File:Diy supports floating blender 001.png
Revision as of 04:51, 21 June 2015 by Jaggz (talk | contribs) (A couple examples of DIY supports, in blue. The "floating" supports at the top are fins which are spaced from the vertical pink wall by about .21mm. They are roughly .35mm below the horizontal solid object surface above, and about 1.5mm apart from eac...)
Size of this preview: 698 × 600 pixels. Other resolutions: 280 × 240 pixels | 964 × 828 pixels.
Original file (964 × 828 pixels, file size: 55 KB, MIME type: image/png)
The "floating" supports at the top are fins which are spaced from the vertical pink wall by about .21mm. They are roughly .35mm below the horizontal solid object surface above, and about 1.5mm apart from each other. The 0.21mm horizontal spacing allows the slicer, in this case, to avoid printing them as a single piece with the main object's body, but it's close enough that the filament curl and bulge allowed the supports to lightly touch and join the object body, but be readily removed with minimal bonding and marking.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 04:51, 21 June 2015 | 964 × 828 (55 KB) | Jaggz (talk | contribs) | A couple examples of DIY supports, in blue. The "floating" supports at the top are fins which are spaced from the vertical pink wall by about .21mm. They are roughly .35mm below the horizontal solid object surface above, and about 1.5mm apart from eac... |
- You cannot overwrite this file.
File usage
The following page links to this file:
