NEMA 17 Stepper motor
Revision as of 09:07, 24 February 2015 by Matthew017 (talk | contribs) (Common Stepper Motor Models)
Vitamin
A NEMA 17 sized stepper motor.
Wikipedia Stepper motor
another NEMA-17 size motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Dimensions
the most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
References
You are welcome to add information on a stepper motor you encounter, but please add only steppers not other motors which were tested to actually work on some or all printer.
The most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
Model Holding Torque Rated voltage Shaft Step angle Motor length
42HT47 44 N·cm 2.8 V Ø 5 mm Dual 1.8° 47 mm
42SHD0404-22 52 N·cm 3.84 V Ø 5 mm Single 1.8° 48 mm
42BYGH4803(SKU 1124030) 54.0 N·cm 4.2 V Ø 5 mm single 1.8° 48 mm
42BYGH4803-DC (SKU 1124090) 54.0 N·cm 4.2 V Ø 5 mm single 1.8° 48 mm
1040222 88 N·cm 2.6 V Ø 5 mm single 1.8° 48 mm
LDO-42STH47-1684A 50 N·cm 2.8 V Ø 5 mm single or dula 1.8° 47 mm
4118S-62-07 31 N·cm   Ø 5 mm 1.8° 34 mm
17HS4417 40.0 N·cm 2.6 V Ø 5 mm single 1.8° 40 mm
SM-42BYG011-25 23.0 N·cm 12 V Ø 5 mm single 1.8° 34 mm
17HS1011-20B 28.0 N·cm 4.8 V Ø 5 mm single 1.8° 34 mm
17HS3001-20B 40.0 N·cm 2.0 V Ø 5 mm single 1.8° 40 mm
17HS5005-S24 44.0 N·cm 3 V Ø 5 mm double 1.8° 48 mm
17HS6002-27B 65.0 N·cm 4.05 V Ø 5 mm single flat 1.8° 60 mm
17HD2038E 45.0 N·cm   Ø 5 mm single 1.8°
17HS19-1684S 55 N·cm 2.8 V Ø 5 mm single 1.8° 47 mm
KH42JM2B087C 33 N·cm 6.7 V Ø 5 mm single 1.8° 42 mm
SY42STH47-1206A 31.1 N·cm 4.0 V Ø 5 mm single 1.8° 40 mm
SY42STH47-1504A 55.0 N·cm 2.8 V Ø 5 mm 1.8° 47 mm
SY42STH47-1684A 43.1 N·cm 2.8 V Ø 5 mm single 1.8° 48 mm
SY42STH47-1684B 43.1 N·cm 2.8 V Ø 5 mm double 1.8° 48 mm
TB35HT36-1004A 35.3 N·cm 2.8 V Ø 5 mm single 1.8° 36 mm
TB35HT36-1004B 35.3 N·cm 2.8 V Ø 5 mm double 1.8° 36 mm
QSH4218-51-049 49 N·cm   Ø 5 mm 1.8° 47 mm
42BYGH W811 47.0 N·cm 3.1 V Ø 5 mm 1.8° 48 mm
--- ignore everything below, this page is a work in progress to build a table without all the external linking ---
417-11-48-02 7.0 N·cm   Ø 5 mm 1.8° 28 mm
4018X-07-04 11.0 N·cm   Ø 5 mm 1.8° 26 mm
4118L-25P-07R0 48.5 N·cm   Ø 5 mm 1.8° 48 mm
KH4248-B95101 48 N·cm   Ø 5 mm single 1.8° 48 mm
PK244-01AA 33.0 N·cm 5.6 V Ø 5 mm single 1.8° 39 mm
PX243M-03AA 20.0 N·cm   single 0.9° 42 mm
PX243M-01AA 15.0 N·cm   Ø 5 mm single 0.9° 33 mm
17H185H-04A 43.8 N·cm 2.8 V Ø 5 mm single 1.8° 42 mm
17H185H-04B 43.8 N·cm 2.8 V Ø 5 mm double 1.8° 42 mm
KH42KM2R001 45 N·cm   Ø 5 mm
42BYGHM809 48 N·cm 3 V Ø 5 mm 0.9° 48 mm
42BYGH404 31 N·cm   Ø 5 mm single 1.8° 49 mm
YH42BYGH47-401A 55 N·cm 2.8 V Ø 5 mm single 1.8° 47 mm
B6524772A 23 N·cm 3.9 V Ø 5 mm single 1.8° 34 mm
