Category:Development
Revision as of 16:09, 5 November 2010 by Buback (talk | contribs) (How To Add a Development: linked to electronics naming conventions page)
An Extruder Design on a Reprap Darwin
This page aims to contain links to all RepRap related development. This is the leading-edge and experimental part of the RepRap experience!
If you are here because you are looking for how to be involved with the development of the RepRap idea itself and want to be a part of it, please contact one of the Core Team here.
You are encouraged to add RepRap- and RepStrap-related work, even if you didn't initially create it; just make sure to attribute it appropriately. Please also include as many pictures and diagrams as you can. These really help understanding.
Adding development work from the Main Blog, the Builder's Blog and the Forums so that new RepRappers can find it is especially appreciated.
This page shows all current and previous development for the Reprap project. This is the place to put your build logs and to document your research; You will reach a much larger audience if you post here, rather than in your personal blog, and the wiki framework allows others to contribute and expand on your ideas.
If you have never contributed to a wiki, first try filling out your user page. That should give you an introduction into how to edit pages.
If you have a project that needs it's own page, just type its name into your browser navigation toolbar like this:
    http://reprap.org/wiki/My_Development_Page_Name
and hit return.
It's best to pick a unique name, but also try to get a feel for the current naming conventions before settling on a specific name.
If you choose a name that's already taken by someone else, that page will come up so you will know. If your name is new, you'll get instructions. Click on "edit this page".
Infobox
All development pages are identified by an info box in the upper right of page. To add an empty infobox to your page (and appear in the list below) add:
{{Development:Stub}} //identifies pages under construction. remove when the page is relatively stable.
{{Development}}
To the top of your page. You will want to add info into this infobox, of course. The Info box, like anything on a wiki, is constantly being modified and improved, so for a list of Infobox template parameters, go to the Template:Development page.
Other useful templates
Other templates can be added to a page as well. you can use them as flags to alert other users to issues with a page, or of upcoming changes. Templates can be added by putting {{ currly brackets }} around the template name. Some templates have useful parameters, so it's best to check the template page for more detailed instructions.
reference example
  • Development:Example - an example development showcasing commonly used mediawiki features. This is just an example! please don't use this!
