MKS BT
This design doesn't even claim to be Open Source and also comes with no sources, so you can't make a copy or learn from it without re-engineering. RepRap recommends to prefer open source designs, which come with sources at least sufficient to make a copy. Open source enhances freedom and is also the foundation which made RepRap so awesome.
If you want to help improving this design, please ask the designer/vendor to release it under an open source or open hardware license and also to upload such sources to this wiki or to link to the repository containing them. If he did, remove this message. For intermediate/partial cases, there's also Template: NotOpenSource.
Release status: Working
Description | BlueTooth
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
MKS BT is a board that contains the hardware of the hc06 chipsets. This is a bt adapter that is used on some reprap ramps and MKS Gen with bt connection.
Print over Bluetooth
In order get rid of the USB connection between RAMPS or MKS Gen and the PC one may like to use Bluetooth.
You can connect MKS BT on AUX-1, and the default baut is 9600. You can change it Melzi
Connect
Connect RAMPS 1.4
Connect MKS GEN
