Phase 1
Description | An affordable high performance 3D printer
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Phase 1 is an affordable high quality RepRap 3D printer.
Overview
Phase 1 was created to be a value 3D printer available. Phase 1 prints reliably and accurately at a price that you can afford. Phase 1 affordably delivers the full experience of assembling a RepRap 3D printer without sacrificing performance and build volume.
Development
Phase 1 Revision 1
Timeframe: (June, 2016 - October, 2017)
Base Features:
- 200x200x200 Build Volume
- Heated Bed
- E3D compatible extruder
- LCD screen
Issues:
- Lack of frame led to heavy Z-wobble
- Z-endstop mount was not secure enough for repetitive use
- Power Supply not attached
- X-axis misalignment
- Difficult assembly due to threaded rod deisgn
- No print fan
- Electronics loosely housed in center under heated bed
- No heated bed insulation
- Brass X-axis T8 nut wore down over time leading to backlash and debris
- Left Z-motor sometimes fails to move
- Power Supply exposed
Revision 2
Timeframe: (November, 2017 - March, 2018)
Version Goal: Increase Z-axis stability, safety, and ease of use
Improvements:
- New Frame design adds ease of assembly and stability
- Z-top mount reduces Z-wobble
- Bed auto-tramming support for inductive probe
- Electronics moved to back of frame for easier access and airflow
- Print to cool prints
- Power Supply Cover with switch
Issues:
- Slim width causes overall instability
- Axial fan fails to provide adequate airflow
- Power Supply not mounted
- Hand-cut frame, no clear dimensions
Revision 3
Timeframe: (April, 2018 - June, 2018)
Version Goal: Increase overall stability, reproducibility, and add "premium" features
Improvements:
Unnamed (rev. 4)
Timeframe: (July, 2018 - Present)
Issues:
Features
- 200 x 200 x 200mm Build Volume
- MK3 Heated Bed Standard
- Printing Speeds of up to 60 mm/s (faster has not been tested)
- Fits all e3D hotends
- Print Resolution down to 50 microns
