickly hardened into a mass looking like tangled spaghetti.
Brainella and the Brainettes were marginally impressed.
Print Calibration 1
WHOA! Might be a little early for this, there's still some software we need to set up. But here are some cool things I found. However, there are objects specifically used for calibration the printer included in the software to be installed.....
Print calibration can be done by printing a 10 mm cube. A file for this can be found at Thingverse.
Hollow calibration cube http://www.thingiverse.com/thing:4249
Calibration set http://www.thingiverse.com/thing:5573
Skeinforge Bridge calibration cube http://www.thingiverse.com/thing:5011
Several things that can be useful for calibration:
40 mm cube http://www.thingiverse.com/thing:477
support test object http://www.thingiverse.com/thing:4360
weighted storage cube http://www.thingiverse.com/thing:6375
companion cube http://www.thingiverse.com/thing:1622
More on PC Software
In addition to the python scripts for manual/interactive control of the printer, additional software is needed to print from model files.
BEFORE ANY STL files can be printed, must determine method to get from STL to G-code....
Looking from the PC to the printer during set-up:
- ARDUINO.exe is the IDE to the micro controller. This PC application is used to load a software program (firmwae) onto the Aurdino/Sanguino electronics hardware.
- SANGUIINO is the set of hardware definitions that tell ARDUINO.exe about the specific hardware being used. It is slightly different from a stock arduino board, but if we have SANGUINO definitions loaded we don't have to worry much, all the differences are accounted for when we select "Sanguino".
- SPRINTER is the software program (firmware) we are going to use on the printer. SPRINTER is a G-Code interpreter. SPRINTER needs to be configured for you specific printer, including X, Y, Z travel range, stepper motor degrees per step, belt and pulley size, and baud rate.
- Configure SPRINTER for your rig
- Load SPRINTER into your ATMEGAxxx micro controller ROM. on power-up, the printer is ready to receive control commands.
Looking from the printer to the PC:
- SPRINTER is the software (firmware) that runs on the (ATMEGA644p, etc) micro controller that controls the printer actions. SPRINTER is a G-Code interpreter. G-Code is a series commands telling the printer to move or perform other actions. Feed the SPRINTER program G-code commands, and it will dance.
- PRINTRUN is package of scripts written in the Python language that send G-code commands from the PC to the printer micro controller. One of the python scripts isn the printrun package is PRONTERFACE.py
- PRONTERFACE.py is a python script in the printrun package. PRONTERFACE.py is a PC GUI application that allows the user to send G-code commands to the printer interactively.
Looking from STL files for various objects to the G-Codes neede to print the object:
Objects are commonly represented in STL format. STL files describe only the surface geometry of a three dimensional object http://en.wikipedia.org/wiki/STL_%28file_format%29
STL files must be translated into G-Code in order for a G-code interpreter to preform the printing operation.
<< Currently determining an appropriate STL to G-code translation software >>
20111202 - OK, I got SFACT to talk to PRONTERFACE, and it went through the motions of printing.
Here's my notes as I set it up on the target PC (to free up my gaming PC for its intended purpose, games).
SKIP THIS SECTION
So, I'm trying to figure out how to get from STL files to G-code. There are too many options, the "old standard" seems to be skeingforge + ReplicatiorG, the new easy way might be OpenSCAD + KISSLicer ? ... looking...
This page has a good explanation?
http://reprap.org/wiki/Alternative_Software
The above page is named Alternative Software but has the title CAM ToolChains.
What software to load on the PC?
Currently the goal is to get a calibration object from thiniverse in STL format, and print it as a calibration test.
TRY - KISSLicer first, then look at others - contacted lonesock
NOTES about Python scripts
Python is an interpreter/compiler for the PC that runs programs written in the Python language.
When Python source code is compiled, we usually call it a program.
When Python code is executed by the interpreter, as from the command line, we usually call it a script.
In any case, the result is the same, the Python source code executes and does what the program has coded.
Python is getting more popular on the PC, as it is easy to to do thing we typically want to do on a PC, like writing user interface, and script processing.
ReplicatorG is another Python package. This series of scripts converts the head motions (given from skeinforge) into Gcode. GCode is the descrete series of command that actually move the print head. It also provides a user interface to the process. ReplicatorG Includes Skeinforge.
Skeinforge is another package of Python scripts. Skeinforge converts the STL model into Z layer slices for printing. I don't know where the term "skein" came from for use as "slicer" it does not appear to be used this way in English. UPDATE - I figured this out after a couple more days. "Skein" is a bundle of yarn (or hair or threads), and each layer or slice is composed of a bunch of threads of extruded filament. A "skein" would usually mean a single length of yarn, while a layer would typically have more than one thread of filament, so there is some license taken with this term. No biggie, just another thing to learn while catching up to the guys that created this.
Anyway, the slicing process is a little complex, as you might image, it has to take to take the triangles in space that efine the surfaces and comnvet then into flat layers with a defined thinkness and width. I guess its not that complex, but it is tedious. The output of Skeinforge is motions the print head should move to extrude the model. Initially Skeinforge needed an optimization package call psyco, this may or may not be needed at this point.. We don't directly install skeinforge as it is included in ReplicatorG. If you try to install in the order the tools are discussed, and end up trying to install skeinforge first, you might notice problems.
PRONTERFACE.py in the PRINTRUN package is in Python. PRINTRUN package is a a series of scripts that forma usrer interface to the printer software running on the ATMEGA or similar micro controller.
SFACT is another python package of scripts. It does the same thing as skeinforge, but represents the calculations in a different way, making it easier on the person running the printer. (Skeinforge seems to have been written from the programmer point of view, and while excellent, presented difficulties to people that were not the original programmer, which is a typical occurrence). SFACT is seems to rely on an installation of skeinforge (ie via ReplicatorG) installed before it works. There are steps below to achieve this.
IN THE BEGINNING, it seems that folks use ReplicatorG + Skeinforge were the popular way to go.
AS OF THIS WRITING, Pronterface + SFACT appears to be the new popular way to go.
HOWEVER, much of the documentation is written from the perspective of "upgrading" from ReplicatorG+Skeinforge to Pronterface+SFACT. While this applies to most folks that are already printing, it does NOT apply to folk just starting out. This is alos a common occurrence. Thus it appear difficult to start, since the docs all assume things that are not present. In fact, setting up the software is really simple, it just is not properly documented. The purpose of this log is to capture the current process fro setting up the tool chain, and maybe to demonstrate the merit of user-oriented documentation (versus programmer-oriented documentation, which can be little more than gibberish to non-programmers).
STL to G-code Toolchain
This section covers the (presently) involved set up of the STL to GCode tool chain.
The final target set-up is PRONTERFACE+SFACT.
An intermdeiate set-up is preformed, as SFACT rerquires a prior installation of skeinforge, and skeinforge is installed with ReplicatorG.
So here's what's in store:
- Install ReplicatorG to get skeinforge
- partially set up ReplicatorG to get SOME communication and definitions established.
- partially run skeinforge to get some communications and definitions established.
- Install SFACT to get the NEW IMPROVED changes to skeinforge
- Use PRONTERFACE as the final target interface
ReplicatorG (intermediate) setup
I selected Machine-> "klimentkip (115200 baud)" since this others did not look like my machine I selected com12, that was the only virtual port
"Connect" started communication with machine! Hahahaha!
GCode -> EDIT BASE PROFILES brought up a window with several selections that could not possible fit BUT... Selecting the one that says PLA then selecting DUPLICATE allowed me to create a new profile, and modify it. THIS is the key!!! Ha HA!! And they said I was mad!
Now I can connect to the printer using the "connect" button at the top.
"Control" now works, Homing can acitvate the printer.
Move the print head to the center of the XY bed, and make this position ZERO
The extruder still does not operate, this is ok; the goal is to use SFACT in the next step.
Hit GENERATE GCODE and it processes.
Now, in the control panel, the extruder has a non-zero motor speed, and can run forwarrd or backward.
But, the GCode does not enable anything to initiate a print? The BUILD button means START PRINTING.
Sort of, the extruder still does not move, the Z axis does not move.
SFACT (skeinforge intermediate configuration) setup
Download SFACT.
http://reprap.org/wiki/Sfact says to use http://www.reprapfordummies.net/index.php/softwaresection/44-gcode-generators/49-sfact-homepage which says to use http://www.reprapfordummies.net/downloads/SFACT.zip so I downloaded that.
Extracting the arhive gives me the README.txt which says:
Extra the archive (anywhere) (which I already did, because I'm reading this)
Go into folder skeinforge_application. and Click skeinforge.py
Now all the magic happens!!!
A window opens fo skeinforge, but says SFACT in there someplace, so I hit save, and the magic window says something got saved. Looking at PRofile -> extrusion it says PLA is checked, so I am happy again.
I have no idea about dimensions, as I have never printed anything yet, so I close the window.
back to PRONTERFACE
NOW I look at the warning about PRONTERFACE again....
(CAUTION: If you want to use SFACT from within Pronterface, you need to copy the files into a folder called skeinforge within the folder of Pronterface. Then you will need to manually copy or move the sfact_settings folder into that directory as otherwise SFACT wont see the default profiles shipped with it.)
Under the Python27 directory, I have moved the PRINTRUN directory.
Under the ../Python27/PRINTRUN/ directory, I have created a directory named /skeinforge/
Under the ../Python27/PRINTRUN/skeinforge/ directory, COPY EVERYTHING FROM THE SFACT ARCHIVE HERE
That is, everything in the SFACT.zip archive in directory "ahmetcemturan-SFACT-1bc51b0", copy six directories and six files to the manually created /skeinforge/ directory under /PRINTRUN/ in the /Python27/ directory
Now start up PRONTERFACE as above, and it works.
Printing an STL file
Now, opening an STL file causes PRONTERFACE to run skeinforge with the SFACT settings
OTHER OPTIONS for STL to Gcode
These are things I started but did not end up in the final tool chain
kissslicer
SKIP THIS SECTION
http://www.lonesock.net/kisslicer.html
KISSlicer runs on the STL calibration models I tried, even on the ancient Duron 750Mhz windows box.
Per the instructions, three configuration files were generated the first time is was run.
Per the instructions, the output files are named with the original file name plus the string "_gcode.bfb" appended.
What do we do with the BFB files? Do we just chop off the "_gcode.bfb" and re[place it with ".gcode"?
Where is the print origin, do we start from "home" position or from the center of the build platform?
Contacted lonesock, he has a beta for a GUI he wants tested
JAVA
SKIP THIS SECTION
NOTE: this seems like an early tool, or specific to a particular hardware? SKIPPING this for now...
REPRAP - this PC software application option is unfortunately named identically as the class of thing we are talking about. This might be just me, but shouldn't this be better named "JAVA PC software Application for controlling the REPRAP machine"?
Are Driver software and REPRAP both referring to the java option for STL to G-code?
http://reprap.org/wiki/DriverSoftware http://reprap.org/wiki/Installing_RepRap_on_your_computer
Folks report the java option is buggy? java 6 has issues, use java 5 instead? Using sun java, the other java has issues?
SFACT - friendly skeinforge
SKIP THIS SECTION it covered above. This is in case I need the old notes later. Delete this section when above notes are complete.
SFACT is described as a user friendly version of skeinforge. It uses different setting in a different directory, from skeiforge
>>> Now that I have ReplicatorG installed first, this might work out better? <<<<
The fun first thing is in the README.txt file:
The means under the PRONTERFACE directory, we should create a directory and name it "skeinforge" and copy ALL of SFACT into this folder.
Then we have to do something with the "sfact_settings" directory. Move this into the newly created "skeinforge" directory? Didn't we just do this with the copy operation? Maybe it means the "sfact_settings" directory needs to go into the PRONTERFACE directory? In any case, something must be copied, and something else must be moved or copied.
CHECK THIS
At this point, I've go so many things intstalled, I don't know what is working and what helps versus what is noise. Time to uninstall and do a system restore and proceed from a known point.
PRINT CALIBRATION
Earlier, calibration steps were performed for the truing of the chassis, for the belts and motors, for the electronics settings, and for the motion of the head.
Now, with those complete, and all system areas operational, we can perfom print calibration by tweaking the setting for controlling extruder temp, feed rates, requgested layer thinkness and extrusion width, etc.
<20111203 in progress....>
Buying filament
I was advised to start with PLA. It is "easier to print" and does not require a heated bed. Following this advise, I got 5 lbs of red on a spool.
http://ultimachine.com/content/pla-3mm-red-5lb-spool
I wanted the natural, but it was sold out http://ultimachine.com/content/pla-3mm-natural-5lb-spool
Red is said to be "gloopier" I guess the dye affects the plastic properties. After I print 5 pounds of red I will decide if its time to get natural (which seems to be dye-able using magic markers http://www.thingiverse.com/tag:marker) or move up to a heat build platform (HBP) and ABS.
initial prints
The 20mm box looked great.
The 20mm hallow box was great except the top sags.
The simplified bridge looks passable
The over hang test looks like crap, there are lots of stray loops that did not laminate to the neighboring layers
The pirate ship looks recognizable on the side nearest the 40mm fan, but the side away from the fan looks like it went through a battle with another mini pirate ship.
I know there is a "dimension" tab with calibration in SFACT, but first I will check the mechanicals on the the unit. I hear the screws tend to loosen up(?)
After adjusting the Z-axis belt
http://www.thingiverse.com/thing:5573 (Has instructions)
- 20mm box
- 20mm hollow box
- bridge overhang test
http://www.thingiverse.com/thing:477 40mm Cube Test Object
http://www.thingiverse.com/thing:11387 Minimal bridge calibration block
checking the Belts
I see the X axis belt deflects when the X axis motor turns, in a way that the Y-axis belt does not. I remember taking special care to adjust the Y-axis belt during assembly. I did not torque down the X-belt for fear of breaking something (like the X-motor mount in particular). I suspect that this is a contributing factor to my issues on the sloppy looking loops during print. < to be continued >
The instructions for SFACT say its mostly good to go, you MIGHT want to calibrate using the check box in the "dimension" tab. This is only true AFTER your done everything else, which is not mentioned in the FAQ.
The "everything else" is a bit involved:
Calibrating E_steps_per_mm
The sprinter firmwaer has a couple examples of values for step per mm in the configuration.h file. The does not apear to be an variable names e_steps_per_mm in the sprinterfirmwaer code.
//// Calibration variables // X, Y, Z, E steps per unit - Metric Prusa Mendel with Wade extruder: // float axis_steps_per_unit[] = {80, 80, 3200/1.25,700};
I marked 100 mm of the filament from the top of the extruder. Set the EXTRUDE value in pronterface to 100, and hit extrude. I did this several times and found on averrage 75 mm of filament was processed. Changing 700 to 500 and the same steps averraged 65 mm extruded. Changing to 2000 gives....
Calibrating using CARVE
The instructions say to start by setting the values for Extrusion Thickness and Extrusion width to something sane. This is helpful, if only we know what defines sane in this context. Later it says extrusion thickness should be slightly less than nozzle diameter, and Extrusion Width should be slightly greater than nozzle diameter. With a nozzle diameter of 0.5 mm the default extrusion thickness of 0.4 mm is 20% less, and the default extrusion width of 0.6 mm is 20% more. I tired the overhang test from costermans calibration set. http://www.thingiverse.com/thing:5573
The big one was a challenge. I had fair results with extrusion thickness 0.38 and extrusion width of 0.52, but the big one kept dropping loops. at first it appeared that the hob bolt (actually a Dremeled threaded rod) http://suddendevelopment.com/?p=68 resulted in a working diameter the needed adjustment of the e_steps_per_mm. Now it appears the hobs were not cut deep enough, and clog too easily, again resulting in inconsistent filament feed. Back to the hobbed bolt again! Previously, I cut only as deep as the threads. Next try will be much deeps cuts.
Calibrating using Dimension in SFACT
The instructions say to click the "calibrating" check box, and to uncheck it when we're done. I found the FAQ is largely a repeat of the regular instructions, BUT hidden in the FAQ is includes a helpful hint:
Do not print any G-code that is output with the "Are You Calibrating" checkbox on. That is only to give you the packing density/e-steps corrector value. Enter the value into the box and then skein again and print.
This means that we UNCHECK the "are you calibrating?" check box every time we do a test print.
First time through, it got worse. The second time through, after I found the FAQ, I settled on entering values for my RED PLA as diameter 2.75 mm and a resulting Filament packing density of 0.81
In another part of the instructions, it points out that if the FILAMENT FEED is inconsistent, the calibration will not correct it. It turns out that my hobbed bolt gets clogged after a bit, and starts to slip.
I don't know if this is due to
- too much pressure on the spring feeding the hobbed bolt
- too much tension on the filament line (don't think so, it pulls pretty easily)
- the curve of the filamet line is binding in the xtruder head
- 8mm hobbed bolt is too small diameter
- Hobbed bolt is hobbed incorrectly
- filament is inconsistent and gets fat in places, clogging the feed
- filament is inconsistent chemically, and parts are softer of melt at differrent temperature
- PLA is just soft and needs to be clear from the bolt every 35 minutes
>>>> Did the 50 mm extrusion test. Turns out the hobbed bolt has at least one spot where the feed pauses. Time to re examine the hobbing process...... <<<<
In the explanation for "bridge" and "bridge layers" it states the feed/flowrate is set under SPEED. It also states
adjust the spacing of these 100% fill lines and also the nozzle diameter setting is needed here to be able to calculate a "natural flow" for the nozzle.
I wonder what that means? "Bridge width multipler ratio" and "overlap remover" do not appear related to "fill lines". :(
This is another puzzler:
The bridge settings will only kick in if Infill in direction of bridges is checked. This setting will cause for some fully filled layers if you are printing shapes with all-around overhangs (especially organic shapes or statue like things). They might appear random to you but this is the reason for that.
This setting does not appear in INSET, FILL, SPEED or DIMENSION. Nor can I find it in the other selections. It must be infered or calculated from other settings? There are settings for Infill in Leadin and Skin, bu not "Infill in direction of bridges".. Maybe there's no way to turn this on?
The FAQ and the instructions explain "What is CLIP. What does it do? CLIP adjusts the gap between the start and the end of the perimeter (outermost) extrusion."
Wouldn't "perimeter gap" be a sensible name for this?
Creating STL MODELS
20111203 this in next on the TODO list after print calibration is complete
OpenSCAD
<< This was recommended >>
http://reprap.org/wiki/Useful_Software_Packages#OpenSCAD
Blender
Blender is a 3D graphics package. It can make movies and animations. We only want objects, this might be overkill?
Google Sketchup
Makes 3D models
http://sketchup.google.com/intl/en/download/
This page has a list of software for making custom STL files
