Belts and Pulleys
Revision as of 20:09, 14 July 2012 by Emmanuel (talk | contribs) (Created page with 'Category:Suppliers_by_Part See also Choosing_Belts_and_Pulleys ==Belts== {| class="wikitable sortable" |+ |- style="background-color:#f0f0f0;" ! Supplier !! From !! T…')
Belts
Supplier From Type available Pitch Width Length Material Approximate Cost Additional notes
BBMan US Imperial/Metric
Econobelt US many
Misumi multiple
Royal supply US GT2 2 mm 6 mm 1164 mm fiberglass / nylon / neoprene 5,48 $ -
SDP-SI US Imperial/Metric
TechPaladin US GT2 2 mm 5 mm 1160 mm neoprene 8,50 $ -
There is also some on ebay.
Pulleys
Supplier From Type available Pitch Tooth Size (bore, OD,...) Max belt width Material Approximate Cost Additional notes
BBMan US many
Econobelt US many
Misumi multiple
Royal Supply US GT2 2 mm 18 4,7 mm 6 mm Alu cost you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft
SDP-SI US many
TechPaladin US GT2 2 mm 36 5 mm 6 mm plastic/bronze 6 $ -
Ultimachine US GT2 2 mm 20 5 mm 6 mm Alu 11 $ use two set screws
