YARR
Revision as of 09:38, 27 December 2014 by Ledsandchips (talk | contribs) (Communications)
wiki under construction
YARR - Yet Another RepRap
Introduction
YARR (Yet Another RepRap) is an open source 3D printer designed and developed by LEDs&Chips Creative Electronics. YARR is based on the CoreXY technique [1]and adds several improvements to other printers.
Where to buy
 - Leds & Chips Assembled - Portugal
Gallery
Technical specifications
Dimensions
Printer Dimensions: 1250(X) x 1250(Y) x 1250 mm(Z without bowden tupe support) 583 mm(Z with support )
Print Area Dimensions: 750(X) x 750(Y) x 750 mm(Z)
Mechanical Construction
OpenBuilds V-Slot aluminium frame
OpenBuilds Wheels carriages X, Y, Z
Axial ball bearing pulleys B623ZZ for X, Y
Flexible aluminium coupling for threaded rods of Z Axis
9 point print base levelling system with cushioning
Quick change system for print base
Brushless Fans with axial ball bearings.
Print resolution
Very high: 60 microns
High 100 microns
Medium 200 microns
Low 300 microns
Extruder Mechanics
Custom extruder design
0.4mm nozzle
Heat-sinks with axial fan
Part cooling nozzle
Print speed
-Recommended speed: 50 mm / s
-Maximum recommended speed: 120 mm / s
Electronics
Any RepRap electronics conforming to RepRap Interface Standard RIS 1.
LCD with rotary encoder and push-button navigation
Cold glass base (size:750 ​​x 750 x 4 mm)
Power supply: 220 AC 12 DC 100W
Thermistor 100k extruder
Heating element: 12V 40W
Software
Firmware derivative Marlin
Recommended environment: Cura Software
Supported Files:. Gcode
OS supported:
Windows XP and above
Mac OS X and above
Linux
Communications
Standard SD card reader
USB Port Type B
Materials
PLA Filament 1.75-mm
