LabRap/en
[[::LabRap/en|español]] • [[::LabRap/en/en|English]] • [[::LabRap/en/fr|français]] • |
Description | LabRap 1.0, made by RepRap Chile Inspired by the P3Steel. |
License | GPLv2 |
Author 1 | Labotecno |
Author 2 | Hanlest |
Author 3 | Ricardo Pinto |
Contributors | RepRap Chile |
Based-on | P3Steel |
Categories | Prusa i3 Derivate, Cartesian-XZ-head |
CAD Models | File:LapRap Plano corte.zip |
External Link |
- 1 Introduction
- 2 Improvements included
- 3 Proteins
- 4 Vitamins
- 5 Electronics
- 6 Mecanical parts
- 7 Smooth bars
- 8 Laser cut parts
- 9 Firmware Marlin
- 10 Extruder
- 11 Videos
- 12 Optional upgrades
- 12.1 608ZZ bearing cover :
- 12.2 System for x axis endstop
- 12.3 Converter M5, M8 threaded rod to leadscrew:
- 12.4 Glass clip
- 12.5 Cable chain
- 12.6 Suport for wire
- 12.7 Layer fan
- 12.8 Electronic protection
- 12.9 Mount for ATX-PSU power supply
- 12.10 LM8UU Bearing printed
- 12.11 Adapter for printer board endstop
- 13 Links
Introduction
Designed and built by the group 'Reprap Chile',
Made of the prototype
- The upper brackets of the shaft flat rods joined in one piece Z
- Threaded rods by screws were changed to improve print quality in the Z axis
- The arm holding the filament to withstand rolls of 200mm in diameter and 100mm wide changes.
- Frame is modified to allow the use of a single roll of filament or two as needed.
- Two small parts for truck extruder that lets you choose between a single or double one extruder added.
- It extends a few millimeters bracket Y-axis motor to prevent this abutting the anchor nut.
- A belt tensioner is added to the Y axis
- Perforations are added to mount vertically and horizontally electronics.
- Available space is left for mounting the case then acrylic.
Proteins
The LabRap printer does not require printed pieces, unless a direct extruder MK8 is used.
Adaptador para extrusor directo
Description | Link | Image |
Adapter for direct extruder | http://www.thingiverse.com/thing:835475 |
Vitamins
Tools
Electronics
Parts | Quantity | Unit price | Total price | Image |
Arduino Mega 2560 board (or compatible) | 1 | - | - | |
RAMPS 1.4 board | 1 | - | - | |
Pololu stepper driver board. | 4 | - | - | |
Mechanical Endstop | 3 | - | - | |
Type B USB wire 1.8 meter | 1 | - | - | |
Wire motor Nema 17 | 4 | - | - | |
Wire endstop 40 cm | 2 | - | - | |
Wire endstop 85 cm | 1 | - | - | |
Fan 50 x 50 mm | 1 | - | - | |
LCD Screen control | 1 | - | - | |
Heat bed 200x200 | 1 | - | - | |
Thermistors 100K (1xHeatBed 1xHotEnd) | 2 | - | - | |
Power supply (12v 20-30A) | 1 | - | - |
Mecanical parts
Linear bearing LM8UU | 11 | - | - | |
Ball bearing 608zz | 2 | - | - | |
Pulleys GT2 | 2 | - | - | |
Pulleys GT2, 6mm | 2mt | - | - | |
Flex Coupling 5mm a 8mm | 2 | - | - | |
NEMA 17 steper motors | 5 | - | - | |
Lead Screw THSL-300-8D | 2 | - | - |
Smooth bars
They are necessary 6x8mm steel bars of the following sizes:
- 2x Ø8x395 mm for X axis.
- 2x Ø8x341 mm for Y axis.
- 2x Ø8x320 mm for Z axis.
Laser cut parts
- 58 pieces cut into 3mm thick aluminum.
DWG file with the blueprint cut parts.
File:LapRap Plano corte.zip LapRap_Plano_corte Autocad 2010-2013
Firmware Marlin
Firmware con los parámetros probados. File:LabRap v1.0-200mm-Marlin-Release.zip
Extruder
The LabRap model is designed to using an bowden MK8 extruder and E3D V6 hotend
It is also possible to use an MK8 extruder with a corresponding adapter Download adapter File:Mk8 Extruder mount for Prusa i3 Rework.zip Mirror
Other model for adapter: Download alternative adapter (Sintron)
Download alternative adapter 2
Other extruders
MK8 extruder + V6 HotEnd
Kuro's compact bowden geared extruder
Compact bowden extruder
Prusa i3 direct drive bowden extruder
Geared extruder v.3
Videos
<videoflash>mb4Pr4k5BpU</videoflash> <videoflash>MXxVImFkHi4</videoflash>
Optional upgrades
Allows the pulley is always kept at the center of the bearing. bearing cover for 608ZZ
This piece is to improve Endstop Z axis, it is composed of a knob and a spring. EndStop Z axis
Allows a M5, M8 threaded rod screw instead of a leadscrew.
Adapter M5 - leadscrew - - Adapter M8 - leadscrew
Glass clip
This part replaces the metal clip lifetime. Printers clip
Cable chain
This piece allows better ordering cables and prevent tangling with each printing. Option 1 Option 2
Suport for wire
Layer fan
This part allows to install a layer fan in a MK8 extruder. Layer fan
This piece protects the electronics inside a box. RAMPS Case
This piece allows mounting a ATX power supply. Mount ATX
This piece allows replacement LM8UU bearings of a printed version. Bearing printed
This piece allows use normal Endstop instead of the micro-swith.
