Frax3d
Description | 3D Printer, metallic structure, Core XY
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Frax 3D
Frax3D is a 3D printer that has a CoreXY system that allows us to work faster due to its low inertia. Its structure is completely of stainless steel sheet metal, giving a professional finish, greater structural rigidity and compact design. This 3D printer can operate with a print speed of 80mm/s.
This is a completely OpenSource 3D printer and therefore all components used follow this philosophy and are fully interchangeable by any other similar component (not limited to our processors, filaments, extruder, etc.). Also, in the design, they are included all necessary geometries so that this project can be expanded or modified (for example different extruders and fittings extra holes to attach any gadget that you consider appropriate).
Characteristics of the new Frax3D:
- CoreXY System for lower inertia and higher print speeds and acceleration
- Wide range of available materials thanks to their Full metal extruder E3D
- Different possibilities of extrusion (direct or bowden) with one or two extruders
- High definition printing (HD) with a calibrated spindle and special nut on the Z axis. Layers of 0.1mm or less
- Heated bed (MK2b 200x200mm) to print ABS, PLA, HIPS, Flexible, nylon …
- Autonomous 3D printing thanks to LCD screen and button and SD card reader. No need to be connected to a PC
- Easy operation
- Simple, compact and elegant design
- OpenSource technology
- Easy to assemble.
Interesting Links
Page of the author: Frax 3D Online store: BCN Dynamics
