FuseBox
Revision as of 23:05, 7 August 2015 by AlexY (talk | contribs)
FuseBox
An affordable aluminum-framed CoreXY printer.
FuseBox is a low-cost CoreXY 3D printer that uses an aluminum extrusion frame.
Goal
To design an affordable and accessible 3D printer using CoreXY kinematics that offers high speed and quality.
Features
  • Aluminum structure based on Misumi 1515 extrusions and printed brackets
  • Uses a stacked variant of CoreXY that eliminates belt crossing
  • Total materials cost under $350
  • 210x160x200mm build area (200x200x200 for heated bed versions)
  • Capable of 0.05mm layer height and 150+ mm/s printing
  • Mostly RepRappable parts and easily hackable/upgradeable
  • Relatively low amount of filament needed for plastic components
  • Provision for direct and Bowden extruder setups (currently only Bowden is supported in latest version)
  • Low moving mass—all motors stationary except extruder motor in direct-drive version
  • Portable—all hardware and electronics (except for filament spool) are integrated within the frame
  • No specialized tools or equipment necessary for assembly
Bill of Materials
Printed Parts
A zip file containing all the printed parts can be found here: File:FuseBox Printed Parts.zip
Other Parts
Item Quantity Note
1515 Extrusion 380mm 4
1515 Extrusion 330mm 2
1515 Extrusion 345mm 4
1515 Extrusion 243mm 2
1515 Extrusion 386mm 2 optional but highly recommended for greater rigidity
M3x6mm Bolt 96
M3x10mm Bolt 10
M3 Nut 100
M5x25mm Bolt 6
M5 Locknut 6
625 Bearing 9
250mm M8 Threaded Rod 1
300mm M8 Smooth Rod 6
LM8UU Linear Bearing 4
LM8LUU Linear Bearing 4
5mm to 8mm Flex Coupler 1 Clamping type preferred to reduce wobble
2mm Pitch GT2 Belt 3m 1
20 Tooth GT2 Pulley 2
Bed Leveling Springs 4
RAMPS 1.4 1
Arduino Mega 1
NEMA-17 Stepper Motors 4 Tested with 76 oz-in steppers
12V LED Power Supply 1 Tested with a 30A supply
40mm 12V Fan 2
MK8 Drive Gear 1
Medium Binder Clip 2 Remove handles to use as extruder idler tensioners
E3D Lite6 Hotend 1
8"x10"x 0.125" Glass Sheet 1 Used as a cheap and rigid PLA printbed; heated bed available
Stick-on Furniture Feet 4 Optional
Development
Version 1.0
Initial variant. Uses a non-intersecting CoreXY design to eliminate belt crossing issues.
Issues
  • Z-axis issues—slight wobble and linear bearing binding
  • Slight rigidity issues caused by weak corner joints
  • Extruder grip issues leading to inconsistent extrusion
  • Untidy wiring
Todo
  • Endstop integration (possibly with inductive z-probe)
  • Cooling fan addition to improve bridging and top speed for small parts
  • Bowden option for lower moving mass (will retain direct extruder for flexible materials)
  • Diagonal aluminum braces on sides
  • Reduce clearances for additional build area
Version 1.1
Extruder carriage and fan duct
Changes'
  • New compact extruder design with more solid hot end mount and fan duct addition
  • Bowden extruder carriage designed; cold end still in development
  • 608 bearing idler replaced by a 625 idler
  • XY-gantry made more compact, resulting in ~18mm increase in maximum z-axis height
  • Z axis changes: bar spacing reduced, additional reinforcement for z-nut crosspiece
Issues
  • Slight z-wobble
  • Rigidity
  • 625 Idler breakage problem
Todo
  • Additional bracing
1.1B
Uses a bowden extruder and replaces Aluhotend V6 with an E3D-Lite6. New idler design improves strength and extrusion consistency.
Version 1.2
FuseBox 1.2 Render
Changes
  • New Y Bar attachments using 1 bolt each
  • Integrates bowden extruder and print fan
  • Larger corner braces
  • Cross braces on sides
  • Added option for 30mm hotend cooling fan
  • 10mm additional x-axis travel
Version 1.2h
Changes
  • Heated bed support
  • Wider z-rod spacing to accommodate heated bed
  • Additional z-axis bracing
  • Adjustable z-endstop
  • Additional y-axis travel
  • Replaced corner brackets with flat plates on lower x-axis
Videos
<videoflash>I3xibPxbO2s</videoflash> <videoflash>qRtPtuInjQw</videoflash>
Gallery
